Old January 19th, 2022, 11:27 AM   #1
john pierson
john pierson's Avatar
Motorcycle(s): '00 SV650,'02 EX250,'15 EX300
Valve shims
Just checked my '15 300 @ 12k miles. Intakes were good 7,8,8,8. Exhausts tight 8,9,9,9. Checked shims with Venier and got rough numbers so I'll barrow Mike for better numbers. Checking with magnifying glass showed an 8 & 3 on three shims and nothing on forth. I'm 2nd owner so perhaps it was clearanced before with non oem shims. Checking prices I found oem as high as $13+each and Moose brand at $1.95(misprint?) from Dennis Kirk. Are these exhaust valves welded 2 piece units that lose head hardness during welding like some Hondas had? The face and seat must lose metal for them to tighten up right? Thanks,GJ
GUZZI JOHN
john pierson is offline   Reply With Quote
Old January 19th, 2022, 12:44 PM   #2
john pierson
oops
I think the numbers are 2 and 8-my 75 yo eyes aren't real good.
GUZZI JOHN
Old January 19th, 2022, 01:20 PM   #3
2 and 8 what? I believe the clearances in the manual are:
exhaust 0.22-0.29 mm (0.009"-0.011")
intake 0.15-0.24 mm (0.006"-0.010")
or thereabouts.
Old January 19th, 2022, 03:53 PM   #4
shspvr
Motorcycle(s): 07 Kawasaki Ninja 250
or thereabouts.
The right value in the manual for 88 thru 07
Valve Clearance:
Intake 0.08 - 0.13mm (0.003-0.005 inches)
Exhaust 0.11 - 0.16mm (0.004-0.006 inches)
The right value in the manual for 08 thru Present
Valve Clearance:
Intake 0.15 - 0.24 mm (0.005 - 0.009 in.)
Exhaust 0.22 - 0.29 mm (0.009 - 0.011 in.)
Same as your
The reason for the diff is the cam has a slight taper so valve bucket can rotate
Last futzed with by shspvr; January 19th, 2022 at 06:03 PM.
shspvr is offline   Reply With Quote
Old January 19th, 2022, 04:39 PM   #5
Valve Clearance:
The right value in the manual for 08 thru 12
Valve Clearance:
Intake 0.15 - 0.24 mm (0.005 - 0.019 in.)
This is a Ninja 300. The clearances for the 250s are not the same.
Your intake clearance for the '08 to '12 Ninja 250 should be 0.005" to 0.009" (not 0.019)
Old January 19th, 2022, 05:50 PM   #6
shspvr
That error was on my part with 19
Just dbl check it is the same for both 250 and 300 - 08 thru Present
https://www.manualslib.com/manual/77...r.html?page=45
https://www.manualslib.com/manual/80...0.html?page=53
By the way you never reply back to me about fuel filter
Old January 19th, 2022, 07:22 PM   #7
Well, intake should be 0.006" to 0.009". It looks like my secondary source was wrong.
I just look on eBay for filters and buy them. I'm surprised you couldn't find what you need. Usually they're like 10 for $10 for 1/4" or 3/16" fuel line.
Like these... I searched for "inline fuel filter 3/16": https://www.ebay.com/itm/26534470231...3ABFBM3KvN1M5f
Here are some for 1/4" line even cheaper: https://www.ebay.com/itm/33419406893...3ABFBM0pfr1M5f
If they're a little loose, put cable ties or clamps on them. I'm using 1/4" Tygon fuel line so they fit properly.
Old January 19th, 2022, 08:01 PM   #8
shspvr
I see so you didn't get a 5/16 or 8mm fuel filter
In general, this is a bad idea being slow down the flow rate which would work fine if was just one carb but not pair carbs I keep look soon or later I fine what I'm look for even I have to get a Fram G4167 that used on the old Subaru from 80's
Any way thanks
Old January 19th, 2022, 08:32 PM   #9
In general, this is a bad idea being slow down the flow rate which would work fine if was just one carb but not pair carbs...
Trust me, there will be no shortage of flow on a 250 if you use 1/4" fuel line. I've had this fuel line and filter on my 250 for five years now, and have done top speed runs and many miles. It flows much better than the stock fuel line with the tiny filter at the carb inlet.
Old January 19th, 2022, 10:06 PM   #10
It comes down to flow numbers. Here's what I measured with 3/16" filter I got from motocross shoppe:
- 80% WOT on track consumes 7 ltr/hr
- that works out to approximately 120cc/min
- measured flow-rate at 6" below tank = 210cc/min
Unless you can find somewhere to ride at 140% WOT for hours on end; flow is more than sufficient.
Old January 20th, 2022, 12:18 PM   #11
shspvr
DannoXYZ just wondering did your factor in the paper filter media density restriction for let say at lease 5or10 Micron in order to capture dirt and other particle from getting into float bowl in a gravity feed system.
Also, I hope to be driving this bike some 1500-mile one way to Idaho I hope this summer to see Grandkid and Daughter maybe even drop down into Nevada to see my mother and cousin "Yes I know I'm nuts " but what can do the driving my truck with avg mpg 12 is not going cut it and cost arm and leg in fuel so it drive or take a bus.
Old January 20th, 2022, 02:19 PM   #12
Those tests were done WITH 3/16" filter in-line. I change them once per year during winter rebuilds. Never had problem with them clogging up over time. They could probably go 5-years without any issues, I just do them while rebuilding entire bike over winter. Got bag-of-10 for peanuts and might as well use them.
For non-track riding with less than 5% time spent at WOT, even clogged filter would flow more than enough.
Old January 22nd, 2022, 08:49 AM   #13
john pierson
2.58??
Borrowed son's micrometer and found all 4 shims measured the same. 2.58mm or .1011". After looking at all the online pix of shims I saw no sizes that didn't end in 5 or 0. The center of the numbered side was against the valve stem so any center number is erased. I'll be doing emery/whetstone thinning.
GUZZI JOHN
Old January 22nd, 2022, 09:14 AM   #14
shspvr
Hey John when you order your hotcam shim kit 7.48mm they only come with in .05mm increments so you need get them with in the general valve lash clearance spec it doesn't need be 100% perfect.
Old January 22nd, 2022, 04:00 PM   #15
there's spreadsheet around where you can entre your clearances & shim thicknesses per cylinder. Then play mix & match with moving shims around. This reduces the number of shims that needs replacing. Usually just 1 or 2 max.
Old January 28th, 2022, 01:32 PM   #16
john pierson
Job done, runs fine but yellow engine light is on. Does the computer need running time to reset itself?
GUZZI JOHN
Old January 28th, 2022, 02:50 PM   #17
Good job!!!
Nope, there's no learning or storage of any kind.
Old January 28th, 2022, 04:08 PM   #18
john pierson
Glitcho??
What activates that light?
GUZZI JOHN
Old January 28th, 2022, 04:14 PM   #19
shspvr
Yellow could be the ABS Indicator Light or Check Engine Light
Did unplug the battery before you started ?.
Ahh it will not let post link to web site
so here the photo
Old January 30th, 2022, 08:56 AM   #20
john pierson
Old dog new tricks or "Once again you have learned Weedhopper"
Found info on the code reader I didn't know existed. Ah so! #64 air switch valve unplugged. Let's see-brain fade, senor moment, evil gremlins? My shop also tends to make tools and parts disappear only to reappear minutes or years later. Learning is what life is about and doesn't end until life does.
GUZZI JOHN
Where do you buy your Valve Shims? The Seldom One 2008 - 2012 Ninja 250R Tech Talk 17 August 29th, 2016 12:01 PM
Stacking valve shims corksil 2008 - 2012 Ninja 250R Tech Talk 8 July 2nd, 2015 11:03 PM
Anyone stock valve shims in SoCal yblaser Items Wanted 1 June 23rd, 2012 08:34 PM
Valve Shims questions kashun84 2008 - 2012 Ninja 250R Tech Talk 3 December 9th, 2010 12:35 PM
Buying valve shims... headshrink 2008 - 2012 Ninja 250R Tech Talk 4 March 5th, 2010 01:24 PM
