Old May 16th, 2018, 08:53 AM   #1
agnt_kruger
agnt_kruger's Avatar
Motorcycle(s): 11'Ninja 250r, 06 Ninja250r(Sold), 01'GSX-R750(Sold), 07'GSX-R1000(Sold), 96 GSX-R600(Sold),11' DR-400s(SOLD)
chinese rearsets
don't buy them, the sato knockoffs anyways. They don't fit. The brake cylinder does not line up with the rearset. I am pissed. I want to buy another pair tho when I get a refund. These arashi ones look pretty sweet and they look like they will fit now that I know what I am looking for.
agnt_kruger is offline   Reply With Quote
Old May 16th, 2018, 08:56 AM   #2
agnt_kruger
the ones I want to get next
Old May 16th, 2018, 09:13 AM   #3
Can you post picture of full rearset with nothing around it? thx
Old May 16th, 2018, 09:34 AM   #4
taz
taz's Avatar
MOTM - May '17
the color also fades in about a years time too.
Old May 16th, 2018, 09:46 AM   #5
agnt_kruger
thanks for the help guys, I will take some pictures of just the rearsets when I get home tonight and post them up later or tomorrow. I appreciate the replies.
Old May 16th, 2018, 01:06 PM   #6
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
have you contacted the peeps you bought it from?
show them the pics
"trying not to get old"
Old May 16th, 2018, 03:03 PM   #7
agnt_kruger
show them the pics
I did, trying to get a refund. They sent me "install pics" which was just a picture of original Sato rearsets already installed on a different bike, ridiculous...
Old May 16th, 2018, 03:06 PM   #8
MLR
MLR's Avatar
You need to spin the master around IIRC.
After getting the poops with trying to fit mine I gave up, until I looked at it better, my brain went click and they ended up fitting.
The anodizing does fade, but meh.
Don't forget to get the blue lock tight for the fixtures, if not bits WILL come lose.
MLR is offline   Reply With Quote
Old May 17th, 2018, 12:31 PM   #9
agnt_kruger
Wow, I never thought of spinning it around. Thanks SO MUCH!!!!!
Old May 17th, 2018, 12:33 PM   #10
agnt_kruger
Here are the pictures btw
Old May 17th, 2018, 12:54 PM   #11
Genuine Sato requires flipping master-cylinder as well.
Old May 17th, 2018, 01:02 PM   #12
agnt_kruger
this makes so much sense
Old June 25th, 2018, 08:25 AM   #13
Jaffer_ali88
Motorcycle(s): Ninja 250 '12
I went ahead and bought these from eBay without doing my research. Lo and behold after 9 hours of trying to align the brake side right rearset, it obviously doesnt line up. Stumbled on this thread and got so happy knowing all I have to do is flip the MC. But then I spend 4 hours trying to loosen the nut that's on top of the MC but it's so tight that ir wouldnt budge. What do I do??
TLDR: Nut on top of the MC doesn't want to budge, too tight. Any recommendations?
Jaffer_ali88 is offline   Reply With Quote
Old June 25th, 2018, 09:30 AM   #14
Put old rear-set back on.
Bolt MC to it
Loosen banjo bolt on top.
Old June 25th, 2018, 03:47 PM   #15
Jaffer_ali88
It's stripped now...arghh...
Old June 25th, 2018, 05:01 PM   #16
What tool did you use? Beaver teeth?
Old June 25th, 2018, 05:45 PM   #17
Jaffer_ali88
I used a wrench and it kept slipping since it's so tight. But at this point i might actually need an animal with sharp teeth and strong jaws. Ive messaged my mechanic now...giving up doing this on my own...feel like ...
Old June 25th, 2018, 07:01 PM   #18
What kind of wrench? Post picture?
Old June 25th, 2018, 07:56 PM   #19
Jaffer_ali88
Tried with this. It opened the other bolts no problem.
Old June 25th, 2018, 08:19 PM   #20
Other bolts are fine, but you want 100% success rate. A single failure can set you back a LONG time and even introduce life-threatening errors into system. Two things caused stripping that bolt (which could've been prevented).
1. every single nut and bolt on this bike is metric. Toss all non-metric tools away
2. use closed-end wrench so it doesn't spread open and slip
Even better, use 6-sided sockets with longer ratchet wrench for leverage. Less chance of slipping that way because you don't need as much force.
If you plan on doing more work on bike, get and use better tools for job. You'll also want torque-wrench
Last futzed with by DannoXYZ; June 25th, 2018 at 10:15 PM.
Old June 26th, 2018, 08:16 PM   #21
Jaffer_ali88
Thanks. I actually used a closed wrench first and a torque which is the reason it slipped. Regardless. I got the bolt off and did a mock up. Now my problem is that the brake pedal is hitting the side fairing. Either my fairing is out much or the brake pedal is too inside. Did anyone else run into this issue?
Old June 27th, 2018, 02:05 AM   #22
It shouldn't move that far. Have you bled all air out of system? Can also adjust push-rod to lengthen it and raise pedal slightly.
Old July 26th, 2018, 03:28 PM   #23
syph0r
Motorcycle(s): 2010 ninja 250r
So I just got this same set basically. I am grateful I saw about turning the MC around but I can't get the shifter to connect. The rod it comes with won't work because the old swivel joint is maybe riveted on? And it's a female end so I can't attach it to the new rod. I tried with some all thread rod but it's reverse thread so I can't even do that. I'm not sure what to do for my shifter now. Everything else is fine but I need to be able to shift
syph0r is offline   Reply With Quote
Old July 26th, 2018, 03:53 PM   #24
Remove riveted ball joint. Replace with one of these:
https://www.ebay.com/itm/352063383949
These come dry. Gently pry up rubber boot and smear some light moly grease into joint. Re-seat rubber boot.
Old July 26th, 2018, 04:02 PM   #25
syph0r
Could I just remove the riveted one and put a bolt through this guy? That way I don't have to wait two weeks for a part and be without a bike
Old July 26th, 2018, 04:03 PM   #26
syph0r
Didn't realize the image was gonna be that big sorry
Old July 26th, 2018, 04:40 PM   #27
Sure that'll work.
Make sure both ends have same amount of threads engaged.
If you have to adjust length, change both ends equally.
Set so both pivot-arms are about 90-degrees to rod.
Old July 26th, 2018, 05:22 PM   #28
syph0r
From what I'm thinking they're gonna be close to the end each. But I know from another post I saw to make it close to 90° at each pivot.
Old July 26th, 2018, 05:50 PM   #29
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
Try using [RESIZE][/RESIZE] around the image link
Spoiler for topic:
It might just be the [you] tag
Old July 26th, 2018, 08:55 PM   #30
You should still get replacement ball joints. Those you have should only be used temporarily. Without seals, they probably won't last more than couple months.
Old July 26th, 2018, 09:01 PM   #31
syph0r
Yeah I didn't figure on them being permanent. But they'll work for a little while until I get new better parts in. Just need to be able to ride. Truck uses way too much gas lol. I was able to get the old stock rivet drilled out but ran out of daylight to finish so I'll finish up tomorrow.
Oh and the shift linkage is on the outside of the arm it seems like it might hit the pedal.. could I swap it to the inside?
Old July 26th, 2018, 09:09 PM   #32
Sure, inside might make for straighter aim.
Yeah, i've been using my 250 for commuting more and more to SF. Have actually gone an entire week on one tank!
Old July 26th, 2018, 09:32 PM   #33
syph0r
Yeah that's kind of what I was thinking too. It is angled as it sits right now. And straight would be better.
Yeah I'm loving the mpg... The truck does ok at 18 but...man do I love 50mpg
Old July 27th, 2018, 04:08 PM   #34
syph0r
So I have the linkage set up. Tried to get at close to 90° at trying pivot points and it doesn't want to shift. With adjusting I can either get it to shift down or shift up but not both. I also haven't tried with it on and running or moving. Just rolling with it off. The shifter also seems lower than before at an almost uncomfortable angle for my foot. :/ Not sure what to do now
Old July 27th, 2018, 04:33 PM   #35
syph0r
As it sits like this. I can shift down to first and back up to nuetral but not any up past that. And now I can't find a spot to make it able to shift into second
Old July 27th, 2018, 04:55 PM   #36
syph0r
Well I feel dumb. Rode it around the parking lot of apartments and shifts just fine once moving. A little fine tuning and it'll be perfect. Thank you for the help
Old July 28th, 2018, 12:37 AM   #37
Yeah, it's way gearbox is designed to make finding neutral easier. Real pain unless engine's running.
Chinese fairings? peperino 2008 - 2012 Ninja 250R Tech Talk 18 February 16th, 2016 03:40 PM
Chinese radical Ninjinsky General Motorcycling Discussion 26 January 21st, 2016 03:55 AM
Chinese Fairings greenswoave 2008 - 2012 Ninja 250R Farkles 37 June 25th, 2014 01:26 AM
Chinese Motorcycle Purse Snatchers vs Chinese Mob akima Videos 10 May 23rd, 2012 09:34 AM
Chinese sport bikes? Greg_E General Motorcycling Discussion 66 September 8th, 2009 06:04 PM
