Old January 5th, 2010, 10:10 PM   #1
Betlog
Betlog's Avatar
Motorcycle(s): 2009 250r
Noob question - regarding jetting
Can I re-jet to the default Dynojet settings (3 turns, 98 DJ jet) on my stock exhaust? I plan on adding an Area P exhaust later but would like to ride it with the stock exhaust for now.
(Apologies to the mods as I asked this within one of the other threads but decided to post it on its own thread for visibility...)
Betlog is offline   Reply With Quote
Old January 6th, 2010, 11:50 AM   #2
HKr1
IC2(SW)
HKr1's Avatar
You can do what ever ya want with the jetting. Stock bike, just putting in the DJ needles works great. I wouldnt up the jet until the pipe is on thou.
Old January 6th, 2010, 12:13 PM   #3
Betlog
Betlog's Avatar
Thank you. But why is it that you don't think I should change the main jet with the stock exhaust? Will I damage something?
Old January 6th, 2010, 01:29 PM   #4
If you select the wrong main jet, you can. The question is, why do you think you need to touch the main jet?
rejetting is not a cure all for instant/go fast HP, but rather a means to fix problems that you are having with engine power delivery characteristics.
bigger is not always better.
Old January 6th, 2010, 02:08 PM   #5
Betlog
Betlog's Avatar
Thanks. It's just that I'd rather not open up the bike multiple times. I plan on installing sliders and was thinking of doing the re-jet as well. Then later on, I can install the exhaust.
Old January 6th, 2010, 02:24 PM   #6
HKr1
IC2(SW)
HKr1's Avatar
The mains are rich enough with the stock restrictive exhaust.
Just think of it as getting into the top of the carbs once, and then once again for the bottom when the pipe comes in.
Stupid noob question from a non-noob LNasty 2008 - 2012 Ninja 250R Tech Talk 13 March 21st, 2015 10:47 PM
jetting question mikedabike64 2008 - 2012 Ninja 250R Tech Talk 4 November 19th, 2013 02:01 PM
Jetting Question NathanUc 2008 - 2012 Ninja 250R Tech Talk 3 August 5th, 2011 02:14 PM
jetting question lotus168 2008 - 2012 Ninja 250R Tech Talk 12 April 10th, 2011 02:26 AM
Noob Jetting Question 00v_Lucky 2008 - 2012 Ninja 250R Tech Talk 6 July 11th, 2010 06:23 PM
