Old October 9th, 2009, 01:55 PM   #1
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Source for those wretched rubber well nuts
You know those little rubber well nuts (rubber tubes with captive brass nuts) that are found on the windscreen and between the fairing lowers and the front cowl?
Many of us have discovered the hard way that they're very delicate and easy to tear. Including me.
Since I know I'm going to be popping the cowling lowers off at least a few times a year I decided I'd better not only replace the one I tore (%$#*!!), but get a fistful of replacements.
They are EXPENSIVE from Kawasaki (Cheap Cycle Parts wants over $4 EACH), and since they're metric (M5), no hardware store/big box home improvement store has 'em. In fact, I've yet to find an employee who even knows what a well nut is, even in stores that do stock (SAE) well nuts.
Off to Google we go.
I found this source. 60 cents a piece, plus USPS priority shipping ($7). I ordered 30, for a grand total of $25. That should last me as long as the bike does if I don't do anything stupid.
Here it is:
http://www.desmoparts.com/ducati/wellnut/wellnut.htm
It's possible they're not exact replacements, but I kind of doubt it. I'll post if they're not right.
My next mission is to find panel fasteners identical to the ones that hold the fairing lowers together, because I don't think they'll last forever. I might just use big beefy well nuts there instead.
Old October 9th, 2009, 02:01 PM   #2
randomwalk101
self wrencher
randomwalk101's Avatar
Yeah.. Let us know of the fitment. That place is in Houston...where I live but across town. I might ride over one day and pick up some
Posted via Mobile Device
Old October 9th, 2009, 02:15 PM   #3
ztrack157
The Sportisi Master
ztrack157's Avatar
Motorcycle(s): 2008 Ninja 250
Search on ebay for windscreen bolts usually comes with 8 well nuts
Sportisimoto USA is born.
ztrack157 is offline   Reply With Quote
Old October 9th, 2009, 02:35 PM   #4
gamma500
gamma500's Avatar
The windscreen wellnuts are a tad to small for the fairing ones. If you have a metric tap set, you can get the 10-32 wellnuts and tap them out...I got 25 for $7.00 off eBay. The brass nuts are a breeze to tap out and the size is large enough to not pull through the hole.
gamma500 is offline   Reply With Quote
Old October 10th, 2009, 04:14 AM   #5
Would like to know myself.
Old October 10th, 2009, 06:07 AM   #6
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Go to cheep cycle parts . Under OEM products . they are listed with cowling #92015B for $4.15 each .
http://partsfinder.onlinemicrofiche....e=13&A=40&B=62
Old October 10th, 2009, 06:43 AM   #7
randomwalk101
self wrencher
Actually if you look at the link op posted, the windscreen is m5, but there also m6 nuts which is fairing.
Old October 10th, 2009, 07:30 AM   #8
adouglas
adouglas's Avatar
Nope. I double-checked the parts fiche before ordering. The ones I'm talking about, between the cowling and lowers are M5. RacerX has it right.
Those little funky flared-head stainless bolts that you have on the fairing between it and the cowling and were it bolts to the tank are 5mm.
The parts fiche does list two different M5 well nuts, though, one at over $4 and the other at over $2 each. I don't know what the difference is... I didn't look a the nuts on the bike side-by-side.
Old October 10th, 2009, 10:21 AM   #9
Racer x
Racer x's Avatar
No I did not get it sorry . The ones for the shield are 92210A for 2 dollars. The fairing ones are 92015 B for $4.15
I have my bike apart let me look and see the difference
Old October 10th, 2009, 10:34 AM   #10
Racer x
Racer x's Avatar
I ordered the like 10 of the 92015 B 5mm nut wells from cycle parts. I am putting together race body work .
So I used six of them for the shield . I did not notice any problem . So I guess the shield ones will work on the fairing. I'm not sure .They do look the same. But they do cost half as much . But for what it is worth you can use the 4 dollar ones for the shield.
The parts from cheap cycle parts are genuine Kawasaki parts with the Kawasaki part#92015-1757.
Old October 10th, 2009, 01:43 PM   #11
00v_Lucky
00v_Lucky's Avatar
Motorcycle(s): '09 Candy Thunder Blue Ninja 250R
I am confused. So, which one should I buy? ^^
Edit: Oh and thanks for the findings op! I thought I was the only one to have lost those wellnuts.
00v_Lucky is offline   Reply With Quote
Old October 10th, 2009, 01:50 PM   #12
Racer x
Racer x's Avatar
They rot away faster than you would think . Plus taking them on and off wares them out.
The 92210A for $2.00 are for the shield
The 92015B for $4.15 are for fairings.
But they both look alike.
Old October 10th, 2009, 02:39 PM   #13
gamma500
gamma500's Avatar
10-32 Rubber Well Nuts For 3/8" Hole( I got 25 of them for $9.99 inclusive shipping)...plug this into eBay and tap them out to fit the 5mm threaded bolts for the fairing. The windshield wellnuts have a smaller flange and will slip right through the fairing holes plus most of them are for 4mm allen bolts and they are a bit shorter than the fairing wellnuts. The fairing size can work on the windscreen but not viceversa usually.
Old October 10th, 2009, 05:37 PM   #14
Someone should buy enough for everyone and sell them at-cost to save us the trouble. Anyone feeling generous?
Old October 15th, 2009, 02:02 PM   #15
Momaru
Momaru's Avatar
I'm very amused that on the OP link, 10-32 well nuts are in the picture for the 5mm...
That said, thanks for finding a distributor that doesn't require them getting shipped over the pond.
Proud member of the Blue Army
Old October 15th, 2009, 03:03 PM   #16
gamma500
gamma500's Avatar
There is one distributor who states the 10-32 will work with our 5mm bolts...not the case as I found out...you can screw the 5mm's into a 10-32 nut with some effort but you get one shot since it screws up the bolts threads. A cheap tap set from Harbor Freight is adequate for rethreading the 10-32 nuts to avoid this problem.
Old October 16th, 2009, 05:40 AM   #17
divingtigger
Pedal Power
divingtigger's Avatar
Motorcycle(s): 2008 Ninja EX250R
I picked up some off ebay, I got 16 wellnuts with the bolts for $12.02 (need to have a silver tongue though. They sell for .01 for a set of 8 and $12 shipping, talked them into shipping them together for $12.02 total).
If you have the corresponding bolts does it matter if they aren't the same size as the factory ones??
Using Pedal Power
divingtigger is offline   Reply With Quote
Old October 16th, 2009, 12:52 PM   #18
Buffalony
Buffalony's Avatar
I use the ones from desmoparts and they work fine. Hes a good seller.
Old October 25th, 2009, 10:25 AM   #19
adouglas
adouglas's Avatar
Finally got around to pulling the lower fairing off the bike to replace the well nut I tore, along with the remaining to-do on my winterization list (fogging the cylinders). First time I've pulled the plugs, and that plug socket they give you in the owner's kit is wonderful. I LOVE well-designed tools.
The desmoparts M5 well nuts are indeed a perfect fit.
(BTW, from various postings it appears there might be some confusion over metric fastener sizes. An M5 (5mm) Allen bolt requires a 4mm Allen wrench. Makes sense if you think about it... the recess in the bolt head has to be smaller than the bolt shank, right?)
Note that a new, uncompressed well nut is just a tiny bit too long to easily engage the bolt threads. Just reach around behind the panel and press it in a bit until you can get the bolt to grab.
Old October 25th, 2009, 12:41 PM   #20
seis gunnar
Motorcycle(s): '09 250R SE Lime Green
Andrew,
Thanks for the putting the leg work in and sharing the info.
When I originally read your post I was thinking you guys should be more careful. Then when I went out to work on the bike, I tore one up.
As my Dad has always says, "Only two types of people in the world; those who have and those who will."
seis gunnar is offline   Reply With Quote
Old October 25th, 2009, 12:56 PM   #21
randomwalk101
self wrencher
need to make a road trip to pick some some of these babies next week.
Old October 25th, 2009, 02:40 PM   #22
Sailariel
Sailariel's Avatar
Here it is:
Old October 25th, 2009, 02:43 PM   #23
Sailariel
Sailariel's Avatar
They make nuts and bolts in all sizes in Nylon--They are white--nothing a Sharpie couldn`t fix. Thanks for the tip on those rubber abominations.
Old October 25th, 2009, 03:33 PM   #24
00v_Lucky
00v_Lucky's Avatar
Could you provide a link for those please? They sound like a good deal because I am also in need of some bolts as well. and could you also provide pictures? or does the webpage already have them?
Old October 29th, 2009, 09:45 AM   #25
I saw fasteners like them at Harbor Freight. I'll have to remove mine and bring it in.
Old October 29th, 2009, 08:00 PM   #26
randomwalk101
self wrencher
If you can find them at HF, it'll be cheappppp...should have bought some. Let us know.
Old October 30th, 2009, 10:47 PM   #27
headshrink
headshrink's Avatar
I bought some well nuts from desmoparts of of ebay last year. They work well (no pun intended). There were even an extra one or two thrown in.
Old November 7th, 2009, 08:17 PM   #28
k4m1k4z3k
k4m1k4z3k's Avatar
I got my wellnuts from http://www.bikebolts.com. They're 67 cents apiece with free shipping on orders over $10 and then i used this coupon for 25% off: http://www.bikebolts.com/Forum_Produ..._Bolt_Kits.htm also got replacement push rivets from there (they're actually screw in rivets but still more durable) and colored fairing screws (the M5s work but i took them off because the button heads are small and looked like awkward little buttons and the M6 heads are too small to hold the fairing w/o a bushing or washer)
k4m1k4z3k is offline   Reply With Quote
Old March 31st, 2010, 06:13 AM   #29
deezyellownutz
deezyellownutz's Avatar
Motorcycle(s): 2007 Zx10R 2009 250R
Awesome thread - I used the discount coupon - 4forum20 - of the full bolt kit for the 08-10 250R come about to be a $27 shipped. I started to pull the well nuts from the plastics and looks like they are all breaking on me. Good thing I was able to find this. Dealer prices are outrageous! Thanks again! = )
2007 Kawasaki ZX10R Red
2009 Kawasaki EX250R Special Edition
deezyellownutz is offline   Reply With Quote
Old March 31st, 2010, 07:38 AM   #30
Scott1620
Scott1620's Avatar
Motorcycle(s): 2008 Ninja 250r(sold), 2007 650R (sold), 2013 Ninja 300
Nice find, I just had a heck of a time installing my zero gravity windscreen because the lower well nuts broke.... Looks like that bolt kit would be good to have around...
Scott1620 is offline   Reply With Quote
Old April 2nd, 2010, 07:22 AM   #31
kevlar250
kevlar250's Avatar
Motorcycle(s): '94 Vulcan 1500, '06 Katana 600, '08 FZ1
Kawi had a problem with many rubber parts in '08 & '09. They even had a recall on the KLR650 as the rubber turn-signal mounts would just disintegrate, you'd come out in the morning and they'ed just be hanging there by the wires. Wellnuts, clutch cable boots, cover on the starter's power cable lug, all of them looked like they'ed been baking out in the sun for 10 years.
kevlar250 is offline   Reply With Quote
Old April 2nd, 2010, 08:59 AM   #32
jonthechron
Motorcycle(s): magHitVE
+1 I was going to start a thread on this. Most of the rubbers on my 09 are ruined.
Old April 3rd, 2010, 09:33 AM   #33
2WheelGuy
2WheelGuy's Avatar
+2 I took removed the bodywork on my '08 last year and all the well nuts were totally rotten.
AFM #278
Old April 3rd, 2010, 11:43 AM   #34
Almost all the rubber I see on my '08 is pretty thoroughly disintegrated/disintegrating. Any list of what to check/replace?
Old April 3rd, 2010, 12:17 PM   #35
headshrink
headshrink's Avatar
If you are using petroleum based lubricants, this will explain why your rubbers are falling apart. They are pretty clear on the packaging that they are to be used ONLY with water-based lubricants.
Old April 3rd, 2010, 12:18 PM   #36
Why would I be putting any kind of lubricant on a rubber part I don't even recognize?
Old April 3rd, 2010, 12:33 PM   #37
headshrink
headshrink's Avatar
hehe... I'm just messin' with you.
Old April 5th, 2010, 11:04 AM   #38
Momaru
Momaru's Avatar
+3 my clutch cable boot fell apart before I'd even gotten around to lubing the cable the first time, all the well nuts had to be replaced at least once and the boot on the master fuse (30A under the fuel tank bracket) is falling apart.
Any ideas where to snag a new clutch cable boot? Can't find it on the parts fiche; seems like it's simply included w/ a new clutch cable which I don't need.
Old April 5th, 2010, 01:40 PM   #39
maglin
maglin's Avatar
Motorcycle(s): what else?
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_2416wt_958
-This signature rocks!!!
maglin is offline   Reply With Quote
Old April 6th, 2010, 05:34 PM   #40
diablo250
Crafty Salesman....
diablo250's Avatar
Motorcycle(s): 09 250r, 06 sv650sf
i ordered mine from ebay as well. They were about $10 shipped and I got around 15 of them.
With -"IST" endings adding a negative connotation: Racist, Sexist, Polygamist, wouldn't a person who hates bikes be a cyclist? I am no longer part of the order of bike haters. I am a cycler.
diablo250 is offline   Reply With Quote
[superbikeplanet.com] - Respected Success Vs. Wretched Excess Ninjette Newsbot Motorcycling News 0 December 10th, 2013 10:40 AM
WTB: Rubber expansion nuts, pop rivets, body screws (new 250r) SwagenGTI Items Wanted 3 April 17th, 2013 03:54 PM
Rubber Well nuts Daeldren 2008 - 2012 Ninja 250R Tech Talk 11 February 8th, 2013 01:28 AM
Rubber nuts on Fairings? setasai 2008 - 2012 Ninja 250R Tech Talk 6 June 21st, 2010 05:52 AM
which thread had the info about the fairing rubber nuts? Sound Wave General Motorcycling Discussion 1 April 21st, 2009 01:12 AM
