September 9th, 2016, 03:30 AM | #1 |
Join Date: Dec 2015 Motorcycle(s): 2008 NINJA 250R Posts: 14
spluttering at 9000RPM
hey all, ill be as detailed as i can but its been a while since I've done my carbs....
I've got an 08 250r with an adjustable danmoto slip on, K&N in box and some random jet kit from eBay (somewhere in US) and NGK iridium plugs CR8EIX (new). after not riding for about 7 months and doing carb work in that time (jetting, cleaning even though they were spotless), i hopped back on the bike and all was sweet, she was full of toque down low, good smooth power, which is what i need because its the commuter (never rev too high in the suburbs, too loud). then i took it up a famous country road where i am and as soon as i hit 8.6k to 9k it almost feels like its misfiring for about 1k RPM its not bogging badly, just little splutters here and there but there's less pull over 9k although it does get to redline if i keep it pinned. I've also tested it in different situations, hot, cold, morning, night, all besides when the engine is cold. I've ran it on 91 95 and 98 octane with no change. and yes I'm in Australia. i found this layout (could be helpful) in the carb database but i couldn't find any info relating to me. YEAR: 2008 INTAKE MODIFICATIONS: no snorkel K&N in stock box EXHAUST MODIFICATIONS: adjustable danmoto carbon GP slip-on, stock headers BRAND OF JET KIT? unknown, uses Keihin numbers MAIN JET: 102.5 NEEDLE AND CLIP POSITION: stock needle 3 shims ea. MIXTURE SCREW SETTINGS: 2.5 or 3 (cant remember) ELEVATION: 0-2300 MISCELLANEOUS INFORMATION ABOUT YOUR BIKE’S JETTING SETUP: slide drilled (cant remember size of drill bit) i was also supplied with pilots but again i cant remember the size. 48 comes to mind for some reason... i also changed the sprockets to +1 front and back although that wouldn't make a difference. any ideas would help a lot as I'm not heavily educated in this dept. Last futzed with by rahnos18; September 9th, 2016 at 05:31 AM. |
September 9th, 2016, 05:25 AM | #2 |
I would check each electrical connector along the ignition system.
It seems related to one frequency of vibration.
September 9th, 2016, 05:41 AM | #3 | |
thanks! |
September 9th, 2016, 08:04 AM | #4 |
I think you may be too rich on the Main. I would take it down a size or 2 and see if that cures it.
Find a shop in the area that stocks Keihin OEM jets, and use those. A Keihin jet will have a "K" logo stamped before the number. Anything else is a pain. 3 shims on the needle may be too much with the stock airbox. Make absolutely sure the gas is fresh (and there is no condensation in the tank) and use the recommended octane for best performance. |
September 9th, 2016, 07:08 PM | #5 | |
quick update, ive found my jet kit. its from 6sigma and they use keihin (same k as stock 98s i pulled out) they supplied 102.5 (installed) 105 and 107.5 so ill have to hunt around because im thinking bike shops around here wont stock them, this area is sh*t for bike supplies... ill strip it down and go though the ignition system and go -1 on the shims tomorrow and report back Last futzed with by rahnos18; September 9th, 2016 at 09:18 PM. Reason: additional info pilot jets are 40 |
September 11th, 2016, 02:36 AM | #6 |
fixed!!! sort of... nearly.
ok, so i stripped it down, pulled the carbs to make sure it was all clean inside (it was), removed a shim each carb. checked from spark plugs to coil pack, there was a slight bit of corrosion on a connector of the right coil pack, sanded it back and put the bike back together and went for a ride.
gave it a little squirt when it was still a bit cold and no problems revved right through to 10k nice and smooth, rode like a nanna until i got up to the hills so it was nice and hot and gave it a bit more 4k to 13k smooth as a babys bum! rode pretty hard for a while (not too hard, public roads and all) and it started to splutter again, but not constantly like it did before. maybe once in every 20 times i hit 9k, very twisty, lots of gear changes. i also found out my slide springs are cut, i have no idea how many rings were cut but it doesn't look like many, there's still quite a bit of pressure on the slide. so I'm not sure what did it but something worked! maybe a mixture of the two... are there any other ideas that don't include dropping a jet size? I'd like to keep the 102.5s if i can. but if there's nothing left i will. |
September 13th, 2016, 05:29 AM | #7 |
Join Date: Dec 2015 Motorcycle(s): 2008 Ninja 250 Posts: 210
You could add more air to compensate for the extra fuel the 102.5 is allowing (not sure how you would do that other than drilling some holes in the airbox or getting pods). I suggest 100 mains. I know you just said you wanted to keep the 102.5's but I had the same problem with my 102.5 mains only it was in the 10-11.5k range. Switched to 100 mains and I was impressed by how much smoother the power came on after 9k till redline. My fuel economy received a slight bump too, although it was probably negated by my newly found heavy right hand...
September 13th, 2016, 07:05 AM | #8 |
downsizing jets is looking like my only option, I was hoping to smooth out the power without dropping a jet size. because of my long gears (mostly hwy riding), I wanted more juice there for the weekends, oh well I'll start looking in to who stocks jets, near me. if there's any ideas that haven't been mentioned, let me know please guys!
thanks for the replys! |
September 13th, 2016, 08:56 AM | #9 |
Vintage Screwball
MOTM - Mar '16
Most likely your main jet is actually too small. With the K&N and a slip on, you need to go richer. If you're sputtering at high RPM's, this is an even greater sign.
If it were me, I'd try a 105 or a 108 and see if it's better. If the jets use Keihin numbers, the 48 pilot is too big. Stock is 38 so I'd go with a 40 or maybe 42.
Goin' fast on slow bikes! |
September 13th, 2016, 09:08 AM | #10 |
oh ok, well seeing as I already have 105s I might chuck them in,and see what happens, if I do have to go down in size the bike will tell me straight away.
pilots are 40, I did a little edit thing but it didn't pop up... |
September 13th, 2016, 09:15 AM | #11 |
You should be able to move the enricher (starter) lever when the problem is happening, and add a little extra fuel. If the problem gets worse, you're already too rich. If it gets better, you're too lean.
I know this works with plain Mikuni round slide carbs, so I assume it would work with these. |
September 13th, 2016, 09:15 AM | #12 | |
Vintage Screwball
MOTM - Mar '16
You have a much better flowing air filter and a freely flowing exhaust. One jet size over stock isn't sufficient....which is what the 100 jet is. Stock is 98. Pregens with dual exhaust came with a 105 main from the factory, if that tells you anything. This has to deal with pregens in regards to jet sizes but....the principal of tuning remains. Notice the High RPM stuttering is cause by a lean condition. Same as you have........ http://faq.ninja250.org/wiki/How_to_...e_your_jetting
September 13th, 2016, 09:22 AM | #13 | |
Our Ninja Beater is running pods and a leaky stock exhaust with 108 Mains - which seems right on at around 1000 ft and temps in the mid 80s. With the stock airbox and a K&N, I was thinking he is too big on the Main at 102.5. I usually see sputtering and popping as too rich, and flat-running or bogging as too lean, but we'll see. |
September 13th, 2016, 09:47 AM | #14 |
Vintage Screwball
MOTM - Mar '16
Since there isn't any relevant info in the jetting database thread for newgens other than pod filters, maybe after the last track day of the season Friday I'll tear my carbs down and see what the jets are. They should be looked at anyway and cleaned out/dried for the winter.
It has stock airbox, no snorkel, K&N filter and a pipe. Dyno sheet shows it dead nuts on the money. I'm betting it doesn't have 100 mains in it. Then again, the OP is using a random Ebay carb jet kit. Who knows what the numbers actually are in relation to jet size.
September 13th, 2016, 03:30 PM | #15 | |
can't multiquote on my phone... stupid phone. @Triple Jim: You should be able to move the enricher (starter) lever when the problem is happening ok I'll give this a go tonight, I'll warm it up to avg running temp, approx 70c, and pull the choke on a bit and see what it does, although it's not doing it as often as before so I'll have to test over 15-20 mins. might check the plugs again too, may have changed color, @RacinNinja. kit is keilhin. confirmed with brand "K" stamped on all jets. |
September 13th, 2016, 03:36 PM | #16 |
The enrichers aren't very effective with the throttle wide open, so you may have to pull it all the way to see much difference.
September 13th, 2016, 03:40 PM | #17 |
ok, I'll try it in stages and let you guys know, might give a hint as to how lean it may be.
September 16th, 2016, 10:19 PM | #18 | |
because it is now very intermittent, its impossible to know when its going to happen next and i don't really want to ride around with my choke all the way on for (potentially) an hour. i took the bike out last night and did a bunch of 3rd gear pulls and all was fine. so i didn't use the choke then as there was no need to, i might just have to chuck another size in there and see what happens. do you guys think its possible to swap jets without pulling the carbs? i doubt it but thought id ask... |
September 17th, 2016, 04:47 AM | #19 |
It is possible but might be more of a pain in the behind than just pulling the carbs and swapping them.
Never tried it but you could remove the starter temporarily to give you a little more room to work with the carbs still in. Just a thought.. |
September 17th, 2016, 06:26 AM | #20 |
It's definitely hard to find an intermittent problem. The enricher lever idea is just a quick thing you do when you're actually having the misfiring. As you said, you don't want to ride around with it that way for any length of time.
September 17th, 2016, 03:58 PM | #21 |
Join Date: Jul 2011 Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636 Posts: 661
You can change the jets without removing the carbs if you have a right angle adapter. It is still a tight fit, and can be a pain in the ass.
September 17th, 2016, 11:41 PM | #22 | |||
JET SWAP IT IS!!! |
