February 11th, 2019, 07:54 PM | #1 |
fork spring change
hi - I took the springs and the rods out, drilled extra holes on the rods for the gold valve emulator, but when i dropped the rods in and thread in the allen bolt, the fork is now stuck in the collapsed position and will not extend at all!
what's going on? thx. |
February 11th, 2019, 09:18 PM | #2 |
Did you put springs back in?
February 12th, 2019, 02:50 AM | #3 |
"a legend in my own mind"
Join Date: May 2017 Motorcycle(s): 2015 moto guzzi norge,2020 aprilia dorsoduro, 2014 yamaha fjr, 85 yamaha fj 1100 Posts: A lot.
MOTM - Feb '18
can you remove allen bolt?
"trying not to get old" |
February 12th, 2019, 07:00 AM | #4 |
guys thanks for your help
no clue what was going on.... I switched the dampening rods between the 2 forks and it is ok now... the forks don't look bent or anything.... so no clue lol. |
February 12th, 2019, 10:45 AM | #5 |
MOTM - Feb '18
something was in a bind, check everything closely.
February 12th, 2019, 10:55 AM | #6 |
yeah thx... still no clue... initially both forks were stuck in collapsed, then 1 got loose, then i swapped and both are loose.... already installed on the bike so they will not go back to the collapsed position again, should be ok from here.
thanks! |
Fork oil weight/spring rate | ieathonda | 1986 - 2007 Ninja 250R Tech Talk | 72 | June 12th, 2015 07:48 AM |
NewGen Fork Spring Rate Chart | InvisiBill | 2008 - 2012 Ninja 250R Tech Talk | 6 | May 30th, 2015 08:16 AM |
Fork Spring Question | Dsheumaker | 2008 - 2012 Ninja 250R Tech Talk | 5 | March 25th, 2015 05:08 PM |
Anyone know the stock fork spring rate? | Rizod | 2008 - 2012 Ninja 250R Tech Talk | 8 | April 10th, 2012 05:42 PM |
fork spring upgrade | upon1#19 | 2008 - 2012 Ninja 250R Tech Talk | 16 | May 13th, 2011 07:20 PM |
