Old September 24th, 2022, 09:35 AM   #1
paulard
Motorcycle(s): ninja 250 2011
broken Cam Chain tensioner ?
Hello,
my 2011 ninja 250 had a clicky noise in the engine,
comparing with some videos i guessed the problem was a loose cam chain.
So i started taking out the cam chain tensioner to check it, then i took out the middle bolt (with a bit of force) and the thread was broken. (as in the picture)
I don't know if i broke it when i took out the bolt or if it was already damaged.
I wonder if this could be the reason why the cam chain is loose?
Other than that the CCT seems to work properly so i don't think it is le cause of my problem.
What do you think ?
paulard is offline   Reply With Quote
Old September 26th, 2022, 01:20 PM   #2
I had a clicky noise that would go away when I reset the tensioner (retract and release the tensioner bolt) but it would come back. I replaced it but damaged the threads for the cap bolt when tightening. I used some high-temp RTV sealant to glue a small coin over it.
Yours is damaged in a different way. The aluminum threads came out cleanly when I tightened mine too much where yours seems to have cracked somehow… perhaps when someone tried to insert a screwdriver to retract the tensioner bolt.
Old September 27th, 2022, 08:15 AM   #3
new-gen CCT tends to be more troublefree than pre-gen.
Not sure what happened with yours.
I would replace with new one.
Also measure cam-chain for wear.
Old September 28th, 2022, 10:08 AM   #4
paulard
thank you
Old September 28th, 2022, 10:18 AM   #5
paulard
CZroe did the new tensioner solved the clicky noise ?
Old September 28th, 2022, 03:22 PM   #6
I can’t say for sure. It was not new since I salvaged it from a parts engine and I parked the bike ever since. The bike has more serious issues now, like a rusted fuel tank, and fuel that drained into the oil.
I stopped hearing it at idle but resetting the old one would also accomplish this until I went for a ride.
Cam chain tensioner ninjajoey 1986 - 2007 Ninja 250R Tech Talk 19 April 11th, 2017 03:55 PM
Old Cam Chain Tensioner akima 2008 - 2012 Ninja 250R Tech Talk 0 February 1st, 2017 06:41 AM
cam chain tensioner question bob706 2008 - 2012 Ninja 250R Tech Talk 16 June 21st, 2016 12:09 PM
Manual cam chain tensioner. Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 10 December 23rd, 2013 05:58 PM
cam chain tensioner kittyslasher 2008 - 2012 Ninja 250R Tech Talk 2 June 16th, 2013 09:17 AM
