Old May 10th, 2017, 07:42 AM   #1
T0A0C
Motorcycle(s): Nothing that runs yet!
Minimum electronics to run the engine.
Hi Guys,
Im in the process of fitting a 250 engine into a chinese bike which had blown the final drive. What are the minimum components I need to get running.
I have the following so far:
Engine from a 2011 bike
Wiring loom
CDI
Junction box/relay box? (Part with 3 plugs)
Fuse box (part of loom)
Throttle bodies with 3 sensors/plugs & injectors
Lambda remove plug
Fuel pump/tank
Upright sensor
Starter
Regulator
Im hoping I can use the starter solenoid and coilpacks off the original engine but will have to check fit.
Will this be enough to get it running?
Any help much appreciated.
Thanks
Tom
T0A0C is offline   Reply With Quote
Old May 13th, 2017, 05:12 PM   #2
Vintage Smoke
The 2 Stroke Ninja!!
Vintage Smoke's Avatar
Motorcycle(s): 2010 250R, 1977 RD400, 72&73 RD350 75 RD200
I have been here. While it is a different application, I have put a Yamaha Banshee motor in my Ninja and needed to figure out the wiring. I would recommend that you get a good copy of the factory diagram and start studying it. There is a TON of stuff that is cross connected. Relays, switches, individual components, etc. Removing one part affects the operation of another. It's more than just small things like the sidestand switch too. If you are real sharp with motorcycle wiring you should be able to figure it out, but if you look at the diagram and your head spins, you may wind up chasing electrical gremlins forever.
Vintage Smoke is offline   Reply With Quote
Old May 15th, 2017, 11:18 AM   #3
T0A0C
Thanks for the reply. I think I've got it now. I finally managed to track down the UK wiring diagram with fuel injection and it makes pretty good sense. I was going to splice the standard speedo but have decided to get a set of ninja dials to make it a lot easier.
[motogp.com] - Brivio says electronics and engine performance are focal points for Su Ninjette Newsbot Motorcycling News 0 October 1st, 2014 02:00 AM
[kropotkin thinks...] - Ducati Completes Test At Mugello - Electronics, Engine And Sw Ninjette Newsbot Motorcycling News 0 May 24th, 2012 11:20 AM
[kropotkin thinks...] - Casey Stoner On Electronics, Ducati's Screamer And Engine Pen Ninjette Newsbot Motorcycling News 0 November 2nd, 2010 04:30 PM
[crash.net - MotoGP] - Rossi tests 'long life' engine, electronics and tyres. Ninjette Newsbot Motorcycling News 0 June 15th, 2009 01:00 PM
[kropotkin thinks...] - Pedrosa To Run Pneumatic Valve Engine At Indy Ninjette Newsbot Motorcycling News 0 September 5th, 2008 05:24 PM
