Old July 28th, 2016, 07:04 PM   #1
motodancer
motodancer's Avatar
Motorcycle(s): 08 250
Lowering Bike / Handlebars
When you lower the bike (front and back evenly), will the handlebars stay at the same height and/or will they go up?
Does that even make sense?
I tried to search it here as well as Google it, but I don't think I was putting in the right word combinations because I couldn't find anything on it except for lowering/raising the handlebars themselves (which I will not be doing)
(For those who've read my intro post months ago - yes, I've decided to keep the Ninja & lower it an inch or so)
motodancer is offline   Reply With Quote
Old July 28th, 2016, 07:43 PM   #2
MauR
MauR's Avatar
Motorcycle(s): 250R
As far as I know lowering the front WILL rise the handlebars unless you use clip-ons.
MauR is offline   Reply With Quote
Old July 28th, 2016, 07:55 PM   #3
I'm not sure that's always the case. I thought that the point of the lower blocks on the front was that you slipped the fork legs a bit further through the triple tree, so you put the blocks on top (with holes that fit the pegs), so when you attach the stock handlebars on top of the blocks, they end up at roughly the same height (compared to the seat) as they were before. If you lower the front of the bike without those lowering blocks, I think you do need to find a way to mount clipons, as the stock handlebars won't be able to attach against the tripletree anymore.
Old July 29th, 2016, 05:34 AM   #4
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
No, that's not right. The bars will stay at the same height relative to the ground, but not the seat.
The ninjette bars are on top of the fork tubes, which do not change their height relative to the ground. Any solution that keeps the bars mounted to the top of the tubes will leave them right where they are to begin with. But when you lower, the rest of the bike moves down, including the seat.
The purpose of the blocks is to give the handlebar mounting bolts something to grab onto, nothing more.
The only way to keep the bars at the same height relative to the seat is to use clip ons. Two options here:
1) Get some with risers and mount them below the triple, or
2) Lower enough that there's sufficient tube sticking out on top to allow clamping of the clip on.
Old July 29th, 2016, 06:41 AM   #5
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
What they said.
With clipons, the fork tube slides through the mount, so the bars stay in the same place relative to the triples. You may or may not be able to mount them above the triple, depending on how much of the fork tube is sticking through.
With the stock risers, they mount above the fork tube, so they inherently will stay the same height from the ground, regardless of how far up or down you slide the triples. You need the blocks to provide more room for the top of the fork tube to stick up through the triple, while still allowing the riser to bolt onto the triple.
Old July 29th, 2016, 08:40 AM   #6
motodancer
motodancer's Avatar
So.. the answer is the handlebars will stay the same height relative to the ground even if the rest of the bike gets lowered..??
Old July 29th, 2016, 08:52 AM   #7
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
With the stock bars: yes
With clipons: maybe but probably lower
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old July 29th, 2016, 08:55 AM   #8
adouglas
adouglas's Avatar
Right. Height depends on the clip-ons you get. Do some homework... you'll find that different riser heights are available for clip-ons. Woodcraft are the go-to option.
Old July 29th, 2016, 02:23 PM   #9
MauR
MauR's Avatar
Motorcycle(s): 250R
I'm using Vortex over the triple tree with no other modification.
Old July 29th, 2016, 06:05 PM   #10
motodancer
motodancer's Avatar
I clearly don't know enough since I didn't understand the replies.
(Like I said, I couldn't find anything when I googled probably because I didn't know what words to use)
Are clip-ons required to lower the bike?
Here's what I want: Lower the bike, but not the handlebars (so I'll be sitting slightly more upright, right?)
Old July 29th, 2016, 06:15 PM   #11
adouglas
adouglas's Avatar
Oh, okay. That's not what you originally asked... you asked whether the handlebars would stay at the same height or not. Wanting to keep them at stock height while you lower the bike wasn't part of the query.
You've got your answer in the posts above. No, clip ons are not required to lower the bike. They are required to keep the bars at the same height relative to the seat, however.
The blocks shown in the second photo in InvisiBill's post do exactly what you're after. They leave the handlebars at their regular height, while the rest of the bike lowers. Therefore, the bars are higher relative to your seat, which makes for a more upright riding position.
Does that make sense?
Old July 29th, 2016, 06:27 PM   #12
motodancer
motodancer's Avatar
Oh I worded it wrong because that IS what I originally asked! I asked if they'd stay at the same height (original height BEFORE the bike is lowered), not same height with the seat. I'm still learning vocab here
And that does make sense. Thank you
Old July 29th, 2016, 07:09 PM   #13
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Are you using the roaring toyz kit?
I had it on the 250 and 300, It did what I needed and felt good.
Old August 2nd, 2016, 06:12 AM   #14
motodancer
motodancer's Avatar
Ok the pictures make more sense now since we lowered it
We got the parts from blackpath.?
I love it
lowering my bike lowdown112 1986 - 2007 Ninja 250R Tech Talk 2 May 25th, 2013 08:18 PM
lowering the bike question...but i have an EX500 spring rabies 1986 - 2007 Ninja 250R Tech Talk 5 September 8th, 2012 06:42 PM
using 'lowering' links to RAISE the rear of the bike? tommycruising 2008 - 2012 Ninja 250R Tech Talk 17 June 12th, 2012 03:51 PM
Lowering a bike further with 16' rims??? snowlife 2008 - 2012 Ninja 250R Tech Talk 23 June 3rd, 2009 03:48 PM
Is lowering a bike safe? PinkNinja81 General Motorcycling Discussion 11 May 7th, 2009 05:55 AM
