Old April 20th, 2017, 06:45 AM   #1
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
'08-12 Hotbodies Tail mounting?
Hey how do you guys have your racing tail sections secured? Are you just using bolts at the lower L/R corners? I'm sorta thinking of adding nutplates so I can put in a couple bolts upwards into the tail where the 4 holes are that would hold the inner fender to the frame using the stock parts.
Dave Wolfe is offline   Reply With Quote
Old April 20th, 2017, 07:22 AM   #2
Floki
Motorcycle Nurse?
Floki's Avatar
Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100
I zip tied mine where the fender mounted, and bolted the two lower holes. Albeit I had plastics from south america that were trash and didn't line up at all.
Floki is offline   Reply With Quote
Old April 20th, 2017, 09:40 AM   #3
Zaph42
Zaph42's Avatar
On most of my bikes with cheap race fairings, (Hotbodies, Motofairings Inc from Peru, Catalyst, etc) I usually form something up by hand using aluminum flat stock. Then mark hole locations, drill and tap. Most of these cheapies don't have secondary mounts in back, and if they do, they aren't even close to lining up. Aluminum flat stock, a vice and a rubber hammer is always my friend.
Old April 20th, 2017, 09:59 AM   #4
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Not Ninjette-specific, but zipties are the way to go in general. I have as many zipties holding my R6 race bodywork on as bolts. My tail is entirely ziptied. The undersplash has Dzus, mostly because the battery charger lead is tucked in there.
The big advantages:
- They don't get loose
- They allow for simpler mounting, because you can ziptie to anything convenient.
- You have countless spares available, so you need not worry about losing or mangling one.
Old April 20th, 2017, 10:24 AM   #5
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Thx guys
I think I have a plan. Ill just need some bubblegum and duct tape and maybe some tannerite..
Old April 20th, 2017, 11:25 AM   #6
Bob2010
Bob2010's Avatar
I don't remember having an issue. I did have to use rubber insulators as shims under the rear rails
2010 Red Ninja 250
2009 Black Ninja 250
Old April 20th, 2017, 05:27 PM   #7
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
the 2 bolts on the under part then one zip tie on each side under/next to seat.
TEAM ALFALFA
www.apexassassins.com
FS: 08+ Ninja 250 Hotbodies tail abhijitz Motorcycle-related 0 July 12th, 2016 11:13 PM
Targa vs Hotbodies Tail kit? 5evenz 2008 - 2012 Ninja 250R Farkles 7 July 24th, 2011 08:33 PM
