April 23rd, 2016, 03:37 PM | #1 |
Join Date: Apr 2013 Motorcycle(s): 2012 Ninja 250 Posts: 10
Question On Cleaning The Carbs
My 2012 Ninja 250 doesn't want to start after sitting quite some time. I figure it probably needs to have the carbs cleaned. I was able to remove the fairings, seat and tank pretty easily using the DIY'ers on this site. My issue is I can't figure out if I need to remove the airbox to remove the carbs, or what screws this requires. Any tips would be appreciated.
April 23rd, 2016, 07:27 PM | #2 |
Board Member
you dont NEED to remove the airbox, but it makes the job of removing the carbs a lot easier. In order to do that, you need to drop the rear tail pan. It is pretty involved for what you think it is.
don't forget the screw down by the sprocket holding the airbox down. |
Carb cleaning QUESTION | ortizj2289 | 2008 - 2012 Ninja 250R Tech Talk | 17 | April 3rd, 2015 01:19 PM |
Removing and cleaning carbs and K&L Repair Kits | peterpayne | 1986 - 2007 Ninja 250R Tech Talk | 4 | November 4th, 2013 03:49 AM |
High Idle at 4500rpm after cleaning carbs | NinjaBob | 1986 - 2007 Ninja 250R Tech Talk | 5 | June 14th, 2013 09:38 PM |
Cleaning carbs. Need some help please! | tjb0012 | 2008 - 2012 Ninja 250R Tech Talk | 4 | November 1st, 2012 11:02 AM |
Is Cleaning the Carbs a Pain the Ass ? Any Tricks/ Tips ? | RedNinja09 | General Motorcycling Discussion | 4 | December 1st, 2009 09:58 AM |
