January 2nd, 2016, 02:32 PM | #1 |
Join Date: Jul 2015 Motorcycle(s): '99 Ninja 250 Posts: 37
Sudden noise change, loss of power. [VIDEO] [SOLVED]
FIXED
Spark plug came loose Alright guys, so recently I fixed my bike up tip top and it was running fine, maybe running rich, but not giving me any other issues after I replaced the R/R which was causing the battery to die after multiple startups. Now I have my newest problem. Yesterday I decided to go grab some gas and run some errands. So I make the 3 mile drive to my grocery store, pick some items up, start the bike back up and begin cruising to the other side of the parking lot to the gas station. I was in first gear doing about 6mph (about 5k) when I approach the longer "Stretch" portion of the parking lot that leads to the gas station so I went to let it wind up before I shifted into 2nd (about 8k) and I was immediately greeted by an absolutely hideous new exhaust noise and a quite noticeable loss of power even in 1st. The sound from the exhaust is really hard to explain, though "Farting" comes to mind . So I immediately killed the engine and coasted into the gas station and filled her up. Then rolled her back into the grocery store parking lot. Pulled off the side panels to check and see if any tubes / hoses had come undone. I would explain the noise but thats what the video is for. So I had to go home and change clothes to get to work at this point and since I didnt have any rides, a had to limp the bike back home. So I drove it back home at about 30mph in 6th gear..throttle pinned. It wouldn't accelerate past 35mph no matter the gear... So I get back home put her in the garage.. Fast-forward to today, I have only checked the coolant since I read that someone with a similar story said his coolant had turned brown. My coolant is still a nice green, but with some weird whitish particulates floating around. Though it could just be random crap from the reservoir (it isnt the cleanest). My next step is to take the gas tank off and check the plugs. Though the problem with this being the fact that the left side of my tank has a hole straight through the tank (either mechanic or PO put to big of a bolt.) I had fixed this with some epoxy though, just I now have to drain the tank using a hand pump before I remove the bolt. BUT the hoses for that hand pump are nowhere to be found so Im going to have to find some other way to siphon the gas before I can remove the tank. https://youtu.be/hRJEFh7eZP0
We may not all be geniuses, but we are all genius to some. Hard work betrays none, dreams betray many. Last futzed with by Calix; January 2nd, 2016 at 07:57 PM. |
January 2nd, 2016, 02:37 PM | #2 |
Fast-Guy wannabe
MOTM - Jan '13
you video doesn't work for starters. My scooter once lost nearly all its power during my commute and I had to limp it in the last 4 miles WOT going like 20mph. Bike was sputtering and backfiring like crazy. Ended up being the spark plug got a little loose and was making intermittent contact.
January 2nd, 2016, 02:41 PM | #3 | |
Fixed, the youtube player doesnt like the video for some reason
We may not all be geniuses, but we are all genius to some. Hard work betrays none, dreams betray many. |
January 2nd, 2016, 07:54 PM | #4 |
FIXED!
Turns out the spark plug in the right cylinder popped out completely. Have no clue how, must of been loosening over time. Tightened the left and right plugs back down and soldered and sealed the coils to the boots.
January 2nd, 2016, 10:47 PM | #5 |
Fast-Guy wannabe
MOTM - Jan '13
well that was unexpectedly easy to diagnose
January 3rd, 2016, 08:00 AM | #6 | |
Did you renew the HT leads, and disassemble the caps?
Make sure you disassemble the caps, and clean them, and yes the caps get cruddy. Here my write-up, Quote:
Here's some pictures that might be helpful. I took these when I replaced the wires themselves, as it was a good time for a write-up, and the wires were OEM from 1998. IMPORTANT NOTICE: make sure to use a proper screwdriver, make sure it fits, as the parts are made of brass inside the spark plug caps Wires are just 7mm copper core, with clear silicone jacket
January 3rd, 2016, 09:04 AM | #7 | |
The next time my gas tank is off, for whatever reason, I plan on replacing the wire.
January 3rd, 2016, 09:15 AM | #8 | |
You just have to trim enough off so the ends are fresh, it only takes a few minutes. Renewing the HT Leads is highly recommended, if not mandatory.
January 3rd, 2016, 09:24 AM | #9 |
If you have a some $$, I also suggest doing the CoPs modification, as it has its advantages, like a better spark for one.
https://www.ninjette.org/forums/blog.php?b=8379 https://www.ninjette.org/forums/showthread.php?t=241339
January 3rd, 2016, 09:29 PM | #10 |
You'd be surprised how common this is, over the 9 years I've owned an EX250 I've read probably 15 posts where peoples' bikes have coughed out a spark plug.
Sometimes the threads in the cylinder head go out with the plug. I guess that's a sign of weakened threads from overtightened plugs. Sometimes the threads in the cylinder head are undamaged. I guess that's a sign that somebody didn't tighten the plug properly. You should inspect the bottom of the fuel tank. About half of the owners who posted about a blown out plug mentioned a pretty good dent in the bottom of the fuel tank. |
January 10th, 2016, 02:08 PM | #11 | |
Was riding normally then a sudden loss of power... | peterpayne | 2008 - 2012 Ninja 250R Tech Talk | 2 | March 29th, 2015 09:47 PM |
[kropotkin thinks...] - 2013 Mugello Moto2 QP Result: A Sudden Change Of Fortune | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2013 08:20 AM |
Loss of power, but I think I know why... | rmorse | 2008 - 2012 Ninja 250R Tech Talk | 1 | August 13th, 2012 08:16 AM |
Loss of power? | oblivion007 | 2008 - 2012 Ninja 250R Tech Talk | 2 | June 4th, 2011 08:07 PM |
Loss of power on highway (all the power) | aldenso | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 7th, 2011 10:27 PM |
