Old August 9th, 2009, 12:00 PM   #1
n4v1n
Motorcycle(s): 2009 ninja 250r
Can any damage occur to the engine in a lowside?
Recently lowsided the bike, it slid on its left side and hit a sign post with the fuel tank, denting it where it meets the seat. The bike was started the next day, sounded fine. I would just like to know if there could be any other damage besides what is cosmetic/obvious. Can I still ride with a dented tank, or will it affect the vaccum in the fuel line or something? It costs like ~$350 for the tank so If I can make do with out it I can just replace fairings, clutch lever, and shifter.
Also, what are the fairings in the back of the bike that wrap around the rear seat called? I can't seem to find them on the site I'm looking at for oem parts.
n4v1n is offline   Reply With Quote
Old August 9th, 2009, 01:24 PM   #2
CRXTrek
FORMER MOTORCYCLE RIDER
CRXTrek's Avatar
Cover-Tail
Part#36040/A~C
The letter A~C is the color
http://www.bikebandit.com/houseofmot...-2009/o/m17969
Old August 9th, 2009, 07:27 PM   #3
n4v1n
Thanks, does anyone know what I should do about the fuel tank?
Old August 9th, 2009, 07:28 PM   #4
as long as it's not leaking, you can ride with a dented fuel tank, if that's the question.
Old August 10th, 2009, 07:29 AM   #5
TrueFaith
TrueFaith's Avatar
Motorcycle(s): 2011 Honda CBR250R
Make sure to check the swingarm and rear axle carefully. If you contacted the tail fairings you probably did some damage to it. Mine was totalled by the insurance inspector even though it looked fine to me.
TrueFaith is offline   Reply With Quote
Old August 10th, 2009, 08:14 AM   #6
Broom
Track Junkie
Broom's Avatar
Motorcycle(s): '08 Ninja 250r Track Bike, DR350 commuter, KDX220 woods bike
the motor should be fine unless you managed to crack or grind through your side cases, but that'd be visually obvious. especially if its spewing oil.
i'd loosen up your triples and realign your forks (i think theres a DIY on this somewhere on here), and try to make sure your swing arm and stuff isn't binding up any. it should be fine.
Las Escobas -- Track Bikes Save Lives
JonBroom.com
Broom is offline   Reply With Quote
Old August 10th, 2009, 08:28 AM   #7
tjkamper
tjkamper's Avatar
As long as the bike isn't bleeding you should be fine. You should inspect the entire bike and make sure there is nothing else broken or out of alignment, and then take it for a little, gentle spin arround the block. If it rides fine, then just fix the cosmetic stuff. The tank should be fine dented as long as it doesn't leak.
Cam Chain replacement, possible engine damage Ginganinja 1986 - 2007 Ninja 250R Tech Talk 113 April 10th, 2014 05:08 AM
Lost Front Engine Mount Bolt - Pics of damage inside hawker1693 1986 - 2007 Ninja 250R Tech Talk 56 August 26th, 2013 04:08 PM
[sportrider - tech] - Ask the Geek: CBR Forks, Engine Damage and Race Tires Ninjette Newsbot Motorcycling News 0 April 13th, 2010 04:00 AM
[sportrider - tech] - Ask the Geek: CBR Forks, Engine Damage and Race Tires Ninjette Newsbot Motorcycling News 0 March 29th, 2010 11:40 PM
[sportrider - latest stories] - Ask the Geek: CBR Forks, Engine Damage and Race Tires Ninjette Newsbot Motorcycling News 0 January 28th, 2010 01:50 PM
