Old March 27th, 2016, 02:14 PM   #1
ULW
ULW's Avatar
Motorcycle(s): 2015 Ninja 300 X 2
Fork retrofit
The following components seem to be pretty weak in terms of performance on the Ninja 300, in order according to my perception:
1. Front Brake Calipers
2. Front Brake Rotors
3. Front Forks
4. Front Wheels
5. Front Triple Clamps
Seems like this would be handled by a nice retrofit, perhaps from the 600 class bikes. What are some examples that seem to work? Getting a set of triples to accommodate would be one challenge... preferably adjustable offset.
ULW is offline   Reply With Quote
Old March 27th, 2016, 02:29 PM   #2
AwDang
Motorcycle(s): 286, 296, 599, 799
The brakes suck only if you use them.
AwDang is offline   Reply With Quote
Old March 27th, 2016, 02:49 PM   #3
chugs
Schönen Tag noch
chugs's Avatar
Motorcycle(s): 08 ninja 250 race bike, 02 gixxer 600 telefonica
Compare steering stem bearing dimesions from donor bike and yours and that might clarify the triple clamp issue. IIRC from a members busa front end swap, he mentioned using 250r bearing paired with a busa front end will bolt on. The 300 and 250r utilize same bearing.
Found this useful "Find Fork Conversion Bearings" on the all balls website. Very useful data.
http://www.allballsracing.com/index.php/forkconversion
chugs is offline   Reply With Quote
Old March 27th, 2016, 03:08 PM   #4
ULW
ULW's Avatar
Great... although that seems like an odd one, I will look into it.
Can I use different brands of the same weight fork oil in each fork? daverdfw 2008 - 2012 Ninja 250R Tech Talk 18 March 2nd, 2016 04:08 PM
FS: Pregen : Fork Springs, Fork Clamp, Factory Pro Jet kit FvnnyL3tt3r1ng Motorcycle-related 20 February 24th, 2016 08:24 AM
Can fork springs be changed without removing the fork tubes? AlanDog 1986 - 2007 Ninja 250R Tech Talk 26 April 23rd, 2014 05:19 AM
Projector Retrofit ricochet08 Off-Topic 3 December 4th, 2012 01:28 AM
bixenon retrofit alex.s Pictures 9 February 4th, 2011 06:00 PM
