December 30th, 2009, 02:35 PM | #1 |
kinda sorta noob
Join Date: Dec 2009 Motorcycle(s): '03 and '08 Posts: 62
my '08 chain has rust spots!
i keep it lubed all the time, but i just noticed some rust spots on the chain. it's winter here in dc..... what to do? wait until summer and just lube the chain? i ride every day, so i'm having a hard time figuring this one out. any advice?
December 30th, 2009, 03:24 PM | #2 |
*cough* Same happened to me. I lube the chain like clockwork, but had to leave the bike for a week when it snowed. I know it's just cosmetic rust on the outside of the links, but still rankles. Considering using some 'rust converter' paint on the outside of my chain that's supposed to stop the rust, but it'll take a long time to repaint the chain links one at a time with sufficient care I don't get paint where it shouldn't be.
If it's on the rollers, it should clear up with a little riding as it rubs off. Then just re-lube. That said, I'm anxiously waiting a better answer, preferably one that doesn't include replacing the chain.
December 30th, 2009, 05:22 PM | #3 |
Scrub it off as well as possible, lube right over it, and repeat as necessary.
January 1st, 2010, 09:58 AM | #4 |
Join Date: May 2009 Motorcycle(s): 2009 Ninja 250 (sold) Posts: 755
I noticed a few rust spots on my chain as well when I was replacing the rear tire. I don't lube my chain enough, and my bike stays outside though.
The Ninjette is not a disposable bike. You are not ever supposed to get rid of it. It is like a [friendly] herpes virus.... once you got it, you get keep it forever. Originally posted by-Headshrink |
January 1st, 2010, 02:55 PM | #5 |
There is a product called "Corrosion-X" available at most Marine Supply stores. You put some on a rag and wipe down your chain. Wait 12 Hrs. and wipe the chain down with a clean rag. Lube with your favorite chain lube. I used that stuff on my bicycle chains which were exposed to salt water a lot--We lived on a sailboat for 14 years and have gotten quite good at fighting rust.
January 1st, 2010, 03:28 PM | #6 |
kinda sorta noob
excellent advice, thk u.
i'm going to order that stuff online and work the chain. i'm a bit cautious of scrubbing the chain because i don't want to damage any rubber (o rings). and i definitely don't want to change a one year old chain! i'm a commuter that does about 5 miles (total) a day, in DC, your nation's capital. still, i want to keep the bike up to speed and well "greased".
thanks for your advice. it's been taken, and you've earned 5 gold starz! |
January 1st, 2010, 06:26 PM | #7 |
When you scrub the chain use a nylon brush and you will not have any problems with the o-rings. You need to clean/scrub the chain regularly to keep gunk from building up on it.
January 1st, 2010, 09:03 PM | #8 |
Join Date: Mar 2009 Motorcycle(s): '09 Blue Kawasaki KLE650 Versys, '95 Ducati 900SS/CR (undergoing track conversion) Posts: 287
Use a chain cleaning product and a nylon brush, then use a thick product like Chain Wax rather then some of the thinner bodied lubes. Being in an area that can Salt the roads for bad winter weather, the salt ignores the thinner bodied lubes if you happen to get any on the chain as you ride.
Tank Rust Spots | UltraHarley1 | 2008 - 2012 Ninja 250R Tech Talk | 2 | June 5th, 2014 05:14 PM |
Removing rust from chain | kennetht | 2008 - 2012 Ninja 250R Tech Talk | 5 | November 2nd, 2013 03:07 PM |
Getting rid of stubborn rust in the chain... | dark_beaverezt | 2008 - 2012 Ninja 250R Tech Talk | 7 | June 22nd, 2013 06:01 AM |
Cola to remove chain rust? | alex.s | General Motorcycling Discussion | 20 | June 5th, 2010 07:39 PM |
Rust forming on chain? | aloh | 2008 - 2012 Ninja 250R Tech Talk | 27 | May 8th, 2009 03:50 AM |
