Old May 8th, 2017, 11:26 AM   #1
GeicoGecko
Motorcycle(s): EX300B, TL1000R, R6, GSXR1000
PowerCommander 5 (PC5) - Coolant Temp and Speed/Gear Setup
Hey guys,
I couldn't find any information regarding the calibration of the speed sensor (for gears) or the engine coolant setup (if you've wired these into your PC5). Below is what I've calculated and been using. The temp isn't perfect between 23C-40C but it's good enough and displays well on the POD-300
This is on a 2016, I'm not familiar using change in the family. Oh it's also stock gearing. I can calculate the values if you're using other gears (or you can just do the recommended cal).
Gearing (Menu: Power Commander Tools->Calibrate->Gear Calibration)
1 - 450 to 310
2 - 250 to 210
3 - 190 to 155
4 - 150 to 140
5 - 130 to 117
6 - 112 to 100
Engine Coolant Temperature (Menu: Power Commander Tools->Configure Engine Temperature Input)
Source: Analog Voltage
Table Size: 5
Voltage - Temp
4.601 = -20.0
4.003 = 0.0
3.150 = 23.0
2.053 = 40.0
0.435 = 100.0
To see how close yours is, the fan should turn on at 103 and turn off at 98.
Hopefully this helps someone!
GeicoGecko is offline   Reply With Quote
Difference between these two PC5's ? Jason5885 2008 - 2012 Ninja 250R Tech Talk 7 January 16th, 2015 09:32 AM
Any DIY's on fitting a PC5 to my ninja 250 ? Jason5885 2008 - 2012 Ninja 250R Tech Talk 3 December 2nd, 2014 08:24 AM
oil temp vs coolant temp cuong-nutz General Motorcycling Discussion 11 January 23rd, 2013 05:44 PM
Shift Light, Gear Indicator, Temp Gauge - WHERE ARE YOU???!!! 2013 kawi girl 2013 - 2017 Ninja 300 General Discussion 14 October 21st, 2012 12:00 AM
How to test coolant temp sensor? Togglehead 1986 - 2007 Ninja 250R Tech Talk 1 July 21st, 2010 03:50 PM
