Old August 21st, 2019, 08:39 PM   #1
59096
59096's Avatar
Motorcycle(s): GPX250 1989 model and 1990 model
Cam chain replacement dodge?
I am looking at replacing the cam chain in my 1990 GPX250. I notice that there is a small piece cast into the bottom engine case under the crankshaft cam chain sprocket which appears to be there as some sort of guide to stop the cam chain coming off at that bottom point. I think that by removing this small cast in guide it would be then possible to change the cam chain without splitting the cases? Has anyone done this? If so how did you do it?
Perpetua Culpa Alterna Vagus
59096 is offline   Reply With Quote
Old August 29th, 2019, 02:17 PM   #2
Hexadecimus
Motorcycle(s): EX250F, 1960 T100A, GPz900R, 74 XLCH, etc.
I'm not sure, but if you have to ask about grinding metal inside the cases, maybe you shouldn't. Can you confidently ensure no metal dust or chips will end up in the case? Or do you want to tear down the engine to flush it properly?
Hexadecimus is offline   Reply With Quote
Cam Chain Replacement Advice jayman87 1986 - 2007 Ninja 250R Tech Talk 34 April 21st, 2018 06:44 AM
Cam chain guide replacement help Potus101 1986 - 2007 Ninja 250R Tech Talk 4 August 9th, 2017 06:36 PM
Cam Chain replacement, possible engine damage Ginganinja 1986 - 2007 Ninja 250R Tech Talk 113 April 10th, 2014 05:08 AM
Cam chain replacement... is there an easy way? CZroe 2008 - 2012 Ninja 250R Tech Talk 12 October 26th, 2012 05:58 PM
Cam Chain Tensioner Replacement pongoo4u 2008 - 2012 Ninja 250R Tech Talk 4 July 23rd, 2010 05:11 AM
