March 18th, 2010, 02:39 PM | #1 |
Join Date: Mar 2010 Motorcycle(s): 2006 Ninja 250 Posts: 65
How "optimistic" is your speedo?
I finally got around to attaching my Dream to my bike today so I could use it's GPS and found that my speedo is almost exactly 10% off what the GPS says, I'm more inclined to believe that the GPS is more accurate because following it keeps me moving well with the flow of traffic but if I use the stock speedo I end up getting past like grandma on sunday.
I just wanna ride........ |
March 18th, 2010, 03:00 PM | #2 |
March 18th, 2010, 03:11 PM | #3 |
Newb..... on a steeek! :D
Join Date: Feb 2009 Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow Posts: A lot.
I have recently discovered that mine seems to be closer to 5%. One of those signs that shows your speed shows me at around 56-57 when the speedo shows 60. It's a permanent one maintained by the DOT,so the radar seems pretty accurate; at least to my car anyway. It has shown dead on to my car's speedo every time I go past and always about 5% lower then my bikes speedo. Now I'm going through and redoing my math when riding to make sure I'm not going too fast lol.
March 18th, 2010, 03:28 PM | #4 |
My jeep is spot on. Bike is optermiztick by 10%.
Posted via Mobile Device |
March 18th, 2010, 04:56 PM | #5 |
Join Date: Jan 2010 Motorcycle(s): 2009 Kawasaki Ninja 250r Special Edition Posts: 217
Mine is off by a full 10 percent. its ridiculous. any way of fixing this??
March 18th, 2010, 04:57 PM | #6 |
I'm off by 10% as well, whether I pass the cop going 20 or going 90
March 18th, 2010, 07:11 PM | #7 |
Nope, there's actually nothing wrong with the bike. I know of a few people that used to be mechanics for dealerships that told me the factories put the standard at +/- 10% on the speedos. It's also not just the ninjette either.
March 18th, 2010, 07:25 PM | #8 |
I'm using my Dream for a speedo now, that way I don't have to do any math, the last 10 miles of my ride are saved also so I can prove I wasn't speeding. And it's dead on accurate
March 18th, 2010, 07:36 PM | #9 |
this is so stupid. I could understand if it was like 2 or 3 km off, but 10?!? what a piece of ****. I shouldnt have to compensate in my head while im trying to ride. Unacceptable.
March 18th, 2010, 07:55 PM | #10 |
Join Date: Mar 2010 Motorcycle(s): 2003 ninja 250 Posts: 9
put a 110/90 front tire and it fixes almost dead on. mines only off by 1-2 percent. when im going 56 on gps it says 55. so there you go.
March 18th, 2010, 09:26 PM | #11 |
If the speedo is optimistic, why isn't the odometer, or is it?
March 18th, 2010, 09:29 PM | #12 |
March 18th, 2010, 09:44 PM | #13 |
The odometer error is not necessarily the same as the speedo error. It's pretty common for the speedo calibration to read quite high, while the odometer is much closer to accurate.
March 18th, 2010, 10:28 PM | #14 |
Humble Observer
Join Date: Mar 2009 Motorcycle(s): 2009 Yamaha XT250 Posts: 612
The discrepancy in speed seems to come from the speed gear in the wheel hub instead of the gauge. I tested it. I put my after-market speedometer, using the stock hub gear to count rotations, and my bicycle computer, with a magnet on the wheel and sensor on the fork to give rotation readings. The calculations for the two gauges being the same: wheel circumfrence multiplied by wheel rotations in given span of time. When all other factors are equal, the deviation between the bicycle speedo and motorcycle speedo reading was 1 to 1.2. That translates to an actual speed of 25 reading 35, or 50 reading about 60
Everything I post is "IN MY HONEST OPINION". Why is "Parking Lot Enduro" not a thing? |
March 19th, 2010, 01:34 AM | #15 | |
March 19th, 2010, 03:28 AM | #16 | |
Humble Observer
March 19th, 2010, 06:15 AM | #17 |
Truong - in your first post you say actual speed of 25 mph but reading 35 mph. That's an increase of 40%, and unlikely to happen. 1:1.2 for 25 mph would be 30 mph, not 35 mph. An actual speed of 50 mph but reading 60 mph is an increase of 20%, and while possible, is still on the high end of what other folks have been reporting.
Aside from the math, the best way that folks dial in those bike speedos is by using a GPS and calibrating them until they match GPS speed. There's no way to accurately measure the circumference of the outside of the tire with enough accuracy to get the speed within a mph or two.
March 19th, 2010, 06:32 AM | #18 |
Thanks alot Alex, so I really do have 10,700 miles on my '09. Next thing you are going to tell me is that there is no 7th gear that unlocks at 11,000 miles.
March 19th, 2010, 07:10 AM | #19 |
Last year I decided to look into the speedometer/odometer accuracy issue out of curiosity. I took apart and analyzed a spare speedometer that I had laying around, and what I determined is that there are two different systems at play, one for the odometers and one for the speedometer. Both are driven by the same cable but their operating principles are fundamentally different. The odometer system has fixed gear ratios; in other words, the number of turns of the odometer wheels is rigidly linked to the number of turns of the front tire, an exact ratio of 876.5:1; in other words, it takes 876.5 turns of the wheel to advance the odometer exactly one mile. To get that many wheel rotations in one mile you need a tire circumference of 72.29 inches, which corresponds to a calculated tire size of 110/80-16 on the Ninjas through '07 at least..
Unlike the odometers, the speedometer is not rigidly connected to the cable. Instead, a magnet on the end of the cable spins inside a steel bell, using magnetic drag to rotate the bell and the speedometer needle that's attached to it. There is a coil spring attached to the needle shaft which counteracts the magnetic drag and also returns the needle to zero when the bike is stopped. Because it is impossible to manufacture a mechanical speedometer with perfect accuracy on an assembly line, something has to be made adjustable so that the unit can be calibrated after assembly. From what I can tell so far that calibration is done in part using the spring that brings the needle back to zero. One end of that spring, a type of spring called a "clock" spring, is affixed to the needle shaft. The other end is attached to a metal tab that's part of the speedometer housing. Bending that tab alters the amount of spring force that counteracts the magnetic drag force. Making the spring tighter lowers the reading for a given speed, looser makes it read higher. There are two ways that a speedometer can be out of calibration. The first way is for it to read high or low by an amount that is the same at all speeds, this is called offset. The other way is for the scaling to be wrong; in other words, the percentage of error varies with speed. Adjusting the clock spring only addresses offset error, not scaling error. I haven't determined if there's a way to adjust scaling error as of yet. I'm building a calibrator to work with my speedometer using a tachometer and a variable speed motor to drive the speedo cable, I should have that in service in the next couple of months. Here's a sketch of the speedo gear ratios: speedoratios.jpg |
March 19th, 2010, 08:11 AM | #20 | |
You ought to be keeping your eyes on the road anyway. Most of the time I just go with the flow of traffic, so what the speedo says does not matter. I actually don't mind the mental exercise of conversion at all. Doing math in your head is good for your brain and I try to do so whenever I have the opportunity. |
March 19th, 2010, 08:18 AM | #21 |
The fact that the odo and speedo are independent is good to know. A wrong speedo I can live with, but a wrong odo gives us inaccurate fuel mileage calculations and throws off the maintenance schedule.
Now I know I don't need to correct for inaccurate odo readings. Thanks! |
March 19th, 2010, 08:59 AM | #22 |
Join Date: Mar 2009 Motorcycle(s): '09 Red Ninja 250r Posts: 59
Mines off exactly 10% according to my GPS at all speeds. This is a lot better than being off 8% or 12% since it is easier to calculate on the fly. I wish somebody can figure out a way to fix the % error with the same size tires. Bigger tires would fix the speedometer error but will mess up the odometer.
March 19th, 2010, 09:52 AM | #23 | |
March 19th, 2010, 02:06 PM | #24 |
super ninja
Join Date: Feb 2010 Motorcycle(s): 2009 kawasaki 250r Posts: 127
sounds about right to me hahaha i used the gps on my phone and about the same as everyone else 10% off pretty lame and stupid if you ask me
2009 Ninja 250r aftermarket parts *HotBodies double bubble* *Swing Arm Sliders* *Sylvania Sliverstar Ultra* *Akrapovic Slip-on* *Shinto Clip-Ons/Grips/Bar Ends* |
March 19th, 2010, 09:45 PM | #25 |
Join Date: Feb 2009 Motorcycle(s): '91 Honda CBR600 F2 Posts: A lot.
Last time I checked, I was off by more than 10 percent (showed 70 while following behind my parent's car that was going 60). Haven't checked again since I put the sport demon on the front though.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail. |
[superbikeplanet.com] - Back in Stock & Shipping: "Roberts" and "Lawson" Yamaha Art P | Ninjette Newsbot | Motorcycling News | 0 | March 13th, 2015 01:40 PM |
[roadracingworld.com] - Stoner: "I'm Not Feeling Too Optimistic For Brno" | Ninjette Newsbot | Motorcycling News | 0 | August 22nd, 2012 09:30 AM |
[topix.net] - "The Fonz", "Ralph Malph" & "Potsie" are giving away Fonzie's motorcycl | Ninjette Newsbot | Motorcycling News | 0 | August 16th, 2012 04:30 PM |
[topix.net] - Greater Kalamazoo United Way "cautiously optimistic" going into annual | Ninjette Newsbot | Motorcycling News | 0 | September 14th, 2010 03:40 PM |
[sportrider - latest stories] - Nitrous Oxide--"Wet" and "Dry" Kits | Ninjette Newsbot | Motorcycling News | 0 | April 12th, 2010 11:20 PM |
