Old August 1st, 2017, 10:34 PM   #1
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
stick coils
anybody done this mod? when i had my zrx this one was plug in play. i'll look around.
"trying not to get old"
Old August 1st, 2017, 10:36 PM   #2
Ghostt
Ghostt's Avatar
Yup,
https://www.ninjette.org/forums/showthread.php?t=241339
violente et ignorantia
ZX-2R BLOG
Old August 1st, 2017, 10:49 PM   #3
maverick9611
MOTM - Feb '18
most excellent
Old August 2nd, 2017, 10:19 AM   #4
Ralgha
Ralgha's Avatar
I read through that DIY thread, am I correct that it eliminates the mounted ignition coils, they're now built into the plug caps? This would allow removal of the valve cover without removing the engine mount?
bike * miles = smiles
smiles / bike = miles
smiles / miles = bike
Old August 2nd, 2017, 11:00 AM   #5
Ghostt
Ghostt's Avatar
Yes, yes, and yes
ZX-2R BLOG
Old August 2nd, 2017, 11:18 AM   #6
This would come in handy with high-compression upgrade. Denser mixture is more difficult to ignite and having some extra spark-energy can't hurt.
Old August 2nd, 2017, 12:14 PM   #7
maverick9611
MOTM - Feb '18
let da mods begin!
i told my wife i wouldn't do it anymore!
stock zrx left, after i was done
Old August 7th, 2017, 12:44 PM   #8
maverick9611
MOTM - Feb '18
Originally Posted by Ghostt View Post
Yes, yes, and yes
just picked up a harness and stick coils. can't wait!
Old August 7th, 2017, 06:18 PM   #9
Ghostt
Ghostt's Avatar
Don't forget to open the spark gap a little to take advantage of the hotter coils.
ZX-2R BLOG
Old August 7th, 2017, 09:20 PM   #10
maverick9611
MOTM - Feb '18
can you recommend spark plugs? I've used denso iridium in the past.
Last futzed with by maverick9611; August 12th, 2017 at 05:07 AM.
Old August 7th, 2017, 10:08 PM   #11
Ghostt
Ghostt's Avatar
Good enough, I use NGK iridium just open the gap up to. 028~.032 I run both of mine at. 032
ZX-2R BLOG
Old August 8th, 2017, 06:47 AM   #12
maverick9611
MOTM - Feb '18
what is the part # of the plug you use?
Old August 8th, 2017, 09:04 AM   #13
Ghostt
Ghostt's Avatar
NGK (7669) CR8HIX Iridium IX Spark Plug, Pack of 1
https://www.amazon.com/dp/B000HDF852..._D8DIzb27VN53A
keep in mind I have a PreGen, a NewGen calls for a different plug.
IIRC, but double check to be sure, I know that PreGen take a small thread size, as the NewGen use big threads
NGK (4218) CR8EIX Iridium IX Spark Plug, Pack of 1
https://www.amazon.com/dp/B000VZJ712..._bkEIzbAC9CCWV
ZX-2R BLOG
Old August 8th, 2017, 09:19 AM   #14
Those be some pricey plugs...
Old August 8th, 2017, 09:26 AM   #15
Ghostt
Ghostt's Avatar
Yes they are but you only have 2, if you foul one your not in good shape, hence why I use the iridium plugs, and they do last longer, and it's only 2 plugs your buying, not 4
also avoid using certain brands as they don't work well in the Ninjette
https://faq.ninja250.org/wiki/Changi...rands_to_avoid
ZX-2R BLOG
Old August 16th, 2017, 04:41 AM   #16
maverick9611
MOTM - Feb '18
got them in and will start building them up.
Old September 6th, 2017, 02:39 PM   #17
maverick9611
MOTM - Feb '18
i made my own covers as the 08 didn't have the spark plug well covers. super simple mod.
Old November 29th, 2017, 06:33 AM   #18
maverick9611
MOTM - Feb '18
plug i used. $8.55 on amazon.
Takai Coils Racer x 2008 - 2012 Ninja 250R Tech Talk 33 February 25th, 2018 08:50 PM
Are the ignition coils grounded? Fishbine 2008 - 2012 Ninja 250R Tech Talk 16 April 18th, 2016 03:44 PM
How To Bench Test Ignition Coils? ithaca00 2008 - 2012 Ninja 250R Tech Talk 8 April 5th, 2015 10:09 PM
Do you drive stick? jonthechron General Motorcycling Discussion 70 December 14th, 2011 01:10 PM
I really need to stick with it Apex Off-Topic 6 November 9th, 2011 05:05 PM
