Old February 11th, 2020, 09:36 PM   #1
nocturncal
nocturncal's Avatar
Motorcycle(s): '09 Ninja 250R
Measuring Clutch Plate Wear
While I'm waiting for my carbs, I went to take a look at my clutch plates to figure out if they were worn. My gas mileage gas been decreasing over the past year, averaging 210mi from a year half ago to around 185mi from a full to empty tank.
Took a look at clutch plates (OEM) and am about to measure thickness. When taking this measurement, am I measuring the entire thickness of both brown friction pads on both sides, or from a single brown friction pad on one side to the friction disc?
Also in terms of gaskets, anyone have experience with OEM vs aftermarket? I'm considering buying this one:
Cometic EC1135060AFM Clutch Cover Gasket
https://www.amazon.com/dp/B00T6IYIAU..._ZK5qEbATF32TK
Apparently you don't need gasket sealant with this one, but not sure if it's a gimmick product
Last futzed with by nocturncal; February 11th, 2020 at 11:22 PM.
Old February 20th, 2020, 10:00 PM   #2
cuong-nutz
cuong-nutz's Avatar
It's been a while but yes total thickness.
Majority of gaskets are good. Clean mating surface area a key and making sure you don't shift the gasket when closing it up.
HalfFast Racing Team
Old March 5th, 2020, 09:40 PM   #3
nocturncal
nocturncal's Avatar
1 out of 1 users found this post helpful
Old March 5th, 2020, 10:36 PM   #4
So what was total thickness you measured?
Old March 5th, 2020, 11:52 PM   #5
nocturncal
nocturncal's Avatar
The plates measured between 2.98 to 3.02
Clutch plate gap Unicyclone 1986 - 2007 Ninja 250R Tech Talk 9 June 16th, 2017 10:26 PM
2007 ZX6R Clutch Spring Plate/Clutch Spring Direction? KnuckleBuster General Motorcycling Discussion 2 August 24th, 2015 03:21 AM
[crash.net - WSBK] - I will wear #1 plate with pride â?? Guintoli Ninjette Newsbot Motorcycling News 0 January 26th, 2015 02:41 AM
Clutch :: Friction Plate & Metal Plate Install and Wear Questions abhijitz 2008 - 2012 Ninja 250R Tech Talk 12 June 21st, 2013 10:45 AM
WTB: Old/Used clutch plate! leed Items Wanted 0 September 2nd, 2012 11:24 AM
