June 30th, 2017, 07:26 PM | #1 |
Join Date: Jun 2017 Motorcycle(s): 2007 Kawasaki Ninja 250R Posts: 30
2007 kawasaki ninja 250r ticking sound
Just got this bike, haven't even taken delivery.
But, I do know there is a "ticking" sound, along with erratic rpms at idle. I will add more as I get the bike and get into it more, I just want to get a head start and am wondering if there are any common problems... |
June 30th, 2017, 07:53 PM | #2 |
Some ticking is perfectly acceptable due to the solid lifters, but odds are it gonna need a valve adjustment, as it's one of the most overlooked items of maintenance. Valves out of adjustment Cam cause running, idling, and performance issues.
As with any used motorcycle assume your gonna need an oil and filter change, flush and fill all fluids, inspect all hoses, brakes, tires etc.... Was the bike sitting for awhile? Storage? Mileage? Was it taken care of? Etc.... You see where I'm going with this. Is this your first bike?
June 30th, 2017, 08:14 PM | #3 | |
Its been garage stored for a few years, last year I took it for a decent ride and it seemed fine. It has 7851 miles. Most of which were previous owner(s?). So I don't really know service history. My first bike was a gsxr600k5 for 6400mi 2nd was a gsxr600k6 for 27k 3rd was a 2009 yamaha r1, only put 1k due to being laid off. 4th was a triumph speed triple 1050, again only 1k on it. Bought it prematurely after getting back to work thinking I could afford it, but it was a little too right for comfort. My next bike hopefully will be an air cooled triumph scrambler, a triumph Bonneville t120, a Honda cb1100 or something similar. This ninjette is just something cheap to scratch the itch for now |
June 30th, 2017, 08:41 PM | #4 |
If your pretty handy, then you can do all the maintenance on the Ninjette, it's a simple bike, old school technology.
I own both a 250 & 500 ninjas, I like the simplicity of them, I've owned a lot bike over my many years, and I've got to admit I love these small parallel twins, I do all my own work on them both. I've found that the best bang for your bucks is suspension upgrade A properly setup Ninjette with a skilled rider and hang with the big bores in the twisties,and even pull away, it's lightness, and nimble will amaze you, once it's dialed in. Kawasaki did a great job squeezing all the HP out of a small engine once you get it up into the power band 8~12.5k rpms, these no large amounts of HP to be unlocked,
July 1st, 2017, 08:53 AM | #5 | |
So, I'm assuming valve adjustments should be done at 15k? This bike has less than 8k, but it's 10 years old. Could valves effect the idle? Assuming the valves aren't the problem, what if the engine is junk? What do replacements run? Any chance of getting a 500c.c in there? I'm assuming it isn't just a plug and play simple task... |
July 1st, 2017, 10:07 AM | #6 |
Valves adjustment definitely affects idle. That's mainly were you notice it... trying to idle with a cold engine. It wants to stall or run at 5,000 rpm. Then when it's hot it seems fine.
July 1st, 2017, 11:37 AM | #7 |
No to the 500,yezit can/has been done but the frame is crap on these bike, like the 500 frame is crap.
Replacement engines got from 300~500 USD, and these engines are pretty tough assuming you keep the full of oil,which is the main cause for failure, you only have 1.9 L of oil, so keep an eye on your oil level always. The other thing I would personally recommend is better clutch springs, the OEM ones are weak IMHO.
July 1st, 2017, 11:43 AM | #8 |
Ghostt, have you had a pregen clutch slip? I have not had mine even come close to slipping with stock springs. An advantage to not going any heavier than necessary with springs is protection of the drive train if a new rider revs the bike and dumps the clutch, for example, or if the chain breaks and jams up the front sprocket.
Not arguing with your suggestion, just wondering. |
July 1st, 2017, 11:47 AM | #9 |
No slip on mine, I did it as a preventative measure, it's bigger brother EX500 with OEM springs does slip at higher rpms slightly, and over time the springs loose there umph.
It's a common upgrade on the EX500, so I just went ahead and did it, I must say it a more positive feel now. If your gonna be rough on the Ninjette, it's just a good idea IMHO.
July 1st, 2017, 11:48 AM | #10 |
http://www.ex-500.com/wiki/index.php...gs_Replacement
I'm just saying the OEM springs are weak, being it an entry level bike, and the upgrade springs are not crazy heavy, just a bit more, I hardly noticed it, and the Ninjette only uses 4 springs. The upgrade springs are made for a ZX600 which uses 5 like the EX500 .
July 1st, 2017, 12:27 PM | #11 |
Thanks Scott. I'll keep an eye on mine and if engagement isn't crisp under high load, I'll know it's getting near time to change them.
I've measured the springs in my 45 year old H2 and they're still well inside the specs, so I'm not sure I'd agree that age weakens them much. It may be more likely that as the friction plates wear thinner, the stack shortens, reducing the amount the springs are compressed, so the spring force on them is reduced. |
July 1st, 2017, 12:52 PM | #12 |
I took it for a spin, it's crazy it redlines near 12, I had it near 8 and it sounded like it was going to blow up.
The brakes aren't super strong, but oh well. |
July 1st, 2017, 01:01 PM | #13 |
My pregen will do a stoppie. If yours won't, you should look into why. Or does it just take more lever force than you're used to?
(use caution with brake tests) |
July 1st, 2017, 01:44 PM | #14 |
July 1st, 2017, 01:53 PM | #15 |
You sure don't need much rear brake on a Ninja 250, but if it's soft, it may need bleeding. The only time I use the rear is in wet weather or gravel.
July 1st, 2017, 02:13 PM | #16 |
What's a pregen
July 1st, 2017, 02:35 PM | #17 |
PreGen is a model 88~07, NewGen is 08 & up.
With my PreGen my brakes were in dire need of repairs, and service, now the brakes are firm, and strong. Most likely the brake fluid need to be flushed, filled, bled with new fluid. I'd also service the calipers as well, also when changing brake pads too. Add the caliper service to the list of things that almost nobody does. A lot of maintenance items don't get done to entry level bikes, due to they chance hands often, as some owners just buy them for short periods of time, and just ride them, sometimes without even doing a simple oil change.
July 1st, 2017, 07:27 PM | #18 |
I'm actually confused as to what year this bike is. The res a stock yellow that has a black lower fairing... And a stock yellow that is all yellow and has orangish flames where this bike has the flowers... But also near the handlebar where it says ninja...
So why/how would those flames be gone? ALSO, the later years of this gen according to Google seem to have flush mount blinkers, not the ones that stick out like the two in this bike... Not that it matters, just curious |
July 2nd, 2017, 07:49 AM | #19 |
I wouldn't go by colors, or graphics, mine is 98 which came red, I changed out the fairings to an 07 silver, then a took off the flames, and added custom graphics.
What does the title/reg of the bike say? Also there should be sticker on the head tube, and of course the VIN.
July 2nd, 2017, 10:09 AM | #20 |
Also flush mounts are an aftermarket item, like mine are.
The ZZR 250 had OEM flush mounts, which is similar to the Ninja 250, but has a different frame, but does look similar, and it's wasn't offered in the US. It's also the yellow bike from Kill Bill Vol. 1 that the bride rode.
July 2nd, 2017, 11:20 AM | #21 |
A sticker on the frame says it's an 06
I THINK the bike was lowered at some point... Can I undo that? Does it look lowered? |
July 2nd, 2017, 11:21 AM | #22 |
Sorry for lying to you guys this whole time saying it's an 07. I'm a poser
July 2nd, 2017, 11:23 AM | #23 | |
Join Date: Mar 2017 Motorcycle(s): 2007 Kawasaki 250 Ninja, 1982 Honda Ascot FT500 Posts: A lot.
Bill |
July 2nd, 2017, 11:27 AM | #24 | |
Bill |
July 2nd, 2017, 11:49 AM | #25 |
If the sticker says it was made in '06, it may be an '07 model. Check the VIN if it matters to you.
July 2nd, 2017, 11:57 AM | #26 |
It doesnt, I was just curious.
July 2nd, 2017, 12:47 PM | #27 |
July 2nd, 2017, 01:38 PM | #28 |
Depends on how well you want to run.
At the very least check the clearances.
July 2nd, 2017, 01:56 PM | #29 |
A lot of the posters will disagree with me but I would buy the Kawasaki special tool for the valve adjustment. I have a difficult time trying to imagine doing the job without it. I think you can pass on the Kawasaki feeler gauges - way too expensive and I didn't even use it. Just an .004" and .005" feeler blade did fine for me.
Bill |
July 2nd, 2017, 02:07 PM | #30 | |
Also doing the CoPs conversation helped too, as it eliminates the need to remove the coils, etc...
July 5th, 2017, 09:32 AM | #31 |
Is this bike bright yellow or chrome yellow?
07 250r ninja Engine ticking | strickcharles5 | 1986 - 2007 Ninja 250R Tech Talk | 5 | May 4th, 2017 08:36 PM |
2009 ninja 250r engine ticking & knocking noise | ubxssangz | 2008 - 2012 Ninja 250R Tech Talk | 47 | January 26th, 2017 12:15 PM |
Engine ticking sound | Nosajong | 2008 - 2012 Ninja 250R Tech Talk | 4 | May 21st, 2013 07:57 PM |
new sound on my ninja 250r | kimolottie_06 | General Motorcycling Discussion | 7 | July 11th, 2012 03:30 PM |
