Old July 9th, 2017, 05:33 AM   #1
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
Ali exhaust header/partial
i bought the el cheapo muffler and i'm thinking of this.
"trying not to get old"
Old July 9th, 2017, 10:14 PM   #2
Wow! That's an amazing deal! Very similar to Yoshimura's RS-5 exhaust for fraction of price. I don't think you can go wrong. Seems like performance exhausts are commodity items nowadays.
I went with Tyga system due to them getting the highest gains on dyno. Looking at charts more closely, most of the gains were actually from leaning out the factory's too-rich WOT top-end. Remember that '60's hot-rod saying?
So you're looking at a +10% bump in power for less than $200 in exhaust, muffler and 2 main-jets! Great hunting and good job!
Last futzed with by DannoXYZ; July 10th, 2017 at 01:25 PM.
Old July 9th, 2017, 10:16 PM   #3
Way to stick it to the Russian mob too! Ahahhahahahhahha!!!!!
Old July 10th, 2017, 05:45 AM   #4
Lazarus
Lazarus's Avatar
Motorcycle(s): 2008 Ninja 250
I have the same setup from a different website and I love it. The slip on fits right onto the stainless headers and sounds really good. I believe the outer diameter of the headers is 54mm and the inner something like 51 or 52mm. Definitely a good idea for an inexpensive full system!
Lazarus is offline   Reply With Quote
Old July 10th, 2017, 05:47 AM   #5
maverick9611
MOTM - Feb '18
thanx for the update. i figured somebody had tried this. do you have a pic by chance?
Old July 10th, 2017, 05:52 AM   #6
Lazarus
Lazarus's Avatar
I don't right now. I can take some when I get home from work if you want? I've put about 6k miles on the setup and it's seen all kinds of weather, it holds up really well.
Old July 10th, 2017, 06:15 AM   #7
maverick9611
MOTM - Feb '18
i'm amazed how they will copy anything and everything.
Old July 10th, 2017, 06:19 AM   #8
maverick9611
MOTM - Feb '18
Old July 10th, 2017, 06:19 AM   #9
maverick9611
MOTM - Feb '18
thank you
Old July 10th, 2017, 10:04 AM   #10
Lazarus
Lazarus's Avatar
http://imgur.com/jnUIBQA
http://imgur.com/APlzmGD
http://imgur.com/Z5kOVRu
http://imgur.com/MQbh7fw
Pardon the dirt and grime. She is my workhorse and I do about 50mi/day and that is just to and from work.
Only complaint I have is in the second picture you can see the slip on doesn't come all the way down the headers to meet the ring on it. It never really bothered me but there is a super small leak because it won't fit snug all the way. I don't have a sound clip, sorry. It's more of an in person thing anyway. I've never seen a video that made an aftermarket ninja exhaust sound good. Lol but that's just my opinion.
Old July 10th, 2017, 10:21 AM   #11
The outside ring actually doesn't do any sealing. The seal is made at the tip of the inside-tube against the flared/conical edge of the outer-tube. This is where production tolerances come into play. Make sure tip of inside-tube is perfectly-round and is cut perfectly square 90-degrees to the tubing axis. Verify outer-tube's flare is perfectly concentric as well. Spring then serves to push inside tube's tip into the flare for sealing.
Old July 10th, 2017, 11:23 AM   #12
Lazarus
Lazarus's Avatar
^^thank you for sharing. I'll have to pull it apart and inspect when I get a chance. I don't expect much from the muffler, you get what you pay for. Sounds nice and I notice slight gains in high rpm with a jet change and tune.
Old July 10th, 2017, 01:32 PM   #13
It also looks like spring isn't pulling exhaust together very tightly, which might be cause of your leak. Each spring should require substantial force to stretch and install. Typically you'll increase length of spring 50-100% longer from resting to installed state. I'd say about 30-40lbs of pull each. You really need an exhaust spring hook tool to stretch and install those springs. Might want to measure distance between loops and replace with spring having 1/2-3/4 that length when contracted. Perhaps something like this ebay - exhaust spring.
Old July 10th, 2017, 01:49 PM   #14
Lazarus
Lazarus's Avatar
I have an extra set of springs in my toolbox. I'll throw them on along with the inspection. I've never had a problem with just using plyers.
Old July 15th, 2017, 04:16 AM   #15
Lazarus
Lazarus's Avatar
Inspected the muffler and end of the headers. Couldnt find anything out of the ordinary, so I put the new springs on and the leaked diminished slightly. Its not of major concern to me really, but the observation and suggested by JacRyann definitely helped.
Thanks again. Ride safe, all
Old July 15th, 2017, 04:33 AM   #16
maverick9611
MOTM - Feb '18
i need to get my spring hoops welded on, i'm using the hose clamp method for now. ( kampymark)
Old July 15th, 2017, 06:25 AM   #17
Interesting el cheapo header. Check out the header from Tyga as well. it's not the prettiest tubing job, but the welds seem decent and the dyno charts look good. Price is right as well.
I got one and it seems to fit okay. Haven't run the bike with it yet though.
Old July 15th, 2017, 01:03 PM   #18
maverick9611
MOTM - Feb '18
thanx for the tip, i got mine back together and just running el cheapo akron knock off slip on from ali. i will get it soon!
Old July 15th, 2017, 01:58 PM   #19
Nice thing about the Tyga header is it has bung for wideband-O2 sensor. Now I just need to convert to EFI for fine-tuning mixtures.
Old August 28th, 2017, 05:19 AM   #20
the-panther
Motorcycle(s): Ninja 250r
Any updates on this header, hows it running? How are the welds holding?
I'm pretty keen to upgrade from the stock headers, i like the larger bore, the lack of cat., the flexibility provided with spring clamps and most importantly; the price!
$$=freed up HP seems good.
(get 'er breathing better, get 'er performing better!) + (jets/AFR)
Any Real world dyno's done?
hows it holding up users?
the-panther is offline   Reply With Quote
Old August 28th, 2017, 08:48 AM   #21
maverick9611
MOTM - Feb '18
on the back burner for awhile, daughter just started college.
Old August 28th, 2017, 09:36 AM   #22
A.J.
A.J.'s Avatar
Motorcycle(s): 2001 Kawasaki Ninja 250r(SOLD) 2006 Kawasaki Ninja 250r full Muzzy(my pride and joy)
These knock offs are ok. Not something I would buy personally. I would just as well keep the stock. Even $150 is a lot of cash might as well hit a HR and go for the real deal because over time you'll know why a true Yoshi, Muzzy, Two Bros. etc is worth the extra coin. JMO though I still find these generic systems interesting just still haven't seen one that holds up well after a few years. Not in comparison to the top aftermarket exhausts.
"A car or truck will get you from point A to B. But a motorcycle, that is the point." -unknown
A.J. is offline   Reply With Quote
Old August 28th, 2017, 12:25 PM   #23
maverick9611
MOTM - Feb '18
the akra ali slip on i got is the real deal. i spent under $50
Old August 28th, 2017, 01:14 PM   #24
You'd be surprized to know where Yoshi, Muzzy, Two Bros. are having their exhausts made... I have a set of genuine Sato rear-sets without the Sato name... made by same factory... before name is added...
That extra $150 doesn't come in during manufacturing process; that's exactly the same, so exact same quality. Inspect tubing, surface finish, welds, etc. You won't be able to tell the difference. That sticker & logo is where the $150 is added.
Old September 6th, 2017, 11:44 AM   #25
maverick9611
MOTM - Feb '18
i ordered it. overtime/double gave me the green light via wifey. price dropped to $147 and $33 to ship. total $180. b here in 20 days.
Old September 6th, 2017, 12:29 PM   #26
Take a picture of wideband-O2 port when installed will ya? My Tyga's positioning of it is vertically right beneath corner of engine. My O2-sensor will end up hitting oil-pan when I install. Going to have to cut off bung, weld-up hole and re-position/rotate bung towards outside a little.
Might be easier and faster to just pick up one of these exhausts.
Old September 6th, 2017, 01:06 PM   #27
maverick9611
MOTM - Feb '18
no problem
Old September 6th, 2017, 01:10 PM   #28
ck.mecha
Motorcycle(s): 1969 Benelli Cobra 125, 1970 Honda CB160, 2009 Kawasaki 250R
Ive got the Tyga on a 250R with wideband O2 installed. You will not have a clearance issue, it will work just fine.
ck.mecha is offline   Reply With Quote
Old September 6th, 2017, 01:33 PM   #29
I got the Tyga and it won't clear my pregen chin fairing.
Old September 12th, 2017, 01:10 PM   #30
maverick9611
MOTM - Feb '18
just arrived. amazed how fast it got here.
6 days!they used dhl shipping. came wrapped very well.
will post more when i get it mounted
Old September 12th, 2017, 01:12 PM   #31
maverick9611
MOTM - Feb '18
Old September 13th, 2017, 07:31 AM   #32
maverick9611
MOTM - Feb '18
i just finished the install. not bad, midpipe tricky, springs do not align but useable. the multi adapter for slip on not needed. used a touch of anti seize on lower header/midpipe connections. i have countersunk m18x1.5 plug coming for the 02 plug. slingshot muffler bracket just fit(it was close)
Old September 13th, 2017, 07:37 AM   #33
maverick9611
MOTM - Feb '18
double o steel wool to clean it up
Old September 25th, 2017, 06:36 AM   #34
the-panther
Thanks for the pics.
Looks like a good little unit, all things considered.
Some of the welds look like they've been done by a talented blind man, but i've seen much worse. Lets hope they hold, but if not its quick and cheap to fix.
How does it go on the road?
Old September 25th, 2017, 06:53 AM   #35
maverick9611
MOTM - Feb '18
it sounds great. i have not put any hard miles on it yet as i’m right in the middle of pod install/carb tuning/ valve check. i’ll keep ya posted. the ali slip on sounds quite louder even with baffle installed. must be flowing pretty good. cheap is cheap. nothing can beat this price.
Old September 25th, 2017, 10:30 AM   #36
heh, heh... looks like combination of manual and robot-welding. Human labour is cheaper than complex machinery. They take pride in that when done in U.S., but results in inconsistent QC and leaky bikes...
Old October 6th, 2017, 12:38 PM   #37
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
any idea on the decibel level that puts out?
TEAM ALFALFA
www.apexassassins.com
Old October 6th, 2017, 02:13 PM   #38
maverick9611
MOTM - Feb '18
i'm apart right now. soon as i get together i will try. heard you can use your cell phone to read decibels. glad i have the baffle in as it's quite louder than stock.
Old October 6th, 2017, 02:19 PM   #39
Same loudness with same muffler between the factory vs. aftermarket exhaust?
Old October 6th, 2017, 02:35 PM   #40
maverick9611
MOTM - Feb '18
no, the header/ midpipe on the el cheapo is noticably louder. not ear piercing but much more than stock.
el cheapo muffler from ali maverick9611 2008 - 2012 Ninja 250R Farkles 14 August 22nd, 2017 08:55 AM
Exhaust header question?? BDfromBC 2013 - 2017 Ninja 300 General Discussion 8 May 28th, 2016 05:47 PM
2 into 1 exhaust header options HoneyBadgerRy 1986 - 2007 Ninja 250R Tech Talk 21 January 11th, 2016 06:45 PM
FS: NEW Area-P exhaust header Momaru Motorcycle-related 6 June 8th, 2011 03:02 PM
Header exhaust gasket B2FiNiTY 2008 - 2012 Ninja 250R Tech Talk 5 May 8th, 2009 08:03 PM
