Old February 13th, 2016, 06:22 PM   #1
chugs
Schönen Tag noch
chugs's Avatar
Motorcycle(s): 08 ninja 250 race bike, 02 gixxer 600 telefonica
Fiberglass repair tips?
First attempt at repairing my fiberglass fairing. The fairings came with the bike and seems its time to get them repaired. Any tips? Left pic, its cracked through the windscreen bolt barely hanging on with the windscreen as support. Right pic as you can see has a big tear in it.
chugs is offline   Reply With Quote
Old February 13th, 2016, 06:26 PM   #2
chugs
Schönen Tag noch
chugs's Avatar
Left pic right side upper, missing upper portion where it bolts to tank. Middle pic, is left side upper torn section as well as below that where it is cracked in mid fairing. Right pic, has a small few holes when it was sanded.
Old February 13th, 2016, 06:32 PM   #3
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Popsicle sticks or small carbon rods make great reinforcement for weak or flexible areas. You can get the small carbon rods at a hobby shop that sells airplanes...they're used as wing braces.
Use only enough resin to WET the fabric! Strength comes from the fabric, not the resin.
Get a good quality weave not the random chop stuff like you get from an auto parts store.
Glass the inside, bondo the outside. Glass mat is pretty rough texture when it's done right.
Goin' fast on slow bikes!
Old February 13th, 2016, 06:56 PM   #4
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Wax paper on the final surface is a nice way to get a smooth surface.
Worlds fastest 250 ninja
Old February 14th, 2016, 03:32 PM   #5
hfd1 tuner
Motorcycle(s): many mostly racebikes cbr565 fzr490 ex250ish
Something that I am well suited for crash damage repair! Lots of practice Repair using west marine epoxy from back side use woven fiberglass just a couple layers is fine. Chopped strand is too thick as said pop sticks work good to hold stuff in place use blue painters tape on the outside it keeps epoxy from running out and gives shape to the cracks that can be sanded down. You can mix some 404 filler up in the epoxy good and thick and paste in big cracks in the gel coat The epoxy is strong and bonds super good to fiberglass. New bodywork always looks great but fixing broken stuff builds your skills...something about the smell of fiberglass dust
hfd1 tuner is offline   Reply With Quote
Old February 14th, 2016, 05:54 PM   #6
chugs
Schönen Tag noch
chugs's Avatar
Thanks for the tips, will update as I make progress.
Old February 15th, 2016, 09:44 AM   #7
tgold
Motorcycle(s): 2006 1050 Speed Triple, 2010 250 Ninja racebike, YZF320RR? Racebike
MOTM - Nov '15
Rough up the surface that you are bonding to with 100 grit sandpaper to remove loose paint and to promote better adhesion.
Don't sand too much though because you start to cut into the glass fibers and that reduces strength. The pebbly surface on the inside of the bodywork will bond ok, just a little roughing it up will help.
Sometimes you can have problems with adhesion due to the oily residue and grime that can get all over the inside of the bodywork. This is especially true when you are fixing a belly pan, so make sure that the bonding surface is super clean.
tgold is offline   Reply With Quote
Old February 16th, 2016, 05:34 PM   #8
chugs
Schönen Tag noch
chugs's Avatar
Thanks will keep that in mind.
Fiberglass Fairings burnrich 1986 - 2007 Ninja 250R Tech Talk 1 January 25th, 2014 08:03 AM
fiberglass on panels to transform the look? anybody know how? azian4lifz 1986 - 2007 Ninja 250R Tech Talk 1 October 11th, 2013 07:11 PM
[topix.net] - Joe's Scooter Repair: Not limited to just scooters, they also repair AT Ninjette Newsbot Motorcycling News 0 August 12th, 2012 08:30 PM
fiberglass repair Stingray1000 1986 - 2007 Ninja 250R Tech Talk 7 May 14th, 2012 11:26 AM
Anyone know how to repair Fiberglass?? ichibunkid.206 Off-Topic 4 June 16th, 2011 02:29 PM
