Old August 23rd, 2016, 11:46 AM   #1
ninja-turtle
ninja-turtle's Avatar
Motorcycle(s): Kawasaki 636
Ninja 300 rear sets (footpegs)
Looking for OEM only throwaways or something cheap. Thanks yall
Last futzed with by ninja-turtle; August 24th, 2016 at 03:39 PM.
ninja-turtle is offline   Reply With Quote
Old August 23rd, 2016, 06:34 PM   #2
snot
sammich maker
snot's Avatar
MOTM - Apr '15
I use vortex, the parts are cheap to replace. The set is not cheap but at least replacement parts are.
Maybe a used oem set will work if someone wants to part with them?
Old August 23rd, 2016, 07:33 PM   #3
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Vortex FTW!!! no extras; sorry
Old August 23rd, 2016, 07:35 PM   #4
JohnnyBravo
eBay has some cheap ones from china, if you can't find any... You may have already looked there though?
Old August 24th, 2016, 03:24 PM   #5
ninja-turtle
Vortex Not for the win. I have vortex and it bent my frame during a lowside at the track prior to the race. Hence why I'm looking for stockers that would break apart instead of bending my frame...again.
Old August 24th, 2016, 08:44 PM   #6
JohnnyBravo
Oh... I got a brake side for a 300
Old August 25th, 2016, 05:30 PM   #7
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Never heard of that happening before. I can understand wanting stock.
Old August 25th, 2016, 07:03 PM   #8
JohnnyBravo
I've heard of it... There are posts around th ninjette at speed on how to fix the frame afterwards... I will look it up shortly
Old August 25th, 2016, 07:28 PM   #9
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
It's pretty common, our frames are really weak. If you're lucky you can bend it back with a little heat. If you're unlucky then you need to do some welding
I was pretty sad when ninja-turtle wasn't able to race with us because of that issue
Old August 26th, 2016, 08:03 AM   #10
ninja-turtle
I missed the race but later on (after I went home) was able to bend it back with some heat on it. Coincidentally just the day before two other track buddies were telling me to install relocates and utilize stock pegs instead. A track day or two prior anot her buddy crashed his 250 and it completely ripped apart that side of his frame.
I' just need to find a spare set to carry with me at all times just incase
Old August 26th, 2016, 09:28 AM   #11
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Carry a spare frame
Old August 26th, 2016, 11:20 AM   #12
JohnnyBravo
I'm starting to think I should by a shift side and some brakets... But I Relly like the look of the vortex... I know I won't like the look of a twisted frame though
Old August 26th, 2016, 01:50 PM   #13
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
wont see the twist when you're on it
Old August 26th, 2016, 04:24 PM   #14
JohnnyBravo
true
Old August 26th, 2016, 04:24 PM   #15
shift957
shift957's Avatar
Motorcycle(s): R6, SV 650, 300, 250, 250 xc-w
What about the cheapy rear sets on ebay from hong kong/china? They aren't expensive and look alright and I imagine they bust up nicely in a crash. Anyone here used them?
shift957 is offline   Reply With Quote
Old October 25th, 2016, 10:35 AM   #16
bkbaseballa16
Motorcycle(s): Ninja 300
I have a set you may interested in. text me. 561-578-2573
bkbaseballa16 is offline   Reply With Quote
Old October 25th, 2016, 04:24 PM   #17
jrshooter
Motorcycle(s): ninja 300
i have the area 22, the foot pegs look like they have a breakaway notch in them, confirmed low sided and the foot peg broke off, thinking of these pegs on my votex.
Old January 23rd, 2017, 08:00 AM   #18
T11ravis
Professional Carb Cleaner
T11ravis's Avatar
Motorcycle(s): EX250, CRF 150, CRF 100(x2), CRF70
Old thread revival...
Question for all the guys running OEM rearsets on track, any grip issues with the rubber pegs?
We race in the wet quite a bit down here.
WERA #13
T11ravis is offline   Reply With Quote
Old January 24th, 2017, 08:47 AM   #19
Mechanikrazy
Mechanikrazy's Avatar
Motorcycle(s): Thruxton R, R6 450 triple, EX300 (sold)
The 300s are a bit different as they have regular metal pegs instead of the 250 rubber.
I thought the pegs were fine, but not as grippy as I would want. I ended up replacing just the peg on the rear set with PSR SBK pegs, and have been really happy with them.
https://www.revzilla.com/motorcycle/...tpegs-kawasaki
Mechanikrazy is offline   Reply With Quote
Old January 24th, 2017, 09:01 AM   #20
T11ravis
T11ravis's Avatar
Good idea. I have a few sets of pegs laying around, should be able to retrofit a pair on there.
WERA #13
