Old July 21st, 2022, 10:38 AM   #1
RockstaR
Motorcycle(s): 2002 Kawasaki Ninja 250r
Valve problem what next?
So I was going to adjust valves and found this mess. The clip came off the valve spring and the roller rode sideways and ate up itself and the cam. Then there were also these broke pieces under valve cover. Any further guidance would be appreciated. I bought this bike and have been tinkering with it. Carbs seem to be running decent but this valve problem errr. Thanks in advance gents
RockstaR is offline   Reply With Quote
Old July 21st, 2022, 11:53 AM   #2
Yes, side guide for rocker is broken on one side. This allows rocker to worm its way out.
This is usually caused by using too much torque when tightening adjuster locknut. Best to use torque-wrench to tighten locknut.
Should check all other rockers to make sure none of others are broken or cracked.
Also be sure to use full-synthetic oil.
Old July 21st, 2022, 03:20 PM   #3
shspvr
Motorcycle(s): 07 Kawasaki Ninja 250
Look like the top end of that head it wasn't getting much oil the cam look like it got wipe out a bit and rocker follower to.
shspvr is offline   Reply With Quote
Old July 22nd, 2022, 06:17 AM   #4
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
I know it's a lot of work but I would remove the head and strip it.
Replace all damaged parts clean and grind in all valves then set up the valve clearences it's much easier with the head off.
Steve
Some mistakes are too much fun to make only once.
SteveL is offline   Reply With Quote
Old July 22nd, 2022, 09:14 AM   #5
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
If that engine was running, did you remove the valve collets & spring retainer? If not you will have a loose valve dropping into the piston. Get the head off. Check for damage. Do what's required to replace/repair or buy a replacement head.
Valve adjustment problem! Graugaard 2008 - 2012 Ninja 250R Tech Talk 32 July 8th, 2013 05:03 PM
Valve Clearance Problem ElJokerr 1986 - 2007 Ninja 250R Tech Talk 9 February 22nd, 2013 12:40 PM
valve adjustment problem surlistyc 1986 - 2007 Ninja 250R Tech Talk 3 October 24th, 2012 10:30 AM
Carburetor / Valve Problem? kingkang204 2008 - 2012 Ninja 250R Tech Talk 19 August 15th, 2012 06:50 PM
valve problem dirtyrottenninja 1986 - 2007 Ninja 250R Tech Talk 6 July 23rd, 2011 02:17 PM
