Old February 1st, 2017, 07:05 PM   #1
howlinhoss
Motorcycle(s): Ninja 300
N300 Speedometer Relocation
Going to remove the black shroud that holds the speedometer. Looking for ideas on how to relocate the speedometer. Has anyone done this or made a custom bracket to relocate the speedometer?
howlinhoss is offline   Reply With Quote
Old February 1st, 2017, 08:23 PM   #2
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I literally just did this today, dropped ~5lbs from the bike
A 300 racer in pa is making fairing stays for 300s if you're interested. It holds the gauge cluster in its original spot
Old February 2nd, 2017, 04:30 PM   #3
GregS
Motorcycle(s): Ninja 300, GSXR-750, Ducati M1100
Price?
GregS is offline   Reply With Quote
Old February 2nd, 2017, 08:30 PM   #4
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
$150-200 range. It's a custom fabrication from a stand up guy who knows what he's doing.
Old February 3rd, 2017, 08:08 AM   #5
jrshooter
Motorcycle(s): ninja 300
i removed the black shroud and rivited a alum plate to the stay,
it lowers the guage cluster made plenty of room to lower clip ons.
much like wirlybirds on the 300 forum.
Old April 9th, 2017, 11:44 PM   #6
Burphel
Burphel's Avatar
Motorcycle(s): Triumph Bonneville, Ninja 300
Relocating the instrument cluster can be done with zip-ties. After you pull the cowl, put the screws and fender washers that held it on back into the cluster. Maybe use some RTV or super glue to keep 'em there. Then loop zip-ties between those posts and the stock fairing stay loosely. Tighten progressively until you're happy with the position. It'll still move a bit if you bump it, but not enough to notice. If your tech is super strict, it probably could be done with safety wire instead.
Not the greatest picture, but it shows the end result:
I've also since relocated the key switch to the middle bar on the stock fairing bracket (also with zip-ties until I get around to eliminating it). This takes a bit of weight off the yoke and cleans up wire/cable/tube routing immensely. I've also removed the bottom bar and side brackets with an angle grinder. I'm sure somebody makes a fancy race-specific one, but this is cheap and shaves a few ounces off.
I'll try to get a better picture after work.
Let he who has never re-used a crush washer cast the first stone...
Burphel is offline   Reply With Quote
I don't know where to locate, it's N250 vs. N300 Somchai 2008 - 2012 Ninja 250R Tech Talk 2 December 9th, 2015 04:49 AM
Choke Cable Relocation/shortening? GregEvans 1986 - 2007 Ninja 250R Tech Talk 2 October 15th, 2015 06:54 PM
N300, most boring crash video eva subxero Videos 10 November 15th, 2014 10:03 AM
footpeg relocation weaselone 2008 - 2012 Ninja 250R Tech Talk 4 May 21st, 2011 06:10 AM
Relocation of The Rear Brake Reservoir (Pics) ladyrocket 2008 - 2012 Ninja 250R Tech Talk 12 May 16th, 2011 09:41 PM
