Old October 2nd, 2018, 02:56 PM   #1
Booton
Motorcycle(s): 2016 Ninja 300, 2016 Triumph Street triple Rx
Clutch Basket removal
Hi
I’m having a bit of trouble removing the clutch basket from my n300 2013. Can anyone who has actually removed it please confirm if the clutch basket retaining nut is a normal or reverse thread?
Cheers Nick
Booton is offline   Reply With Quote
Old October 2nd, 2018, 04:31 PM   #2
Topaz
Topaz's Avatar
I haven't done it, but the service manual says:
Holding the clutch hub (B), remove the nut and washer.
Special Tool - Clutch Holder (C): 57001-1243
No mention about reverse thread.
Old October 2nd, 2018, 04:55 PM   #3
Booton
Thanks for the reply, I have the manual too. Granted it doesn’t mention it but it also doesn’t mention that you should be able to pick the bike up with a breaker bar before it lets go.
Old October 2nd, 2018, 05:28 PM   #4
Topaz
Topaz's Avatar
LOL
Hopefully someone with more knowledge will chime in.
Good luck.
Old October 2nd, 2018, 05:47 PM   #5
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
as a rule, (most times) a nut will be threaded the opposite direction the shaft turns, so that it's always trying to tighten. I do not know for sure if the basket is left or right threaded.
Clutch Basket fast1075 1986 - 2007 Ninja 250R Tech Talk 33 May 27th, 2014 04:39 PM
2003 Ninja 250 Clutch Basket Replacement!! RobJB 1986 - 2007 Ninja 250R Tech Talk 3 March 2nd, 2012 07:16 AM
Clutch basket q's *searched* iceman.kcmo 1986 - 2007 Ninja 250R Tech Talk 11 February 10th, 2012 09:10 PM
Replacing clutch basket on 88 gpx RII qwaka 1986 - 2007 Ninja 250R Tech Talk 5 August 28th, 2011 04:52 PM
