Old August 20th, 2018, 07:28 AM   #1
s7rokers
Motorcycle(s): 08' Ninja 250r
Cool Speedometer throwing tantrums.
Hi all,
My meter gauge takes turns to stop work working. I had to give it a few hard knocks to get the needles moving. Sometimes its the speedometer, at times it's just the temp gauge or the RPM.
Did anyone experience the same issue? Not too confident if it is the cable or the mechanism in the gauge itself.
s7rokers is offline   Reply With Quote
Old August 20th, 2018, 09:00 AM   #2
Most likely an electrical issue. Check the connector at the back of the gauge and any other main connectors from the battery to the gauges. Also look for any wires that may be pinched or turned tightly.
Check your battery voltage. It should be over 12.7V before starting and over 13V at idle. Confirm that the terminals are tight and follow the black cable to the ground point on the frame. Look for signs of corrosion where it attaches.
Old August 20th, 2018, 09:14 AM   #3
s7rokers
thank you!
Old August 20th, 2018, 10:11 AM   #4
You're welcome, but don't thank me yet...
Old August 21st, 2018, 12:42 AM   #5
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
temp gauge on newgen? or did you mean fuel gauge?
"trying not to get old"
Old August 21st, 2018, 01:54 AM   #6
s7rokers
yes sir!
Old August 21st, 2018, 10:57 PM   #7
maverick9611
MOTM - Feb '18
Originally Posted by s7rokers View Post
yes sir!
is it temp or fuel?
Old August 21st, 2018, 10:59 PM   #8
s7rokers
is it temp or fuel?
ops! misread your reply.
It's the temp gauge
People throwing things at you? wtfh4xx General Motorcycling Discussion 59 June 13th, 2012 06:18 AM
Ninja throwing star sprocket? jezebel 2008 - 2012 Ninja 250R Farkles 24 July 13th, 2011 08:48 PM
[hell for leather] - Throwing The One Motorcycle Show Ninjette Newsbot Motorcycling News 0 February 7th, 2011 06:00 PM
Talk about throwing a wrench in my plans... Apex General Motorcycling Discussion 13 May 9th, 2009 04:50 AM
