Old February 25th, 2022, 11:48 PM   #1
NinjaFinally
Motorcycle(s): GPX250R 2006
Sorting out issues on my '06
Hello all, I am new here after buying a 2006 gpx250r, Australian version. I have been using the wiki which is an excellent resource, but of course it does not cover everything.
Some gremlins I have:
- The horn does not work. I took the horn off the bike and tested it - it read 1 ohm. Put it on a battery and works ok. Started the bike, pressed horn and only get 2 volts at horn terminals. Checked fuse. I am not sure how to check the switch, although I think if I go from one side of the fuse to the correct horn wire that will do it? I suspect it will be high resistance.
- I don't have a 2006 Aussie schematic - but do have the 2005 other variants.
- Passing switch does not work, although high and low beam are both ok. I tested the switch and it is ok so I am not sure what is broken there.
- Neutral light did not come on today. Wiggled green wire that goes into gearbox area of engine and light comes on. Not how I like things to be.
- Indicators switch feels awful. I lubed it a bit and will see how it goes - had a bit of corrosion on the sliding bits.
With all of that maybe I should just get a LH block?
On the good side, I always wanted a Ninja 250. My son is learning to ride and I wanted something cheap and cheerful I could take for short rides with him, and we have already done this a few times. It runs very well, and I've enjoyed doing some other maintenance on it.
NinjaFinally is offline   Reply With Quote
Old February 26th, 2022, 03:38 PM   #2
shspvr
Motorcycle(s): 07 Kawasaki Ninja 250
The switch the best thing is get another switch assembly or try taking apart and clean it the contact to see that help.
Take a pair of pliers and squeeze a little bit should help make it get better contact then reattach to the neutral switch posts.
shspvr is offline   Reply With Quote
Old February 26th, 2022, 11:32 PM   #3
NinjaFinally
Thanks. So I will have to take the side cover off to get at the switch?
Old February 27th, 2022, 02:10 AM   #4
shspvr
Yes that right not all the way just remove the three bolts slide it back then you should be able to use a pair needle nose
Last futzed with by shspvr; February 27th, 2022 at 08:31 AM.
Old February 27th, 2022, 10:03 AM   #5
sprocket cover.
What others have found is sometimes wire rubs on chain and gets cut.
Old March 4th, 2022, 11:21 PM   #6
NinjaFinally
Thanks all, my neutral wire is now fixed. I cleaned up inside the chain cover as well, it took some gentle persuasion to remove.
[motorcyclenews.com - news] - Staff Blog: Sorting our my saggy-ness Ninjette Newsbot Motorcycling News 0 July 8th, 2013 12:40 PM
[motorcyclenews.com - news] - Staff Blog: Sorting our my saggy-ness Ninjette Newsbot Motorcycling News 0 July 8th, 2013 04:50 AM
Sorting... dubojr1 Forum Information 19 August 22nd, 2011 08:08 PM
89' 250...sorting a few issues. Togglehead 1986 - 2007 Ninja 250R Tech Talk 8 June 14th, 2010 02:02 PM
[nytimes.com] - Sorting Out Differences in Helmet Standards Ninjette Newsbot Motorcycling News 0 September 26th, 2009 04:50 AM
