Old March 8th, 2010, 01:13 AM   #1
samuel913
samuel913's Avatar
Motorcycle(s): Ninjia 250r, Ducati monster S4R, 620
new generation of frame slider + frame reinforcement
The WRRP frame slider holds two functions, one, it protects the fairing. Second, it reinforces the frame of the bike. This frame slider does not have an transitional point. If impacted, it would not damage the body frame like other ordinary frame sliders. Although the installation process is slightly more complicated, however, it reinforces the frame like no other frame sliders do. When your bike needs to be maintained, the fairing can easily be removed, unlike the ordinary sliders.
The ordinary sliders
www.wrrp.com.tw
My album
www.wretch.cc/album/samuel913
samuel913 is offline   Reply With Quote
Old March 8th, 2010, 01:53 AM   #2
Momaru
Momaru's Avatar
Interesting slider bracing system, looks beefy!
Care to comment on strength vs the Shogun sliders? They also form some relatively significant bracing across the engine mount and the pucks don't need to be removed for pulling the cowlings. A couple notable downsides to them is the need to notch the countershaft sprocket cover and making it harder to get to the float bowls/cam chain tensioner, so you're already two up on them in that respect.
Proud member of the Blue Army
Old March 8th, 2010, 11:35 AM   #3
laraider
laraider's Avatar
Motorcycle(s): 2009 250r green(sold) 2009 zx6r green
laraider is offline   Reply With Quote
Old March 8th, 2010, 11:52 AM   #4
JokerSeven
Ride it like you stole it
JokerSeven's Avatar
Motorcycle(s): '09 Ninja 250R, '04 R6(sold)
Very nice !
JokerSeven is offline   Reply With Quote
Old March 8th, 2010, 12:17 PM   #5
ninja man
ninja man's Avatar
Motorcycle(s): ninja250r , zrx1200r, vfr800, cb1300s.
very nice
ninja man is offline   Reply With Quote
Old March 8th, 2010, 12:18 PM   #6
ninja man
ninja man's Avatar
very nice mate
Old March 8th, 2010, 12:52 PM   #7
ninjabadger
Motorcycle(s): 2009 Kawasaki 250R, 2008 Genuine Buddy 50
Looks very interesting.
From the pics, am I correct that the the installation of these sliders flexes the rear edge of the lower fairing out about half an inch on the left side and an inch on the right side due to the thickness of the braces which are introduced between the frame and the fairing mounting bracket? Any possibility of detail shots of both sides to see how it affects the fitment of the panels relative to the upper fairing pieces and perhaps left/right bike symmetry when viewed from the top down.
ninjabadger is offline   Reply With Quote
Old March 9th, 2010, 01:01 AM   #8
samuel913
samuel913's Avatar
From these two pictures below you may see the red circles are smaller than the blue circles, therefore, the red circles are for tighten and blue circled holes are for adjustments. Just rememeber before you put back your fairings you need to loosen the orange circled screws.
I currently do not have the picture from the top of the bike. but I will pot one when I take it next time. is not very noticeable.
www.wrrp.com.tw
My album
Old March 9th, 2010, 03:19 AM   #9
Why not just make new fairing mounting brackets to compensate? It doesn't look like it would add hardly anything to the cost, really.
Old April 10th, 2010, 11:50 PM   #10
amodea1
Motorcycle(s): Kawi Ninja ZX-2.5R
So how bout what shops online have them care to share please?
amodea1 is offline   Reply With Quote
Old April 12th, 2010, 10:00 PM   #11
Dano
Dano's Avatar
Motorcycle(s): 09' Blue Ninja 250R and 07' Honda 919
Doesn't look like the mounting points are very strong unless I am mistaken these do not use the engine mounting bolts..On my SV i had sliders that used the thru engine mounting bolt, the kit came with a longer and better than OEM quality mounting rod and nuts. Still a newb to the ninjette but those tabs that the slider are mounted to may break in a accident.
Dano is offline   Reply With Quote
Frame slider recommendations? wardie 2008 - 2012 Ninja 250R Farkles 9 January 2nd, 2015 03:44 PM
Frame slider question roc0487 2008 - 2012 Ninja 250R Tech Talk 3 July 9th, 2014 02:08 PM
Picking right frame slider.. DailyRidden250R 2008 - 2012 Ninja 250R Tech Talk 7 December 12th, 2011 08:52 PM
frame slider help paulforaname 2008 - 2012 Ninja 250R Farkles 1 October 2nd, 2011 05:13 AM
Shogun frame slider frame bolt question crankinaway 2008 - 2012 Ninja 250R Tech Talk 7 June 22nd, 2010 06:46 PM
