September 23rd, 2018, 10:07 AM | #1 |
Join Date: Jul 2017 Motorcycle(s): 2007 Ninja 250 Posts: 17
Should there be a hole in the airbox?
Should this be here? it's hard to tell but it does go all the way through and doesn't look like it was drilled or chipped off or anything. Also, it is upstream of the air filter (side with unfiltered air coming in).
If not I am going to plug it with some epoxy I guess. |
September 23rd, 2018, 10:25 AM | #2 |
They all have it. It's been a while, but I seem to remember that it doesn't let air into the downstream side of the filter, so it causes no problem.
Next time try to post a really big photo. |
September 23rd, 2018, 10:28 AM | #3 |
Haha I just wanted to make sure you could see every individual molecule of plastic.
But thank you I will leave it be then. |
September 23rd, 2018, 12:02 PM | #4 |
MOTM - Sep '18, Feb '16
Could be a liquid drain .
September 23rd, 2018, 02:49 PM | #5 |
September 23rd, 2018, 05:45 PM | #6 |
It’s a screw hole for screw that holds two halves of airbox together. Scrape the broken plastic bits away and you can see way down. Count screws, there should 12 of them.
September 23rd, 2018, 05:55 PM | #7 |
September 23rd, 2018, 09:54 PM | #8 |
My money is on liquid drain on the upstream side of the filter.
Small hole in airbox -- how to seal it? | Cra1g | 1986 - 2007 Ninja 250R Tech Talk | 13 | May 13th, 2017 10:28 AM |
Round front hole on airbox? | baz666 | 1986 - 2007 Ninja 250R Tech Talk | 7 | March 23rd, 2014 03:21 PM |
I'm an a**hole... | BlueHairSar | Pictures | 24 | February 11th, 2014 07:38 AM |
Is this supposed to be here? (hole in pregen airbox) | Insan3guy | 1986 - 2007 Ninja 250R Tech Talk | 10 | July 15th, 2013 04:34 PM |
What is this hole..?? | davenay67 | 1986 - 2007 Ninja 250R Tech Talk | 14 | May 3rd, 2012 06:47 AM |
