Old March 29th, 2024, 12:45 PM   #1
unionjack
Motorcycle(s): ninja ex250f
fixed other issues currently no spark
bike has a fully charged battery,is getting air and fuel and carbs are in working condition, the bike worked pretty well a week ago just had issues starting and wont start at all, old owner did wire in a new ignition and its what im currently using, any idea as for where to start checking now that theres no spark?
unionjack is offline   Reply With Quote
Old March 29th, 2024, 01:19 PM   #2
When you say the previous owner wired in a new ignition, do you mean ignition unit or ignition switch?
Old March 29th, 2024, 01:55 PM   #3
unionjack
ignition switch, it appears to have the resistor needed for modification as well
Old March 29th, 2024, 03:00 PM   #4
OK, I was wondering if maybe he did a bad job soldering in the resistor, and the connection broke.
Old March 29th, 2024, 03:02 PM   #5
unionjack
im going to do a test and probably replace that tomorrow to start i doubt the coils would both simultaneously go bad out of nowhere
Old March 29th, 2024, 03:15 PM   #6
unionjack
random added note i just took a relook at said ignition and w2anted clarification, there is no resistor directly connected to the grey wire, it is laid out sideways on the board, is the 100ohm wire supposed to be directly spliced to the grey one?
Bike won't start- spark issues? StuntPuppy 2008 - 2012 Ninja 250R Tech Talk 13 April 15th, 2017 09:47 AM
[motogp.com] - McPhee: “We have some issues that need to be fixed!” Ninjette Newsbot Motorcycling News 0 May 26th, 2015 07:10 AM
Finally fixed something of my own! CZroe Off-Topic 10 May 8th, 2014 06:09 PM
Removing spark spark plugs? tsdexter 2008 - 2012 Ninja 250R Tech Talk 3 June 26th, 2013 03:48 PM
2002 Ninja 250 - issues (spark pugs, dirty carbs, won't idle, etc?) Pocket Sprocket 1986 - 2007 Ninja 250R Tech Talk 12 May 17th, 2013 11:13 AM
