Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 General Discussion
Old March 4th, 2016, 07:34 PM   #1
RickM
Motorcycle(s): 2000 EX250
Rear Shock compatibility between pregen, 08+ 250 and Ex300 ?
I have a Fox rear shock removed off my old 1999 ninja 250 track bike. I was going to sell it. But when I noticed peeple are swapping the new gen and N300 shocks into the old bikes, it got me wondering if I can use my fox shock on a 300? I can get it revalved/resprung if necessary for $200 ish. So I am wondering as long as the shock length is close and the clevis and eye are same size it should work.
Anyone here used an aftermarket shock originally made fore the pregen on the 300 or 08+ 250??
I am planning to get a 08+250/ N300/ R3 depending on what kind of deal I find later this season or early next season. So if can use this shock for the 300/new 250 I'd rather hold on to it till I decide on yam or Ninja 250/300 instead of selling it for peanuts now.
Any ideas??
Thanks in advance
RickM is offline   Reply With Quote
Old March 4th, 2016, 07:37 PM   #2
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Pre gen shocks make about 1.5" difference, IIRC. In other words, if you put it in a 300 it will lower the rear by 1.5". I suppose you could get different links to raise the back end up but I'm not sure what that would do for the travel.
Goin' fast on slow bikes!
Old March 4th, 2016, 07:43 PM   #3
RickM
Thanks for the response. I assume it's 1.5" at the wheel and hopefully not 1.5" diffrence in shock length.
The shock is ride height adjustable. So wondering if there is enough adjust-ability there to compensate. I will look into that. I guess my 1st step should be finding out the stock shock length for the 300. I'll do a search
Old March 4th, 2016, 07:48 PM   #4
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Yes, it's 1"+ at the wheel, not the shock.
Pregen rear spring shock alternatives greenaero 1986 - 2007 Ninja 250R Tech Talk 41 March 4th, 2016 08:53 AM
Pregen rear shock Josh_kcco Motorcycle-related 0 March 7th, 2014 11:23 PM
Best rear shock for the pregen Josh_kcco 1986 - 2007 Ninja 250R Tech Talk 17 March 6th, 2014 08:13 PM
Newgen rear shock in Pregen. 02337 1986 - 2007 Ninja 250R Tech Talk 35 October 31st, 2012 11:25 AM
Pregen Ninja 250 stock exhaust and rear shock $15 plus shipping super sale! Grn99Kawi Motorcycle-related 1 May 31st, 2010 06:29 PM
