Old August 15th, 2009, 11:07 AM   #1
dimeified
Motorcycle(s): '09 Blue 250R
1st oil change 600 miles, 2qts too much?
Did my first oil change at 600 miles went with mobile1 10w-40 4t. Followed the diy completely. Oil was 3/4ths up site glass when vertical after 5 min idling. That was with 2 qts. This oil is synthetic. Went for a ride now oil level is full just before the bike is about vertical. Should I drain some? Did I f anything up?
Posted via Mobile Device
dimeified is offline   Reply With Quote
Old August 15th, 2009, 11:26 AM   #2
a10forwar
Motorcycle(s): 09 Ninja 250R SE
No leave it be. Just put 1 and 7/8 in next time. I dont recall the exact amout but it is just under 2. But you are fine dont sweat it. Ride the **** out of it. It will thank you.
a10forwar is offline   Reply With Quote
Old August 15th, 2009, 11:40 AM   #3
dimeified
its interesting after another trip its just under full while idling after a long run. wow. anyway, thanks for the answer!
2 thumbs up
Old August 15th, 2009, 12:12 PM   #4
oil level should be checked with the bike warm, engine shut off for about five minutes and bike level and vertical.
Old August 16th, 2009, 06:49 PM   #5
dimeified
Today i ran to the drug store and came back, turned the engine off, stood vertical, oil was between 3/4 and full in the site glass. I wonder if switching to fully synthetic had anything to do with it.
2 thumbs up
Old August 18th, 2009, 07:38 AM   #6
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
syn oil wouldn't make it appear different in the sight glass. its probably slight variations in how vertical it is. a couple degrees will move the oil a bit in the sight glass. If you have a 2X4 that holds it near vertical you will get a better reading (or at least a consistent reading).
Oil change at 62 miles & 15/41 sprockets JoeLansing 2008 - 2012 Ninja 250R Tech Talk 3 July 17th, 2011 05:46 PM
Oil change-190 miles-filter too? wild-bill 2008 - 2012 Ninja 250R Tech Talk 19 June 20th, 2011 12:54 PM
I did my 1st oil change question! Duvivr6 2008 - 2012 Ninja 250R Tech Talk 19 July 7th, 2009 08:19 AM
1st oil change - not so well. dmonaco05 2008 - 2012 Ninja 250R Tech Talk 24 June 1st, 2009 07:57 PM
Did 1st oil change--have questions birdy 2008 - 2012 Ninja 250R Tech Talk 9 March 19th, 2009 10:20 AM
