Old March 18th, 2016, 06:35 AM   #1
mikedabike64
Motorcycle(s): 2008 ninja 250
Removing lights for track use
Guys I did quite a few track days on my 250 but plan on using my 2014 300 in the up coming months Having a rough time accessing lights I tried pulling the light fuse but I could hear a buzzing near the fuse box and thought better of it until I asked Also the plastics are more elaborate so again I thought I would stop in and ask if pulling the fuse is a go? Thanks Mike H from PSL Florida
mikedabike64 is offline   Reply With Quote
Old March 18th, 2016, 07:16 AM   #2
I don't know why pulling fuses would be an problem. It's been done without issue.
Remember to check with your track org's rules to make sure it's kosher with them. You really only need like 3 fuses to keep a 250 running, not sure how many extra fuses a 300 needs, with the FI and all.
Old March 18th, 2016, 07:20 AM   #3
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
Do yourself a favour if only using for track bike, pull ALL the original fairings & store them, then remove lights. Then add cheap track fairings, if you are keen, then replace the rear subframe or shorten it to single seat size. Remove all bolted on items that are NOT required to run the bike to cut the weight to a minimum. Add crash bungs or covers.
Less items = less damage/expense should you unfortunately come off !
Old March 18th, 2016, 07:24 AM   #4
^^ werd.
But there isn't really a removeable rear subframe for the 300 like there is with most supersports.
here's a 300:
For comparison, here's a ZX6R:
Old March 18th, 2016, 07:28 AM   #5
mikedabike64
Ok guys thanks
I find these fairings puzzling mainly bc I haven't yanked them off like my 250 was a breeze.
Maybe just have to get used to its disassembly
Thank you.
Old March 19th, 2016, 05:08 PM   #6
toEleven
Slower than you.
toEleven's Avatar
Motorcycle(s): CBR600RR, CB750, EX300 (半蔵)
MOTM - May '16
I'd suggest you acquire the service manual. It would be a lot faster to just follow the official instructions rather than guess and hope. Better still, you can acquire the manual as cheaply as your moral fiber will support on ye olde internets (ie free pdf).
Personally I found the 300's fairings amusingly complex compared to other bikes I've worked on.
DISCLAIMERv1.0: There may be more info on the topic than this forum post. Conduct your own research.
If another thread is linked or quoted, go read it yourself.
toEleven is offline   Reply With Quote
Old March 19th, 2016, 06:07 PM   #7
mikedabike64
Ok 11
I hear ya on the fairing went to take strip them off a couple times. I'll get the manual
Pulling lights for track mikedabike64 Ninjettes At Speed 5 August 28th, 2015 07:35 AM
Removing the carb-without removing airbox? tuscani451 2008 - 2012 Ninja 250R Tech Talk 10 July 6th, 2014 05:11 AM
Electric start problem, lights, blinkers, and indicator lights work. claymaker 1986 - 2007 Ninja 250R Tech Talk 8 July 10th, 2012 07:04 PM
Removing Mirror Bracket (with removing all the fairings) killermase 2008 - 2012 Ninja 250R Tech Talk 11 May 21st, 2012 11:16 PM
NIGHT Track day under flood lights at Streets of Willow - July 9 nope Ninjettes At Speed 20 July 22nd, 2010 01:50 PM
