Old February 24th, 2017, 10:00 AM   #1
Seanr97
Motorcycle(s): 2008 Kawasaki ninja 250
Help needed
Hello, I am new to this whole thing and I have had my 2008 ninja 250 for 2 years now and never any problems whatsoever. However yesterday I was riding on the highway and I noticed that after about a few miles that the bike had began to lose speed. Going from 75-70-65-60 etc. I had to pull over to the side of the highway and when I got to a stop, tried turning the bike off and starting it up again, which it did without a fuss. But when I went to put it in gear and start riding again, it wouldn't catch. It moved no more than 5 mph and I was cranking the throttle to see if the bike would catch and nothing (same as when you rev the bike in neutral). Like I said, I have never had any problems with the bike before and am curious what happened and if it would e as easy fix or not. Thank you all for the responses.
Seanr97 is offline   Reply With Quote
Old February 24th, 2017, 11:17 AM   #2
walty87
walty87's Avatar
Motorcycle(s): 2012 ninja 250
Wore out clutch?
walty87 is offline   Reply With Quote
Old February 24th, 2017, 12:02 PM   #3
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
Have you just worked on it? Might be a dragging clutch cable, because it needs lubed or (if you've just worked on it) cable routed wrong.
Old February 25th, 2017, 01:09 PM   #4
Seanr97
I have not worked on it. I am looking around and what I am finding is that the general consensus believes that this type of problem is the clutch is bad? I have no idea but if it is what is the best way to fix it? A shop said it would be between 300-400 to fix...
Old February 25th, 2017, 03:11 PM   #5
Welcome, Sean !!!
Normally, clutches do not fail suddenly during a trip, but gradually over time.
Did you noticed what happened with the rpm's indicated by the tachometer while the bike was slowing down?
As advised above, check that the clutch cable is fully releasing the little lever by the right side of the engine.
http://faq.ninja250.org/wiki/Lubing_the_cables
http://faq.ninja250.org/wiki/Adjusting_the_clutch_cable
Old February 25th, 2017, 05:39 PM   #6
Seanr97
The RPMs were still high as I was trying to give it more power, as it was slowing the rpms stayed high as I had the throttle down
Old February 25th, 2017, 05:59 PM   #7
Seanr97
And I just went down to check if the level is being fully released and it looks to be fully released...just took it for a little spin in the parking garage and there is very minimal power
Old February 25th, 2017, 06:29 PM   #8
Then, it may be time to change the oil or refurbish the clutch.
I would change the oil first, if the level is too low or too high and the color is too dark.
Old February 27th, 2017, 08:59 AM   #9
Seanr97
I checked the oil and it does seem to be dark...and a bit high as well. But can that really have the bike running that poorly??
Old February 27th, 2017, 10:19 AM   #10
Are you saying that the engine RPM was high, that the clutch lever was released, and you weren't moving very fast? As in the clutch was slipping terribly?
Old February 27th, 2017, 10:52 AM   #11
A bit high may mean that the oil has been contaminated with condensation, coolant or gasoline; however, it could have been high all the time since you started riding.
Oil with anti-friction additives may be another cause:
http://faq.ninja250.org/wiki/Preferred_Brands
But again, those causes would have deteriorate the clutch performance slowly over time.
Sudden causes could be broken springs or frozen clutch cable that gives no slack to the lever that I asked you to check previously.
Item needed larry502 Items Wanted 6 March 21st, 2014 10:02 AM
Parts Needed Please Help lastcyclone Items Wanted 24 January 25th, 2013 05:08 AM
We go where we are needed. NathanUc General Motorcycling Discussion 37 January 23rd, 2012 06:15 PM
Needed a Cape!!!! csmith12 General Motorcycling Discussion 10 August 1st, 2011 02:13 PM
suggestions needed tinng321 2008 - 2012 Ninja 250R Farkles 6 June 4th, 2009 01:21 PM
