Old April 17th, 2021, 08:35 AM   #1
Topaz
Topaz's Avatar
Phillips or JIS?
Hey guys. Are the criss-crossed screws in the Ninja Phillips or JIS?
Should JIS heads have the dot engraved in one corner to identify them?
I managed to striped both heads of the bolts that hold the front brake reservoir, and I was wondering if I should have used the JIS drivers.
I did a text search in the service manual for JIS, but nothing came up.
Old April 18th, 2021, 05:16 PM   #2
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
JIS. I bought a set of JIS drivers and they work great, but (ironically) they're marked P1, P2, and P3.
They do fit nice, though.
Old April 19th, 2021, 06:55 AM   #3
I use JIS screwdrivers on all screws of that type on any Japanese cycle.
Sometimes you are still going to chew-up a screw if it's corroded. A hand impact driver will get most anything out, but may damage it. I don't think the impact driver bits are JIS, but they do usually fit pretty well.
The small screws holding the lid on an aluminum front brake master come to mind. They are prone to corroding, and usually get chew-up by the time you get them out.
Recently we removed some with a Torx bit tapped into the head, as it was messed-up beyond the point where any type of JIS/Phillips would drive it. Worked pretty well and is safer than drilling.
Old April 24th, 2021, 04:20 PM   #4
Ghostt
Ghostt's Avatar
I use JIS screwdrivers on all my metric bikes, it and of the must have tools if you're going to work on one.
As far as stuck screws, bolts, nuts, etc.. remember to use anti-seize compound, it's not just for spark plugs. Whenever you have dissimilar metals, it's always a good idea.
violente et ignorantia
ZX-2R BLOG
Old July 2nd, 2021, 09:27 AM   #5
jjmaine
Motorcycle(s): '05 Ninja 250, '16 Ninja 300
Hey Topaz, I'm sure you know this but you can usually find some stainless allen head screw replacements for these at the hardware store. I usually end up changing these on most of my bikes because they are so soft and I never use a JIS screwdriver lol.
jjmaine is offline   Reply With Quote
[motorcyclistonline] - The Difference Between Phillips And JIS Head Screws Ninjette Newsbot Motorcycling News 0 February 12th, 2019 09:53 AM
Is a JIS screwdriver a necessity? slickt0mmy 1986 - 2007 Ninja 250R Tech Talk 7 June 26th, 2013 05:14 AM
JIS screwdrivers - Why do we damage some of the hardware? Motofool General Motorcycling Discussion 6 July 14th, 2012 11:53 AM
[webbikeworld.com] - JIS Screwdriver Review Ninjette Newsbot Motorcycling News 0 October 17th, 2011 07:40 AM
JIS Screws noche_caliente 2008 - 2012 Ninja 250R Tech Talk 33 November 6th, 2009 06:06 PM
