Old January 10th, 2016, 08:59 PM   #1
RadenRider26
Raden Rider
Motorcycle(s): ninja 250R 2010
exhaust issue
ok a few issue with my yosimurah exhaust ill post the pic berfore i ask question, keep in mind i brought the bike second had with the exhaust already on it.
now for my question
1. how do i know this is real and not fake???
2. if i haven't ridden the bike for 2 day or more when i turn it over it backfire, any one know maybe why?
3. it sound different to when i bought it ( i there anything i need to change with in the exhaust its self?)
any help would be good thakxs
Island style Bro
RadenRider26 is offline   Reply With Quote
Old January 11th, 2016, 09:46 AM   #2
2) It could be that the mix is lean when the engine fires up.
Lean mix burns slow and the last phase of the explosion makes it out to the muffler.
When the engine is cold, some fuel condensates over the walls of the carb and intake boots and passage, resulting in a mix that is leaner than normal.
That is the reason for the application of choke when the engine is cold (to inject additional fuel into the air stream).
If it happens with applied choke, it may indicate that the choke circuits in the carburetors are clogged.
Exaust valves out of adjustment could cause back-fires as well.
3) That change may be related to any work that you have done on the bike since you bought it.
Old January 12th, 2016, 07:35 PM   #3
RadenRider26
Raden Rider
ok i will try with coke on the next time thanks for the tip
no work has been done to the bike. i think the could be a hole in the exhaust, well that what a friend told me. is this possibility?
Island style Bro
Old January 12th, 2016, 09:07 PM   #4
........ no work has been done to the bike. i think the could be a hole in the exhaust, well that what a friend told me. is this possibility?
A hole will increase the noise coming from the exhaust, but will not induce back-fires, in my opinion.
Old January 12th, 2016, 10:39 PM   #5
RadenRider26
Raden Rider
iya its was louder the it was before and no longer smooth it sound like a cat being run over
Island style Bro
Old January 12th, 2016, 11:06 PM   #6
Check the connection of the pipe to the cylinder and to the muffler.
Sometimes, those get loose with vibrations and increase the noise.
You could also drain the bowls of the carbs, just in case you have some water in those.
Also check the intake air filter for excessive dirt and any restriction to the air flow.
I would check the valves, if you don't know when and how the previous owner did that.
While checking the valves, I would install new spark plugs and clean the plug's connectors and cables.
If nothing works, you will need to clean the carburetors and verify the size of the jets.
Old January 13th, 2016, 05:35 AM   #7
Yamahawk
Chaplain
Yamahawk's Avatar
Motorcycle(s): 75 RD350 race bike, 82 XZ550RJ Vision, 81 XV920RH, 89 VTR250 Interceptor race bike, 06 Concours, 86 EX250E1
A hole will cause it to backfire on deceleration, as it is sucking in fresh air (oxygen), as well as a leak anywhere in your exhaust system, like a leaky gasket. The hole is easy to find, the leaky gasket or connection, not so easy. You have to check for exhaust pressure at the joint to see where it is leaking. You can put a hand next to the suspected area, and feel for the leak while the engine is running. Just be very careful not to burn yourself, as I have done before
God chose what the world thinks foolish to shame the wise,what the world thinks as weak to shame the strong,what is despised in the world,what is nothing,to set aside what is regarded as something
Yamahawk is offline   Reply With Quote
Old January 13th, 2016, 07:36 PM   #8
RadenRider26
Raden Rider
hahah thank ill give it a shot, over here we call an exhaust burn
a bali kiss
Island style Bro
Old February 2nd, 2016, 07:03 AM   #9
How is it working now?
Old February 2nd, 2016, 08:38 PM   #10
RadenRider26
Raden Rider
got the bike serviced, there was something lose on the exhaust now it fixed and sound good back to normal.
Island style Bro
Old February 3rd, 2016, 09:29 AM   #11
FS: Area-P solo exhaust bracket for Ninja 300 w/stock exhaust c-dog Motorcycle-related 2 September 12th, 2014 10:48 AM
Tyga full exhaust leak issue 675Raisinator 2008 - 2012 Ninja 250R Tech Talk 11 March 27th, 2012 12:32 PM
exhaust issue i think? pezlow010 1986 - 2007 Ninja 250R Tech Talk 6 August 12th, 2011 10:17 AM
[superbikeplanet.com] - Suzuki: Haslam's Wrist Issue Should Not Be An Issue Ninjette Newsbot Motorcycling News 0 May 11th, 2010 07:50 AM
Have a lean issue with my bike, issue with coasting enricher. twiggy2cents 1986 - 2007 Ninja 250R Tech Talk 7 February 24th, 2010 06:54 PM
