Old September 2nd, 2016, 10:31 PM   #1
xXecuterXx2
ChocolateMilk Addict
xXecuterXx2's Avatar
Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock"
Need a part! Investigators Unite!!
http://faq.ninja250.org/images/6/69/RADIATOR.png
Part 132B coolant pipe bolt, came loose and flew out earlier last night, also sprayed coolant all over my foot and rear tire, ill be back on the road ass soon as i top of my coolant and replace the bolt
Burn Rubber, not your Soul.
xXecuterXx2 is offline   Reply With Quote
Old September 3rd, 2016, 12:43 AM   #2
MrAtom
MOTM - July '15
I'm not sure what you want. You know what part you need. You want us to google and find the part for you? You can do that yourself.
Are you posting because you want that part? Post in Items Wanted.
Asking for a more detailed explanation as to the cause of why that bolt came loose? That's fair. Just be a little more specific.
Old September 3rd, 2016, 12:58 AM   #3
xXecuterXx2
Of course i've searched for it, with no luck. All i was meaning to do is get help locating a place to purchase one from people who know their way around the internet a little better. Thought that would've been obvious being that that is a semi-vital part.
Old September 3rd, 2016, 04:38 AM   #4
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
According to the OEM parts list, that's a generic, small flanged bolt, likely a 6mm (i.e. takes a 10mm wrench). The parts list doesn't specify.
It can easily be replaced by a same-size metric bolt from the hardware store. If a flanged bolt cannot be found, just use a regular bolt and a washer. Use Loctite to keep the loss from happening again.
Frankly, you could probably just use a zip tie or some safety wire and be fine. This is not a critical, highly stressed fastener.
If you must have OEM, though...
Try Googling "OEM Kawasaki Parts". You'll get a lot of online retailers.
Here's one: http://www.cheapcycleparts.com/oempa...906c4/radiator
You'll note that the bolt is $1.99. The shipping will probably be several times that.
Seems kind of silly to me.
How about visiting your local dealer? No need to make this harder than it has to be.
Old September 3rd, 2016, 07:12 AM   #5
You can find that bolt in Home Depot and Pep Boys, at least.
Both have drawers identified with the size that they contain.
Look for regular steel, the type of head (hex or Allen) is non-important.
A flat washer wold help if you cannot find the flanged type in that size, or several washers if you cannot find the specific length and have no way to cut it off and then fixing the thread.
Look for M6 x 0.75, which is a metric bolt.
Those are external diameter and pitch of thread in millimeters.
The length of the original is 12 mm, measured from the base (not the top) of the flanged head until the end of the threaded part.
If not flanged type, consider the thickness of the washer and subtract it from the actual length.
When installing it, insert it by hand and feel any resistance that may be caused by damaged thread in the engine (loose bolts sometimes damage the female thread due to vibration) or excessively long new bolt.
If damaged is felt, quit torquing the bolt in and use the proper tap (M6x0.75) to clean the female thread.
Old September 3rd, 2016, 08:07 AM   #6
xXecuterXx2
Thank you guys so very much, i should be back on the road asap! Way to keep another ninja on the road
Old September 6th, 2016, 09:14 PM   #7
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Grumpy much???
1 out of 2 members found this post helpful.
Old September 7th, 2016, 07:55 PM   #8
xXecuterXx2
Originally Posted by JohnnyBravo View Post
Grumpy much???
Read my mind
Old September 7th, 2016, 08:37 PM   #9
JohnnyBravo
sometimes it's just one of those days... We all have them
[roadracingworld.com] - CCS Racing On Hold At VIR While Federal Investigators Work Pl Ninjette Newsbot Motorcycling News 0 September 20th, 2014 09:20 AM
Speedreaders Unite Alex Off-Topic 7 February 4th, 2014 09:31 AM
[motorcyclenews.com - news] - Adventurers unite at HUBB UK Ninjette Newsbot Motorcycling News 0 April 25th, 2013 02:50 AM
101st ABN Ninja's unite Bushmaster11B Group Rides and Local Events 4 July 25th, 2011 09:19 PM
Squids Unite! Flashmonkey General Motorcycling Discussion 28 October 6th, 2010 06:13 PM
