April 5th, 2010, 11:13 AM | #1 |
Ninja 250R Defect Thread
After disassembling the 250r to install several mods and do to it's periodic maintenance, I have noticed that the Ninja has some flaws of it's own.
The point of this thread to share information with current and future owners about things to look at, during the inspection and maintenance of the bike, so everyone can have the safest ride mechanically possible. What I have noticed: Rubbers that are protecting the brake cable from rain/water look like they have 10 years of sun and might cause a breaking problem in time. |
April 5th, 2010, 11:17 AM | #2 |
Join Date: Apr 2009 Motorcycle(s): 2009 Buell XB12Scg and 2009 Kawasaki Ninja 250R Posts: 98
I had a hole in the head of the motor (2009 with 1k miles). This caused radiator fluid to leak all over the bottom of the bike.
-Nick- Posted via Mobile Device |
April 5th, 2010, 11:42 AM | #3 |
The rubber dampers under the passenger seat are often not fully inserted and fall out, despite glue. You can't "see" that they aren't all the way inserted either. It happens so fast that they get lost and most people have no idea there was ever anything even there.
The area around the keyhole with markings like "Lock" and "Off" will crack and flake off over time. A little rubber piece that looks like a "U" with squared off corners is known to fall out. It has something to do with keeping the fairings/side panels from scratching the tank. I think we all know about the CDI problem causing variable heat sensitive tach readings on some bikes (mine included). The area around the keyhole is sensitive to key scrapes so I always separate my motorcycle and cable lock key from the others. I keep a plastic cap (from an ink pen) on the loose cable lock key and after 12.5K miles I can see that it's still causing wear in the black paint all around it. Of course, it's nowhere near as bad as I've seen on some extremely low mileage bikes where people sitck their full set of keys there. Heck... my left bar end it starting to polish and become silver (instead of black) due to part of the grip being occupied by my handlebar remote. Everytime I look my hand is still comfortably on the remaining rubber, so it's still a little weird. Last futzed with by CZroe; April 5th, 2010 at 04:51 PM. |
April 5th, 2010, 10:20 PM | #4 |
The tabs that mount the upper cowling to the frame are defective, they destroy every screw I put into them.
Possible security breach, being able to open the passenger seat without any keys or tools. (no details will be released) |
April 6th, 2010, 02:25 AM | #5 | |
I lock my helmet all the time with a $300 Bluetooth kit (bulk is removed and under the seat). |
April 6th, 2010, 06:58 AM | #6 |
I bought a helmet case and carry it with me. The helmet stays protected and I don`t worry about rheft. I stick the empty case into my tank bag or tail bag when I am wearing the helmet.
April 6th, 2010, 02:04 PM | #7 |
April 6th, 2010, 02:53 PM | #8 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
Jon, Im aware of that also, but there is a REALLY easy way to fix that.
April 6th, 2010, 03:08 PM | #9 |
Join Date: Oct 2009 Motorcycle(s): Red 08 250r Posts: 218
how to fix that
April 6th, 2010, 03:24 PM | #10 |
Care to enlighten us? PM is fine since that'd keep the details of the 'break-in' method off the board for safety reasons.
April 6th, 2010, 03:27 PM | #11 |
Join Date: Dec 2009 Motorcycle(s): Ninja 300 2013 SE , Ninja 2009 blue/Honda Nighthawk S 1985 blue Posts: 222
April 6th, 2010, 08:25 PM | #12 |
April 7th, 2010, 07:37 AM | #13 |
Join Date: Nov 2008 Motorcycle(s): 2011 Honda CBR250R Posts: 585
One of the biggest problems I've read about involves the shift foot lever falling off when the bolt that holds it backs out from use & vibration. It's never happened to me, but it's happened to enough new owners that I always make sure to check the shifter before each ride.
April 7th, 2010, 06:55 PM | #14 | |
April 7th, 2010, 07:38 PM | #15 |
The mirrors also get loose due to vibration, loctite on the bolt solves this issue
April 8th, 2010, 10:31 AM | #16 |
12,550 miles and my mirrors still stay put, so I know I don't have his problem. If I used the cover more often that may not be the case (I always have to readjust after using the elastic cover).
April 8th, 2010, 11:50 AM | #17 |
11,900mi here, my mirror ball 'n' socket joints seem to be weakening a little, but I keep it covered when I'm not riding, meaning the cover goes on/comes off 5-8 times a week. Not failing yet, just needing more frequent adjustment than they have in the past.
April 13th, 2010, 05:48 PM | #18 |
Join Date: May 2009 Motorcycle(s): 2009 Kawasaki Ninja 650RTE & 2009 Kawasaki Ninja 250R (SOLD) Posts: A lot.
Gas Tank Lock!
Yo, add the Gas tank Lock/Cap to this list!
I rode around to do some stuff, then on my way home i stopped to get gas. I couldnt get the gas cap open. I tried for 12mins! There is clearly sumin wrong or defective with it. My Key is perfect, not bent,etc! So i stopped at the stealership on my way home. I had a mech take a look and so he ordered me a New Gas Cap-Lock and told me itll take a Week!!! Theyll call me when it comes in. Its still under warranty so Cost $0.00! So now i CANT ride my bike for a week, cuz its on Vapors-Low!!! |
April 13th, 2010, 07:10 PM | #19 |
Wartown, USA
Ok, guys....
I have notified Kawasaki of the security vulnerability in the passenger seat cover. I dont know what they will do with it, other than perhaps issue a notification to bike owners, or perhaps just do a redesign with my modified parts plan for the 2011 bikes. I do have a solution to the problem, that works and eliminates the vulnerability. The issue now is how to get the info out to all you ninja riders. I think the best way to do this is just to post what part needs to be modified, with no explaination of why or how it works. Just a "do it" kinda of thing. The other issue is that I would HIGHLY recommend you do not store anything of value in the tail, or lock your helmet to the bike using the supplied helmet lock. It is NOT secure, and can be defeated in less than 5 seconds. |
April 14th, 2010, 01:37 PM | #20 |
Join Date: Oct 2009 Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r Posts: 959
please do post the solution..
April 14th, 2010, 05:56 PM | #21 |
Da Duckman
Join Date: Nov 2008 Motorcycle(s): '08 250R, '06 Chopper, '80 Puch Magnum II, '01 SV650, '99 CR250/CR500AF Sportbike. '02 CRF450/CR500AF Dirt Posts: 480
Add this to the list.
Change the oil and this comes out:
DuckmanCycles Youtube Channel - VvTheDuckvV Youtube Channel SkeeterTheDuck on Youtube! - SkeeterTheDuck Facebook Page |
April 18th, 2010, 09:00 AM | #22 |
Clutch Cable is showing signs of wear, at only 6,600 miles? Normal wear and tear on a cheap cable on our bikes?
If you squeeze the cable alil, you can see down it alil, where the cable comes up and into the handlebar! Ill take a Pic later on this week, its cold out today and im not in the mood to play around with it. heh. |
April 20th, 2010, 08:20 AM | #23 |
Join Date: Mar 2010 Motorcycle(s): 2007 Zx10R 2009 250R Posts: 134
The wellnuts are junk. I took off my fairings to sell and attempted to save the wellnuts and they just disintegrated in my hands. They looked like they were on there for years.
2007 Kawasaki ZX10R Red 2009 Kawasaki EX250R Special Edition |
April 22nd, 2010, 12:31 AM | #24 |
I could swear that my key would spring back to center when used in the fuel door but it stopped before my second service. I have to push it down and return it manually to remove the key. The dealers all tell me that it isn't supposed to spring back and that nothing is wrong. Who's right?
April 22nd, 2010, 01:02 AM | #25 |
Join Date: Dec 2009 Motorcycle(s): Blue 2008 Ninja 250R Posts: 86
April 22nd, 2010, 11:10 PM | #26 |
I've never had the key spring back on a ninjette; I think you may have been mistaken.
April 23rd, 2010, 04:19 AM | #27 |
April 24th, 2010, 12:26 PM | #28 |
Ride it like you stole it
Join Date: Jan 2010 Motorcycle(s): '09 Ninja 250R, '04 R6(sold) Posts: 362
does the vulnerability issue with the passenger seat also apply to the solo seat cowl ?
April 24th, 2010, 01:59 PM | #29 |
Join Date: May 2009 Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt Posts: A lot.
April 24th, 2010, 02:02 PM | #30 |
C'mon guys is there some super secret reason why you can't share how it is defective. I'm interested in looking for a fix.
April 24th, 2010, 02:28 PM | #31 |
As in my post #22 here,
Heres Pics of the area of the clutch cable im talking about. The top of the cable , when clutch is fully pulled IN, shows some Fraying on it. Is this normal for a 2009 bike with only 6,600 miles on it? Clutch operation is smooth and easy. Its hard to tell in these pics, vs the Naked Eye, but the slight fraying isnt nutin like if half of teh cable thickness itself was fraying, but just afew strains on top when clutch is fully pulled in. |
April 24th, 2010, 02:31 PM | #32 |
when was the last time that cable was greased and lubed?
April 24th, 2010, 02:53 PM | #33 |
Never, heh
When ive washed my bike ive always set a old rag/sock over the brake/clutch levers so water cant Force into the cable during washing. Manual says 600 miles, then every 7.5k miles, to have clutch looked at adjusted lubed,etc! But Mines never felt loose or doesnt feel any different from the day i first rode it home from the dealer! |
April 24th, 2010, 03:24 PM | #34 |
perhaps you should. grease on the cable might help prevent the fraying. no maintenance on an item that should be properly maintained is no reason for it to be considered a defect.
also, and I have no proof of this, but try to align the openings of the adjuster so they are not lined up with one another to prevent the cable from rubbing on the edges of the adjuster cutout. I got this idea from looking at pictures of the only other person that has had a clutch cable failure from fraying. http://www.ninjette.org/forums/showthread.php?t=16000 |
May 6th, 2010, 10:08 AM | #35 |
Da Duckman
Some people said I should post my rearset explosion damage in this thread.
May 6th, 2010, 10:21 AM | #36 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250R Posts: A lot.
Bellows from the Carbs to the Airbox were not propperly installed when I get the bike brand new. Easy fix (loosen the clamps, straighted them out and slide them over the mouths of the carbs, tighten clamps).
The cluch lever bolt was over torqued from the factory and had sheered off. After about 1000 miles the lever would vibrate profusely. I removed the bolt, in two pieces. Easy fix, had to wait for part. (New bolt was about 6 bucks). Lower fairng bolts under the side stand and next to the exhaust shake loose very easily. (Tighten them regularly).
Addicted to anything that has an engine and rolls. |
May 6th, 2010, 10:24 AM | #37 | |
Da Duckman
Fix is easy, but getting to those clamps isn't. Lots of work.. very time-consuming, especially to someone that hasn't done this type of work before.
May 6th, 2010, 10:32 AM | #38 |
OH YEAH...
From the factory all of the bikes came with a big protruding piece of black plastic hanging off the tail from behind the plate mount. Hack that crap off!!!
May 6th, 2010, 10:34 AM | #39 |
Yeah it is a really tight fit. You have to take off the tank to get a good angle. It's not hard to fix, but it is a royal PITA.
May 6th, 2010, 10:47 AM | #40 | |
It was an unusual and creative fix, but I think it is a good improvement.
Shin's 250r Build Thread | Shintoxica | 1986 - 2007 Ninja 250R Farkles | 3 | August 22nd, 2013 11:10 AM |
Another White Ninja 250R SE Thread | sousuke86 | Pictures | 43 | February 17th, 2013 12:20 AM |
Exhaust Paint Defect | Joshorilla | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 12th, 2012 11:59 AM |
k24_cm7's update/picture thread (10' Ninja 250r SE) | k24_cm7 | Pictures | 41 | April 18th, 2012 10:32 AM |
My White Ninja 250R SE Thread. | Mr.E | Pictures | 148 | April 15th, 2012 09:12 PM |
