Old December 7th, 2015, 11:33 PM   #1
daverdfw
Motorcycle(s): 2009 Ninja 250
Got some rashed shark skinz for $400
Gotta try my hand at bondo and repair. They were crack and repaired but the outside are need some help.
The last pic is my first try at bondo, will need to sand a lot down, and then apply more bondo to try to fill in the gaps
daverdfw is offline   Reply With Quote
Old December 8th, 2015, 07:12 AM   #2
Looks like you are getting it.
As far as working the Bondo goes, I would suggest making sure the entire area where the filler will be going is sanded pretty aggressively. Typically that's grinding with a 40-grit disc, but that cuts into gelcoat/fiberglass pretty quickly, so maybe a coarse disc on a DA. Then clean well with a degreaser or denatured alcohol.
One tip on shaping the filler - keep working and shaping it as it starts to set-up. As it starts to set, reduce the pressure and continue to lightly shape it with the spreader until you can't any longer.
I would shape what you have with a sanding block and coarse paper (maybe 80 or so) before adding more filler. That will level out the filler that's on there and give you a better idea of where additional filler is needed. It also reduces the amount of filler you need to put on and makes getting the right shape easier. Sand/shape until you start to see high spots of the original material come through.
Old December 8th, 2015, 10:01 AM   #3
daverdfw
thanks for the advice! yeah the area to left got a little rough for some reason. I have a DA, so that will help me get it sanded down pretty quickly. I just wanted to get enough to feather it out. The damage was hard to see in the pic but it was like 1/2" cut. So I knew it would take a few layers to fix it. or at least make it halfway decent.
Old December 8th, 2015, 02:16 PM   #4
bruce71198
bruce71198's Avatar
Once your done painting it get as many decals as you can find, decals disguise fiberglass repairs really well
Wanted : 08+ Fairings (Rashed/minor cracks ok) FBR_BDavis Items Wanted 6 June 4th, 2015 10:14 AM
FS: 08-12 Rashed Fairings Trailerboy531 Motorcycle-related 12 March 24th, 2013 09:29 PM
Anyone in the ATL area sporting Shark Skinz or Hotbodies race fairings? CZroe 2008 - 2012 Ninja 250R Tech Talk 0 October 13th, 2012 01:35 PM
Rashed Hotbodies race bodywork RaceBikeRentals Motorcycle-related 23 February 25th, 2012 01:33 PM
Shark Skinz? caps 2008 - 2012 Ninja 250R Tech Talk 13 May 9th, 2011 12:51 PM
