September 17th, 2015, 07:51 PM | #1 |
Join Date: Sep 2015 Motorcycle(s): 2008 Ninja 250r, 2009 Yamaha C3 Posts: 13
Stripped HEX bolt on rear caliper bracket
I have seen in other threads with the same issue as I have. stripped hex bolt...
I have come to find that I have it with both one with the hunger pin as well as the pin to attach it to the frame. They use a different size bolt 5mm for the caliper pin and it seems to be a 6mm for the assembly. I have ordered the pin which is readily available, but I need to know what part number I need for the other bolt. I can probably work with what is left, but I would rather play it safe and change both while I have the bike on stands. |
September 17th, 2015, 09:05 PM | #2 |
Welcome, Sam !!!
I believe that you are talking about the rear caliper. Take a look at this: http://www.ronayers.com/oemparts/a/k...5d5/rear-brake http://www.ronayers.com/oemparts/#/l...ex250j8f-parts
September 19th, 2015, 01:08 AM | #3 |
MOTM - July '15
Man, that's just rotten luck. On mine, the goober of a previous owner used a little JB Weld as a threadlocker for those bolts. Wasn't fun getting that off.
September 22nd, 2015, 04:02 PM | #4 |
Things happen, I'm not going to get upset, it's just a way to learn the bike a bit more. Although, I found Amazon wasn't the best place to get this part since even though the part number starts with 62903, it isn't the same with all of the sub-part numbers with the 4 extra digits. Going to order the corect one from BikeBandit.
The one I am having the most problems is with this that goes through the caliper needs the most attention. I am going to try to hammer in a similar size torx bit and JB Weld the bit and get some penetrating oil in hopes of it working. I also want to address the other pin that goes through the assembly and the body itself but I cannot find what part it number is. The reason I am getting this is because there is an annoying squeaking sound when I go over 10mph and I am hoping a new pad will fix the problem. Could it be the rotor by any chance? |
September 29th, 2015, 09:45 AM | #5 |
Fixed. Went by Harbor Freight and got a $10 screw extractor kit. Ended up finding that I will need to replace the other screw now... At least it's easy enough to remove it, and was exceptionally easy.
September 29th, 2015, 03:26 PM | #6 |
February 4th, 2017, 04:45 PM | #7 |
Finally Resolved
Went thru a lot of threads...
It was easy after getting the screw extractor.. Used the following from Harbor freight, it has 5 different sizes and is cheap which was the reason I tried it and it worked. http://www.harborfreight.com/screw-e...-pc-61981.html |
February 4th, 2017, 05:13 PM | #8 |
Too bad they don't supply left hand helix drill bits in the kit. Sometimes using one of those to drill the hole actually removes the broken bolt and saves you a step.
4 Piston Brake Caliper Adapter Bracket Upgrade | SV Racing Parts | Motorcycle-related | 30 | February 17th, 2022 05:59 PM |
badly stripped brake caliper screw | LoneRonin | 2008 - 2012 Ninja 250R Tech Talk | 16 | February 10th, 2016 05:34 PM |
Brake Caliper Bracket Torque...Bit Of A Weird One | GiGs | 2008 - 2012 Ninja 250R Tech Talk | 2 | September 7th, 2013 09:14 PM |
Rear caliper allen key bolt stripped | Bones85 | 2008 - 2012 Ninja 250R Tech Talk | 17 | June 30th, 2013 12:32 PM |
Stripped Bolt head on oil filter | Liber | 2008 - 2012 Ninja 250R Tech Talk | 17 | July 17th, 2011 08:23 AM |
