Old September 24th, 2017, 08:58 PM   #1
Abu_Mishary
The Asian Caucasian
Abu_Mishary's Avatar
Name: Abu Mishary Mohd Fairus
Motorcycle(s): Kawasaki Ninja 250 SE 2015 (sold); Honda ADV160 (current)
MOTM - Jan '17
shift linkage extension
Hello. I am looking for a "shift linkage extension", 2nd hand / used / pre-owned. Kindly name ur price + international shipping to Malaysia. Payment is via paypal.
Losing someone is not painful. They are a part of us all this while and will always be with us. But missing them is.
Abu_Mishary is offline   Reply With Quote
Old September 25th, 2017, 10:48 AM   #2
You mean a longer rod? How much longer you need?
Old September 25th, 2017, 06:25 PM   #3
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
About an inch or two
Old September 25th, 2017, 07:04 PM   #4
Hmmm, one time I didn't have time to wait for stuff to come in due to race that weekend. What I did was just cut head off 20mm bolt and welded threaded section to existing rod.
Eventually these showed up. Both ends were right-hand threads, but once adjusted to proper length, no need to change. So no big deal. Got two complete sets of rods + ends for about U$D 8.50 each. One set on bike and spare in toolbox.
http://www.ebay.com/itm/172252462236
http://www.ebay.com/itm/352063383949
I was able to actually help guy in Expert 250 class who blew up his R3's engine on Sat. and needed bike on Sunday. He bought used N250R from another racer and needed to replace shift-rod. Luckily, I just happen to have one he could use for Sunday's race.
Last futzed with by DannoXYZ; September 25th, 2017 at 09:36 PM.
Old September 25th, 2017, 08:34 PM   #5
Kevin1956
Kevin1956's Avatar
How about cutting it in half and extending it with a piece of tubing and a couple welds?
Kevin1956 is offline   Reply With Quote
Old September 25th, 2017, 08:52 PM   #6
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
Can't find a welding shop here that would take up the job.
Old September 25th, 2017, 08:54 PM   #7
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
Found two brands "Kuryakyn" and "cycle vision" but the shipping cost is absurd. This is not including import tax. If i could find a pre-owned one it can be declared as used item hence the import tax is not imposed.
Old September 25th, 2017, 09:37 PM   #8
gimme a centre-to-centre distance between rod-ends and let me see what I have in my box...
Old September 25th, 2017, 09:40 PM   #9
You may not need to go this route, but sometimes sellers can do better than the web site overseas shipping price if you email them about it.
Old September 25th, 2017, 09:53 PM   #10
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
Okie dokie... I'm at work now, I will get to it once at home. I didn't bring my ninjette with me.
Send a question for the seller to answer about this "special shipment arrangement" but still has not get any reply.
Old September 27th, 2017, 08:19 PM   #11
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
still haven't had the chance to measure. Will do tonite. Sorry.
Old September 27th, 2017, 08:23 PM   #12
MrAtom
MOTM - July '15
I seriously didn't think this was an innocent question until I read your other posts.
Old September 27th, 2017, 08:55 PM   #13
Hey, that extra inch really makes a difference ya know...
Old September 27th, 2017, 11:48 PM   #14
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
WTH dude....
Old September 27th, 2017, 11:49 PM   #15
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
It's how you use it that counts!
Old October 7th, 2017, 01:56 AM   #16
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
I have a few different sizes, but in Germany for a couple more days. I can check when I get home.
TEAM ALFALFA
www.apexassassins.com
Old November 2nd, 2017, 10:30 AM   #17
RcTechnologies
Motorcycle(s): '12 EX250JC
what about using a piece of all-thread from a hardware store? It will be metric but not expensive for 6" or so. I think (vaguely) its M6 1.0 thread...correct me please-
RcTechnologies is offline   Reply With Quote
Old November 2nd, 2017, 11:19 AM   #18
Tricky part is one end needs left-hand threads.
Or you can just use two right-hand ball-joints.
Old November 2nd, 2017, 12:44 PM   #19
jrshooter
Motorcycle(s): ninja 300
i use the true value hardware, shift extender. i must take it off to adjust the length, not really a problem, once its set it set, its not like i change it once its set.
Old November 2nd, 2017, 02:15 PM   #20
yeah, that's what I do too. Easier and cheaper to find double right-hand threaded rod. Chop to right length and install same rod-end on both ends. Once set correct length and lock it down, I haven't had to re-adjust anyway. Even if needed, it's not that big a deal to unbolt one rod-end.
Old November 7th, 2017, 08:48 PM   #21
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
Sorry for replying this really late. Haven't got the time to measure (quite busy) and I have totally forgotten this thread which I created.
JacRyann, I have already solved the problem by bringing the footpeg a little closer to the shift linkage by using the holes of the rearset.
Sorry for not replying earlier dude and thanks a lot for your help!
Old November 7th, 2017, 09:07 PM   #22
Cool! Can you post photo of your set-up?
Interesting to see other people's solutions.
Old November 7th, 2017, 09:11 PM   #23
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
No problemo. Later today. It's 12.09pm Wednesday noon and I'm at the office
Old November 8th, 2017, 06:15 PM   #24
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
Sorry, I forgot to take picture of my setup. Will do that tonight. Sorry JacRyann!
Old November 12th, 2017, 11:17 PM   #25
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
Yeay.. .finally!
The footpeg was positioned at the circled placement. I moved the footpeg to where it is now.
Shift Linkage coming unscrewed reroka 2008 - 2012 Ninja 250R Tech Talk 4 June 26th, 2014 07:50 AM
Suggestions for a better option to stock shift linkage. nealt 2008 - 2012 Ninja 250R Tech Talk 14 August 2nd, 2012 12:09 PM
WTB: New gen shift linkage + shift knuckle + Woodcraft rear sets 675Raisinator Items Wanted 1 July 30th, 2012 05:59 PM
Shift arm linkage placement Redsvt 2008 - 2012 Ninja 250R Tech Talk 1 March 11th, 2012 08:43 AM
shift linkage bolt b_eastep 1986 - 2007 Ninja 250R Tech Talk 2 July 20th, 2010 01:53 PM
