Old June 5th, 2017, 11:32 PM   #1
tap_rack_bacon
Motorcycle(s): ninja 250, ninja 650
Bike won't start
My 09' 250 has been sitting at my parents house outside for the past 5 years and I finally was able to go out there and pick it up. Lots of problems going on but I stripped it down, cleaned it, stripped and cleaned the carbs, new fitters, etc... I got it back together and put a new battery in and when I turned the key, only the engine light and oil light came on, no fuel pump noise and when I push the stater nothing happens. I checked all the fuses and they were good.
tap_rack_bacon is offline   Reply With Quote
Old June 6th, 2017, 06:15 AM   #2
bob706
bob706's Avatar
check starter switch and battery connections. may be corroded
http://sandollarmotorcycleclub.com/
Old June 6th, 2017, 06:28 AM   #3
If the lights don't dim or go out completely (indicating a weak battery) when you hit the starter button it sounds like a safety switch is stopping it from cranking - https://faq.ninja250.org/wiki/Unders...afety_switches
Old June 6th, 2017, 02:21 PM   #4
Yeah, make sure it's:
1. in neutral
2. kickstand is down
3. clutch lever pulled in
Old June 9th, 2017, 10:57 PM   #5
tap_rack_bacon
well first off i'm retarded. The 250 is a vacuum fed carb so no fuel pump. smh. It turns out it was the clutch switch not fully engaging/disengaging. Bypassed the switch and the button works. My petcock leaks like crazy from the little pin hole in the bottom of the plastic spacer. Any one know what that hole is and why it is all of a sudden leaking? thanks
Help!!!!!!!! - bike won't start auntymunga 2008 - 2012 Ninja 250R Tech Talk 5 August 18th, 2014 06:54 AM
bike won't start. tried everything rabies 1986 - 2007 Ninja 250R Tech Talk 17 September 22nd, 2013 04:46 AM
Bike won't start chowbray 2008 - 2012 Ninja 250R Tech Talk 20 March 21st, 2011 07:51 PM
bike won't start :/ SephiaSputnik 1986 - 2007 Ninja 250R Tech Talk 20 March 12th, 2010 02:40 PM
