Old August 28th, 2016, 12:44 PM   #1
Ballardst
Motorcycle(s): '08 Ninja 250
Bike stalls out instead of starting
A couple of months ago, my bike started stalling out around 3,000 rpm. It was almost as if it had become super cold blooded. I brought it to the shop where they professionally cleaned and rebuilt the carbs. I got the bike back about a month ago and it rode fine. I let it sit for about 2-3 weeks with a little more than the recommended amount of Stabil in the tank, and the tank half full (I wasn't expecting to take so long before I could get back to it). I had run the bike for a while after putting the Stabil in, so it got through the carbs. Now the problem came back. Even with full choke it stalls out at 3,000 rpm. I let it idle for a while and it got up to almost 5,000 rpm, but that's it. Any thoughts? Would running some seafoam help?
Edit: I've had the bike for about a year and a half, and usually ride it about every other week. So, it's not uncommon for it to go this long between rides and it's been fine before. I mean, the jets eventually clogged, but it took a whole year of it building up before it was a problem last time so I don't know why it would stop working right away this time.
Ballardst is offline   Reply With Quote
Old August 28th, 2016, 01:04 PM   #2
cuong-nutz
cuong-nutz's Avatar
Even when you try to Rev past 3k it stalls? Does it idle fine?
HalfFast Racing Team
Old August 28th, 2016, 01:20 PM   #3
Have you asked the shop if they'd help you out?
Old August 28th, 2016, 01:40 PM   #4
Ballardst
I discovered the problem today and the shop is closed until Tuesday.
It idles OK, but when I put on the throttle more than a tiny bit it stalls out. It feels like I'm trying to start it in winter without the choke.
Old August 28th, 2016, 03:05 PM   #5
Do you have a fuel filter between the tank and carbs? It's kinda sounding like dirt/rust/sand is getting into the clean carbs and clogging things.
Old August 28th, 2016, 08:55 PM   #6
daverdfw
Motorcycle(s): 2009 Ninja 250
friend of mine's bike was doing this and he had a clogged pilot jet. Maybe try some sea foam first?
daverdfw is offline   Reply With Quote
Old August 31st, 2016, 07:10 AM   #7
Ballardst
I have not added one and I doubt the previous owner did. Is this an aftermarket addition I should do?
Old August 31st, 2016, 07:53 AM   #8
I like to have a small paper element fuel filter between the tank and carbs on all my motorcycles. Eventually I see little pieces of dirt through the clear plastic, and I'm glad it's there.
Old August 31st, 2016, 08:43 AM   #9
I would drain the tank completely and refill before getting into it too deep.
Look for rust in the tank when it's empty. You may need an inline filter if it's rusty.
I'd also drain the floatbowls and catch what comes out so you can see if you have any deposits or water in the system.
Also check the intake snorkel and the air filter.
Old September 27th, 2016, 11:26 AM   #10
Ballardst
It was water in the tanks. Thanks for all the suggestions to look at.
I think my gas cap is leaking water in when it rains. Are there any good aftermarket ones or should I just get a cover?
If I have rust high up in the tank, how weird I even see that? Is there a trick for looking for it?
Old September 27th, 2016, 11:28 AM   #11
A mirror and flashlight would let you see it, for whatever that's worth, but a good pleated paper inline fuel filter will prevent it from doing any harm now or in the future, unless it's so bad it creates a leak.
Bike stalls, rattles, and won't idle properly goldfox 1986 - 2007 Ninja 250R Tech Talk 19 September 3rd, 2015 01:37 PM
Bike stalls when touch throttle Cycy 2008 - 2012 Ninja 250R Tech Talk 31 May 20th, 2013 12:35 AM
Bike not starting.... LoneRonin 2008 - 2012 Ninja 250R Tech Talk 2 April 29th, 2012 07:33 PM
Bike not starting?! nightrider 2008 - 2012 Ninja 250R Tech Talk 32 September 5th, 2011 04:44 PM
Bike is not starting now :( bikermunda 2008 - 2012 Ninja 250R Tech Talk 6 January 3rd, 2010 10:02 PM
