Old June 13th, 2022, 05:50 AM   #1
BloodFX
Motorcycle(s): kawasaki eliminator 250 d4
Koso gauge problem
Hi, I just installed a koso d48 gp style rpm gauge to my eliminator 250, but the problem I'm having is it says the bike is 4k rpm at idle?
Its connected to the stator coil positive lead.
I have played round with the settings but nothing fixes it, does anyone have any experience with these gauges?
BloodFX is offline   Reply With Quote
Old June 13th, 2022, 09:04 AM   #2
I think you want to connect to coil's trigger line coming from ignitor?
Have link to manual?
Also is there #cylinders setting? 2/4/6/8?
Old June 13th, 2022, 12:33 PM   #3
BloodFX
https://www.kosoeurope.com/en/instru...5000-rpm-black
It says there is piston settings, but I only see a 1 2 3 4 option and the scale chart, I tried them all and 4 is only thats close to working.
Its connected to yellow wire from stator like diagram shows.
Old June 13th, 2022, 04:14 PM   #4
Try some other configurations. Connect brown RPM wire to one of following:
B. Please connect RPM wire (type B) to connect to ignition coil positive pole. This would be red wire on either ignition coil
D. Please parallel RPM wire (type A) with original tachometer signal wire. (This method is available only when original speedometer comes with tachometer on it.) This would be black wire on left #1 ignition coil that drives factory tach.
Old June 14th, 2022, 07:25 AM   #5
BloodFX
I Connected it to the left coil green wire and it looks accurate now?
Not sure if wiring is correct, top tab has green plastic around it with green cable plugged in and bottom has red cable plugged in?
Old June 14th, 2022, 08:57 AM   #6
Yeah, that should work. Tachs usually aren't too picky, just needs some level triggers. What # cylinders did you end up using?
Technically, there's difference in how coil performs with power on top vs. bottom, but really doesn't appear to affect performance.
Old June 14th, 2022, 09:22 AM   #7
BloodFX
I set to scale 2 like the manual says now rpm sits around 1500 at idle?
It has pulse positive and negative setting, can't remember which I set it to, but its defo working.
Old June 14th, 2022, 06:15 PM   #8
Yup, about 1300-1500rpm works for idle. Better little high than too low as lower oil-pressure will chew up cams.
Old June 16th, 2022, 02:08 AM   #9
BloodFX
Smile
Thanks of the help and suggestions guys, appreciated as always.
Old June 16th, 2022, 04:36 AM   #10
BloodFX
Just when I thought it was fixed, took it for ride for first time and now it won't go past 6k rpm?
Old June 16th, 2022, 06:28 AM   #11
maybe need to use #2 setting. Verify actual RPMs with factory tach.
Old June 16th, 2022, 10:34 PM   #12
BloodFX
It doesn't have a factory tach.
Old June 19th, 2022, 05:40 AM   #13
BloodFX
Scale 2 is same as before shows the bike idling at 10k?
Old July 3rd, 2022, 04:54 PM   #14
Hmm, that's no good. Might need 1K-ohm resistor in-line to clean up signal.
need help with koso gauge Old Lemon 2008 - 2012 Ninja 250R Tech Talk 8 August 13th, 2012 01:04 PM
How long have you had your Koso gauge? CThunder-blue 2008 - 2012 Ninja 250R Farkles 8 July 10th, 2012 01:40 PM
GB Koso Gauge Brackets gt_turbo Motorcycle-related 26 June 15th, 2012 11:54 PM
Koso gauge and clipons randomwalk101 2008 - 2012 Ninja 250R Tech Talk 0 November 7th, 2010 08:00 AM
Koso gauge randomwalk101 Motorcycle-related 7 November 5th, 2010 07:28 PM
