Old October 19th, 2009, 08:25 PM   #1
sofo
sofo's Avatar
Look what I picked up yesterday
I went out for a ride yesterday and when I got back my rear tire had picked up a passenger.
Yes, that's a nail embedded head-first in my tire and bent just over 90 degrees towards the back. The top of the bent part is ground up so it was there for at least part of the ride. Check out the bulge on the sidewall of the tire.
I gingerly removed the nail by pulling up and wiggling it out without any drama. The tire has a little wear from where the nail was pressed when I was cornering... which gives me the willies thinking about it now.
I've checked the pressure in the tire and watched for leaks and it seems solid. I'm about to put the bike in storage and was planning on replacing these stock tires with something else next season so overall I'm happy I didn't have any drama from this 'lil guy while riding yesterday and not worried about losing a tire.
I'm wondering if anyone can judge based on the pics whether the tire is a write-off in terms of safety or if it should be good at least to get the bike to the dealer for storage. I'm not an expert by any means and don't want to take any chances.
sofo is offline   Reply With Quote
Old October 19th, 2009, 08:32 PM   #2
Delta107
Delta107's Avatar
Motorcycle(s): 2009 Ninja 250R - BLUE
Wow!
Delta107 is offline   Reply With Quote
Old October 19th, 2009, 08:35 PM   #3
bob706
bob706's Avatar
I'm not an expert either but that one looks unsafe as hell. If it was mine I would get rid of it. Or at most fill in the hole and use it as a spare.
Old October 19th, 2009, 09:05 PM   #4
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
side bubble would be a concern, but i get concerned over chain alignments
Old October 19th, 2009, 09:40 PM   #5
Mo1981
Mo1981's Avatar
Motorcycle(s): 2008 Ebony Ninja 250R
Dang!
Matt
2008 Ebony Ninja 250R (a.k.a. "Venom")
Mo1981 is offline   Reply With Quote
Old October 19th, 2009, 11:04 PM   #6
Cedilla
Cedilla's Avatar
Motorcycle(s): 2009 Ninja 250 (sold)
I would be a little worried riding on that, and im the kind of guy that waits until I can see the belts before I replace a tire(you should see my rear tire lol).
The little bubble sticking out of the sidewall is what worries me, thread punctures are no biggie, but sidewall damage can cause a blowout.
I think rather or not you should replace it depends on your financial situation, if you can swing a new one with no ill effects by all means replace it, but if the money is just not there, I would ride on it, but know there is a very very small chance you could die from it, but I think death caused by other motorist is way more likely.
The Ninjette is not a disposable bike. You are not ever supposed to get rid of it. It is like a [friendly] herpes virus.... once you got it, you get keep it forever. Originally posted by-Headshrink
Cedilla is offline   Reply With Quote
Old October 20th, 2009, 04:26 AM   #7
g21-30
g21-30's Avatar
It looks like the bubble was from the nail head. Now that the nail is out, is the bubble gone? Since the tire didn't go flat after removing the nail, it was not punctured..right? You can always air it up to like 50 lbs and run soapy water over it and check for bubbles.
Bottom line, if you're going to store it, wait until you take it out of storage and decide whether to replace the tire(s) or not. I wouldn't buy new tires now.
Old October 20th, 2009, 06:23 AM   #8
Greg_E
Motorcycle(s): 90 Suzuki gsx600f Katana, 03 Buell XB9R
I wouldn't treat it like a track day tire, but for normal commuting it should be fine until you decide what to replace it with. Try not to lean it over onto the whole or it will eat away at the rubber and make it bigger. Check with soapy water to make sure no air is getting out, air it up for storage and check the pressure. Compare pressure with next spring and decide if it is immediately junk or can make a few trips while the roads are still dirty. Chances of picking up another object in the spring are a little higher so might be worth riding a little bit until you have time to order a tire.
Do tire prices go down in the Winter?
Greg_E is offline   Reply With Quote
Old October 20th, 2009, 10:41 AM   #9
sofo
sofo's Avatar
The bubble is gone now that the nail is out, so it looks like it was just the nail head pushing it out. There doesn't appear to be any loss in pressure but I'll try the soapy water trick to make sure.
Thanks for all the advice all!
Old October 20th, 2009, 11:55 AM   #10
rockNroll
rockNroll's Avatar
Motorcycle(s): black
For commute-ish riding I wouldn't worry about it, It doesn't look like you lean over to the point where the nail entered anyway. If you're just riding the bike to storage and will be puttin on better tyres in the spring then I wouldn't let it bother me, go ahead and ride it.
Old October 20th, 2009, 12:16 PM   #11
Greg_E
The one nice thing about junk tires for storage is that you don't care if they get flat spots from sitting in one place.
Old October 21st, 2009, 09:30 AM   #12
Snake
Snake's Avatar
I would not replace the tire until you take it out of storage for next years riding season. No need to replace if you are not going to be riding the bike.
Old October 22nd, 2009, 10:18 PM   #13
mike_sema
mike_sema's Avatar
Motorcycle(s): ninja 250r
man that sucks
08 250R: sportisi VR full exhaust, Dynojet, custom seat, kleen air rmvd, rim tape, grips, fender chop,zg db windscreen,k&n air filter,15t front sprocket,sportisi-usa clipons,solo seat cowl
mike_sema is offline   Reply With Quote
Old October 24th, 2009, 09:28 AM   #14
TrueFaith
TrueFaith's Avatar
Motorcycle(s): 2011 Honda CBR250R
Thanks for reminding me why I carry a tubeless tire repair kit, which I luckily haven't had to use yet. It's mind-boggling the things your tire can pick up on the road and the places on the tire they end up in. I wouldn't want to carve many corners with that tire. Even for commuting, I'd probably get a new one instead of trusting that one in an avoidance or panic-stop situation.
TrueFaith is offline   Reply With Quote
picked up some new boots :D massacremasses Motorcycle Gear 13 June 4th, 2012 07:18 PM
Just picked up my bike yesterday :) white_samurai New Members 19 June 23rd, 2011 11:10 AM
My heart dropped when I picked up my bike yesterday. 2fiddy 2008 - 2012 Ninja 250R Tech Talk 5 May 15th, 2011 06:07 PM
look what i just picked up... gitoy The Ex-Ninjetters Lair 12 November 15th, 2010 04:21 PM
Picked up a new ride Grn99Kawi The Ex-Ninjetters Lair 10 January 4th, 2010 07:40 AM
