Old April 30th, 2024, 09:52 AM   #1
johnhol78
Motorcycle(s): 2005 ZZR600. 2005 EX250F Ninja
Airbox nightmare
I've searched but this is not a "I want to put pods on post"...
This is a "the bike came with no airbox at all and I need to put one back in the bike"..
I got a complete airbox from ebay, cleaned it and have a new filter in it....BUT....please tell me I seriously don't have to remove the rear wheel to get it in the frame!
rear plastics and mudguard i can deal with....but the wheel as well?
Going to do the battery holder mod while it's out of the bike - does this make it easier to get in the frame as well?
Thanks for the help....
johnhol78 is offline   Reply With Quote
Old April 30th, 2024, 11:14 AM   #2
ACL 9000
ACL 9000's Avatar
Motorcycle(s): 2005 EX250, 1975 Suzuki T500, 2018 Kawasaki Z900RS
You just have to drop it low by disconnecting the shock at the top. If I recall correctly. But yeah, stuff at the rear has to make way.
I don't know about the mod. I ended up just getting used to the disassembly. I'm not sure how much time it saves.
ACL 9000 is offline   Reply With Quote
Old April 30th, 2024, 11:46 AM   #3
If you do the battery box separation mod, then you can get it in without messing with the shock or rear wheel. I did that and now I can remove the carbs, etc, without all the headache.
Old April 30th, 2024, 12:48 PM   #4
johnhol78
Perfect...yes, cutting the battery part off..
Dropped mudguard for more room....and I think it should go in now with anymore stripping.....
Old April 30th, 2024, 01:22 PM   #5
Rednose02231
Motorcycle(s): 2009 kawasaki Ninja 250R
i just went through this yesterday the air boxs comes apart with screws and it will fit in through the top of the bike
Rednose02231 is offline   Reply With Quote
Old May 4th, 2024, 05:07 PM   #6
johnhol78
And onto the next “issue”…
Bike would start and idle great - little lumpy but needs a run with Seafoam I think so really clean the pipes if you know what I mean
BUT - today, start the bike. Pull in clutch and put it in gear…..dies
So I disconnected the side stand switch…now I can pull the clutch and select first….
Slowly release clutch and dies, no matter the revs or speed I let it out
Read it could still be the switch but also read something about clutch switch…
Any ideas guys?
Old May 7th, 2024, 08:41 AM   #7
BoKu
Motorcycle(s): EX250F (2x)
Any ideas guys?
Find the two wires that went to the side stand and connect them together.
BoKu is offline   Reply With Quote
Old May 7th, 2024, 09:02 AM   #8
johnhol78
Thanks...found the FAQ and then found one if the wires wasn't connected
All good now.
Just the final carb tune and it should be good to go.
Welcome to my nightmare... snapshot 2008 - 2012 Ninja 250R Tech Talk 3 May 23rd, 2020 05:53 AM
Valve Adjustment nightmare!! Jono 1986 - 2007 Ninja 250R Tech Talk 18 November 9th, 2011 12:29 AM
...from bad to worse...my clutch nIgHTmaRE Purspeed 1986 - 2007 Ninja 250R Tech Talk 64 July 17th, 2009 05:28 PM
