Old March 6th, 2018, 07:40 AM   #1
Blueninja2007
Motorcycle(s): 2007 Kawasaki ninja EX250
Unhappy Ninja 250 power loss at high RPM
Hello everyone, this is my first time posting on my new account, my ninja 250 (88-07) model sputters and suddenly looses it power between 7500 - 9000 RPM and then once I hit 9500 rpm all my power come right back, I have to down shift to get my rpms to 10k to go above 60. This has been an on going issue for awhile now. I have cleaned both carbs twice, cleaned the air filter and changed the spark plugs, drained and cleaned the tank 3 times and I have run seafome threw the engine more times than I can count. Nothing seems to work and I really don't like having to take my engine to redline to drive above 60, the bike used to run great and have all the power in the world, now it's like a moped once you go above 60 and leaves me no choice but to downshift to go faster and then return to the lower gear to hold my speed. I need help to determine the problem. This ninja has been well cared for and well maintained and is kept indoors when not in use. Thanks-Josh.
Blueninja2007 is offline   Reply With Quote
Old March 6th, 2018, 07:59 AM   #2
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Blueninja2007! Glad to have you aboard...
AFM #676
Supersports are for n00bs
Old March 6th, 2018, 08:44 AM   #3
Hi and welcome!
Did this dropout occur gradually or suddenly?
What happened in between when it was working fine to now?
Old March 6th, 2018, 09:15 AM   #4
Blueninja2007
ItWhen the problem first became apparent I just turned it on one day, warmed up my ninja and drove to work during a hot summer day and as soon as I took it on the freeway I discovered that something was wrong, 6 month later the problem has not gotten any worse and has not gotten any better.
Old March 6th, 2018, 09:17 AM   #5
Blueninja2007
Hi and welcome!
Old March 6th, 2018, 09:26 AM   #6
Sounds like a fueling (carb) issue to me.
When having running problems that you think may be carb related, think in terms of throttle position (1/8, 1/4, 1/2, 3/4, WOT) to help narrow-down the carb circuit that could be causing the issue.
I would say the carbs may need to come off again and be gone through professionally - meaning total disassembly and ultrasonic cleaning. We have a member here that can do that for you.
Contact "ducatiman" if you want to go that route.
Old March 6th, 2018, 09:27 AM   #7
I would expect it to be a carburetor problem. If Ducatiman doesn't respond soon, send him a PM and see if he can help. He's usually happy to give sound advice, even if you don't plan to send the carbs to him.
Welcome to the forum, Josh.
Old March 6th, 2018, 10:17 AM   #8
In meantime,
1. do gas-cap mod.
2. verify you have vacuum to petcock.
3. verify petcock flows fuel with vacuum applied
4. check carb slides, that they move through entire travel smoothly with no binding
Last futzed with by DannoXYZ; March 6th, 2018 at 01:23 PM.
Old March 6th, 2018, 10:34 AM   #9
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome to the board!
Old March 6th, 2018, 02:08 PM   #10
/moved to pre-gen tech
Do you have another existing account on this board for me to merge this one into?
Old March 7th, 2018, 05:24 AM   #11
Blueninja2007
Smile
Thank you all so much for the fast answers and all the help!
Loss of Power, Won't go past 7k RPM denshidereku 1986 - 2007 Ninja 250R Tech Talk 38 March 17th, 2015 08:18 PM
Loss of power at certain RPM The_big_dill 1986 - 2007 Ninja 250R Tech Talk 21 July 14th, 2013 01:32 PM
Ninja 250 Power Loss grnninja 2008 - 2012 Ninja 250R Tech Talk 4 June 9th, 2013 01:09 PM
power loss - mid to high rpms/bike newb sparmek 1986 - 2007 Ninja 250R Tech Talk 9 December 16th, 2011 08:02 PM
Power loss at high rpm ///NR 2008 - 2012 Ninja 250R Tech Talk 4 June 29th, 2010 09:34 PM
