January 16th, 2018, 10:53 AM | #1 |
Join Date: Aug 2017 Motorcycle(s): '07 Ninja @50r Street Fighter Posts: 4
Oil View Glass Doesnt Show any oil
I just changed my oil and noticed before changing it, the view glass didn't show anything there. It was popped up on a trackstand sitting for about 10-15 minutes and still nothing. Immediately I thought I lost all my oil so I go one to change my oil filter and a TON of oil came out, came out to 1.6 or so quarts......
I change my oil and add another new 1.8 quarts and a few hours later from riding about 30min. I check the gauge and again it appears there is no oil in my view glass? And there is no oil in site under the engine. Im assuming this isnt normal, any thoughts? Thanks, YaBoiHuni |
January 16th, 2018, 10:59 AM | #2 |
Is the Red oil light coming on?
January 16th, 2018, 11:21 AM | #3 |
Can't be on a trackstand for a legitimate reading in the sightglass. The bike needs to be level front to back, and left to right, for the reading in the sightglass to be valid.
January 16th, 2018, 11:32 AM | #4 |
As Alex stated above, hold the bike level by holding on to the handlebar while looking at the sight glass.
January 16th, 2018, 12:09 PM | #5 |
When running, the oil is pumped out of the bottom of crankcase and is spread out all over engine, so not much shows on the sight glass. Turn off engine and watch sight glass and you should see it slowly rise as oil drips back down to crankcase.
January 16th, 2018, 12:37 PM | #6 |
Read through this tech section to confirm you are using the correct procedure to check the oil -
https://faq.ninja250.org/wiki/How_do_I_check_my_oil%3F. Basically, as previously noted - warm oil, engine off, balance vertical on level ground, wait 2-3 min - it should be between the upper and lower marks. Should take 2qts with filter to get to the top mark. Check your airbox for excessive oil if everything else checks out. With extended high speed operation they will pump oil from the crankcase breather into the airbox, but it shouldn't be excessive unless there are engine problems like extreme blow-by. |
January 16th, 2018, 12:59 PM | #7 |
Balancing the bike while bending over to see the sight glass is extremely awkward.
Telescoping mirror-on-a-stick is the simple solution, available at any hardware store, Harbor Freight, big box home improvement store, or Amazon. Find a level spot, hop on the bike, stand it up and use the mirror.
January 16th, 2018, 02:18 PM | #8 |
Thank you all. I will keep you posted. Ill check after work to see where its at.
January 16th, 2018, 02:58 PM | #9 | |
Holding the front brake guarantees it's not going to roll forward and flip up the stand. It's nowhere near as sketchy as taking a bike off of a rear stand by yourself IMO. |
January 16th, 2018, 07:39 PM | #10 |
I make the kids look.
January 17th, 2018, 05:59 AM | #11 |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
Join Date: Nov 2013 Motorcycle(s): 2009 Ninja 250R and 2014 Triumph 675R Posts: A lot.
I attached an esp8266 with level sensors and stream that to my smart phone. Then I can check my oil level on my phone as I text and drive. It is just so much easier.
No, I just level it out and hold it with one arm as I look down at the sight glass.
Spoiler for topic:
January 17th, 2018, 08:59 AM | #12 | |
Join Date: Jan 2015 Motorcycle(s): 2000 EX-250; several other years of the same Posts: 470
... can't stop updating the bike! |
January 20th, 2018, 11:03 AM | #13 |
January 20th, 2018, 12:05 PM | #14 |
Yeah, they're great for working on autos too. Can reach into tight spots such as deep into dash. And you can lower them head-first into engine-compartment to get to difficult to reach areas.
Last futzed with by DannoXYZ; January 20th, 2018 at 04:46 PM. |
January 20th, 2018, 07:32 PM | #15 | |
At least now I can make them do the heavy lifting... |
January 21st, 2018, 01:15 AM | #16 |
"a legend in my own mind"
Join Date: May 2017 Motorcycle(s): 2015 moto guzzi norge(brownie),2020 aprilia dorsoduro, Posts: A lot.
MOTM - Feb '18
make the wifey check it
"trying not to get old" |
February 12th, 2018, 11:31 AM | #17 |
I used this mirror "trick" this weekend. The mirror is now in my tank bag, for use any time.
February 12th, 2018, 12:51 PM | #18 | |
Join Date: Mar 2017 Motorcycle(s): 2007 Kawasaki 250 Ninja, 1982 Honda Ascot FT500 Posts: A lot.
Bill
Insanity: doing the same thing over and over again expecting different results each time. |
Oil sight glass | BlueHairSar | 1986 - 2007 Ninja 250R Tech Talk | 20 | December 13th, 2012 01:23 PM |
kawasaki genuine oil filter doesnt come with O rings?! | maxwellca21 | 2008 - 2012 Ninja 250R Tech Talk | 7 | November 17th, 2010 06:15 PM |
Foamy Oil in Sight Glass??? | ScorpionNinja | 2008 - 2012 Ninja 250R Tech Talk | 19 | May 17th, 2010 07:00 PM |
Oil Sight Glass | empyrean | 1986 - 2007 Ninja 250R Tech Talk | 7 | June 25th, 2009 10:25 AM |
Question about oil viewing glass. | Tubesock | 2008 - 2012 Ninja 250R Tech Talk | 20 | June 2nd, 2009 05:00 AM |
